Old Jun 26, 2012, 08:47 PM
payne9999 is offline
Find More Posts by payne9999
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
Question
Making casts of vacuum formed parts?
I often damage the vac formed parts from kits and there is always some hanger rash or scrape from an ugly landing. So, I want to make castings of my vac formed parts so I can make new pieces if I screw up or if I just want to make parts from better raw material.
Can anyone give me some good advice about what materials will work best?
Plaster? Resins? which release agents are safe for the plastics? Any other advice....
Dave
payne9999 is offline Find More Posts by payne9999
Old Jun 26, 2012, 09:27 PM
Robert R is offline
Find More Posts by Robert R
It's a fine fiddly business.
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
Dave,
There is a really good and inexpensive book called Do it Yourself Vacuum Forming for the Hobbyist by Walsh. He has a chapter on that exact subject. He uses plaster of paris. http://www.build-stuff.com/001book_vacuum_forming.htm. It would be a well spent 13 dollars.
Did you get my PM on nacelle measurments you requested?
Best,
Robert
Robert R is offline Find More Posts by Robert R
Old Jun 26, 2012, 09:34 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Originally Posted by Robert R View Post
Dave,
Best,
Robert
Robert,
Yes I did and the Blue Wonder motors fit just great. Plenty of room for tolerances of the build.
Dave
Old Jun 26, 2012, 09:56 PM
Robert R is offline
Robert R's Avatar
Joined May 2009
Dave,
You are welcome, glad to help.
Robert
Old Jun 27, 2012, 05:45 AM
glewis is offline
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
I used to use plaster of paris but it's too soft. It works ok but is just not durable.
Switched to Durham's Rock Hard water putty. It's about the same as working with plaster of paris but cures to a much harder material with a very smooth surface. Durham's is available at the home improvement store.
Others swear by hydrocal but I have yet to try it.
Glenn
glewis is offline Find More Posts by glewis
Old Jun 27, 2012, 07:19 AM
FLYBOB54 is offline
Find More Posts by FLYBOB54
Closed Account
Joined Mar 2011
I second the vote for the Rockhard putty. The best thing I ever found was Diamondcrete but it's no longer available.
FLYBOB54 is offline Find More Posts by FLYBOB54
Old Jun 27, 2012, 10:11 AM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Fix-All has worked great for me. It is so hard you don't want to sand large amounts of it. Mix with water like any plaster. Best of all I don't seem to get air bubbles. We used to add a bit to drywall plasters to get them to set up faster so we could get repairs done real fast. I know it cures fast, and seems to dry out way faster than most plasters I have used.
No release agent used on plaster to plastic BTW. If you want to fiberglass over a plaster form then you need to seal and wax it, but that is a whole different subject.
Fred
Freddie B is offline Find More Posts by Freddie B
Old Jun 27, 2012, 02:04 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Glenn
This material sounds like the best choice for me. I found some at Home Depot.
What release agent do you use if any?
Dave
Old Jun 27, 2012, 03:09 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
No release agent used on plaster to plastic. Plastic will release the plaster with little massaging. Most molds to make plaster parts are thermal formed plastic.
Fred
Old Jun 27, 2012, 03:16 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Fred
Are you saying with Fixall or with Durhams Rock Hard?
Dave
Old Jun 27, 2012, 03:38 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Dave
Yes, most plaster is similar. It is a mix with water. Plaster of paris, Fix-All, Durhams Rock Hard, Drywll Gypsum Plaster, all seem to be similar is mix, dry, and such. The plaster is smooth and plastic is slippery. Even epoxy will peel easy from clear shinny plastic.
Try a small drop of plaster mix, on your 'mold' in a not critical area. You will see. It may pop off as soon as dry when yu pick it up!
Fred
Old Jun 27, 2012, 03:48 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Fred
Thanks Fred.
Well, I went ahead a did one set. Mixed it a little thicker than heavy cream.
So, How long does it take to set? Dang, I am curious now to see how good they might come out...
Dave
Old Jun 27, 2012, 04:41 PM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
A bit late,,, but..
I spray the inside of the part with silicone spray. I feel better having some kind of mold release. Note: don't use any kind of oil, the plaster will never set up. Guess how I know.... Support the part somehow. I use globs of clay stuck on.
Heavy cream is good. You want it thin enough to pour. I like to overfill as much as possible, gives some room to sand the bottom nice and flat.
Next, tap the part to make the bubbles rise. You want to really vibrate it good to get as many bubbles out as possible.
You will notice the color changes some and it will start to pull away around the edges. Usually takes a few hours to be dry enough to pop out of the mold.
It takes a good while to set up completely. The outside will be hard but it will still have a chewy center.... You will notice the part will feel cold indicating the damp insides. On thick parts it will take a week to fully dry out. Don't try to use it until it dries fully.
Glenn
Old Jun 27, 2012, 04:48 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
A bit late,,, but..
Glenn
Glen,
I sunk the plastic parts into some sