Old Nov 11, 2003, 08:43 AM
cfossa is offline
Find More Posts by cfossa
cfossa's Avatar
Stow, MA
Joined Mar 2002
SwitchBack Battery recommendations?
Hi Guys,
I'm in the market for some new battery packs to power my MM Switchback. I'm using the "stock" GWS EPS-300C motor and 10x8 prop. I have purchased some cheap "no-name" 8 cell 700 NiMH packs in the past, and was not satisifed with the performance. One brand never gave me decent power, and the other brand had decent power but developed black wire "disease" after a few months.
So, I've learned my lesson with cheap packs and want some decent 8 cell 700 mAh NiMH AAA packs for my SwitchBack.
Any recommendations? I'm not ready for the "brushless" jump yet
Carl
cfossa is offline Find More Posts by cfossa
Old Nov 11, 2003, 08:48 AM
BrunswickOH is offline
Find More Posts by BrunswickOH
Brunswick, Ohio
BrunswickOH's Avatar
Joined Aug 2003
get some Kan 650's from cheap battery packs or you could go with the Kan 1050's can't go wrong with either. Just go into his custom battery packs link and decide what you want.
BrunswickOH is offline Find More Posts by BrunswickOH
Old Nov 11, 2003, 08:53 AM
Rod Hart is offline
Find More Posts by Rod Hart
Rod Hart's Avatar
Colorado Spring, CO
Joined Mar 2002
I recommend 8-600AE for the cheapest go. I tried Kan 950s, the plane feels heavy and does not perform as well, the Kan 650s might be good. It will have pently of power and fly great. You can later move up to 2 e-techs or 3 Etech and a razor. Then you will have power like slimmers.
Rod
Rod Hart is offline Find More Posts by Rod Hart
Old Nov 11, 2003, 08:55 AM
Brunswick, Ohio
Joined Aug 2003
Great looking plane!!
Old Nov 11, 2003, 09:05 AM
locomoto is offline
Find More Posts by locomoto
locomoto's Avatar
San Pedro, CA
Joined Mar 2002
cfossa,
Go with the Kokam 2 cell 1500's or the E-tec 2 cell 1200's. When you go brushless, they will also work well with the Razor and other small motors. I'm using both of these in my Switchback Sport with a Razor400, GWS 'B' box and an APC10x7SF prop. I prefer the 3 cell Etec's, though.
Park Flyer Motors has great prices right now on these cells, which makes it difficult to justify a comparable NiMH pack.
Dave
locomoto is offline Find More Posts by locomoto
Old Nov 11, 2003, 09:43 AM
dpoles is offline
Find More Posts by dpoles
Crash and Build
dpoles's Avatar
United States, NY, Ithaca
Joined Oct 2001
I have a SB with a razor 400/GWS C box. Also building a Tantrum with same setup.
I am looking at going LiPo for Christmas.
What is the current thoughts on 2 vs 3 cells? Are Thunderpower packs best?
dpoles is offline Find More Posts by dpoles
Old Nov 11, 2003, 10:01 AM
tahoecrest is offline
Find More Posts by tahoecrest
Hooked On Flying!!!
South Lake Tahoe, CA.
Joined May 2003
I second the vote for lipoly's. With the cost of the Lipoly batteries coming down they are an exeptional buy now. I have been using etec 1200 2s2p packs for my Switchback Sport & Dandy GT since I built them. They provide great performance and long flight times. The hobby is definitly aggresively moving in this direction, thus the better cost factor. It will also give you packs for you to use in the future should you go brushless. You might also consider replacing the 300 with a 350 motor when your old one wears out. You should notice better performance over the 300 and same replacement cost.
HAPPY FLYING!!!
tahoecrest is offline Find More Posts by tahoecrest
Old Nov 11, 2003, 10:03 AM
rclark is offline
Find More Posts by rclark
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
I flew the SB with 8 cell packs of 600AEs and HE1100, and KAN950s. I've settled on 8/9 cell CPB650s (actually I'll be buying 9 cell packs from now on). Lighter than the 600AEs and perform just about as well and oz's lighter than the other packs. I'd stick with the 8 cell packs if still flying stock. I fly a miniAC/16 in mine.... Bought my packs from Cheap Battery Packs as well.
No LiPy for me yet as I'd have to 'gear up' for them (a fire proof area for charging, plenty of venilation (sp), new charger, new batteries, etc...) .... Someday....
rclark is offline Find More Posts by rclark
Old Nov 11, 2003, 10:50 AM
cfossa is offline
cfossa's Avatar
Stow, MA
Joined Mar 2002
RClark,
Thanks! I'll check out the CPB 650's as I'm running a "stock" EPS-300 motor. I've been staying away from NiCD with all the reports of burning up motors quickly. I'll settle for a little less performance from NiMH if my motors last longer .
It sounds like the CPB 650's are a good compromise between 600 AE NiCds and 700 mAh NiMh packs.
I appreciate all the other recommendations for LiPo cells, but I too would need all new chargers etc. I'm not ready for that jump yet.
Carl
Old Nov 11, 2003, 11:10 AM
rclark is offline
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
I don't think the 650s are going to help in that department . Why I went BL. I've now 'saved' money in the long run by going BL with the miniAC and CC P25 ESC. Took less than 1 year of flying to 'recoop' the cost in burned out 300 motors (I was burning them out in 1 to 2 weeks of flying early last year . After 5 (or was it 6?) motors, I got to thinking this is stupid .... ). Plus the performance boost is nice as well..... That same motor is now in my son's Tantrum and still working like new...... Before that it was in his SB3D for about 130 flights before he got his Tantrum. I just bought another miniAC/16 setup a month or two ago to get my SB-3D back in the air which just turned over 500 flights.
Richard
Old Nov 11, 2003, 11:55 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
http://www.parkflyermotors.com/pfm.htm 650's for $1.25 a cell, or in a pack for $1.50...
Or Etec1200's for light weight... 2 or 3, up to you
Gene Bond is offline Find More Posts by Gene Bond
Old Nov 11, 2003, 12:22 PM
cadconversions is offline
Find More Posts by cadconversions
Around the World
cadconversions's Avatar
Scottsville, KY
Joined Jun 2002
Hobby Lobby sells the 1100 X-Cell NiMH's batteries. I've got two packs for my SB. I also use my 600AE. Both packs are 8 cells. I've also purchased two razor motors to put to good use...
cadconversions is offline Find More Posts by cadconversions
Old Nov 11, 2003, 03:43 PM
Beaver1 is offline
Find More Posts by Beaver1
North Platte, Nebraska, United States
Joined Jan 2003
Rod great looking plane, did you lesson the dihedreal (spelling) in the wing. Steve
Beaver1 is offline Find More Posts by Beaver1
Old Nov 11, 2003, 03:51 PM
Rod Hart is offline
Rod Hart's Avatar
Colorado Spring, CO
Joined Mar 2002
That is a prototype wing I got from Bill Stevens. It is just like the GT except it has tabulators on it but flies the same. I moved from Colorado Spring in June. I miss flying Doug's and Bill's prototypes.
Rod
Old Nov 11, 2003, 05:36 PM
cfossa is offline
cfossa's Avatar
Stow, MA
Joined Mar 2002
Richard
Richard,
Where did you get the miniAC/16 setup? If I'm going to go with the 650's, maybe I'd better plan on a new motor and ESC too
Thanks again,
Carl
Switchback battery GForceStress Parkflyers 1 Nov 03, 2002 08:41 AM
What other planes can the switchback battery packs be used for? butter_fingers Parkflyers 10 Jul 22, 2002 09:31 PM
GWS Tiger Moth battery recommendations popesle Batteries and Chargers 10 Jul 11, 2002 01:21 PM
Motor/Battery recommendations PLEASE. Chester_76 Electric Plane Talk 2 May 06, 2002 06:41 PM
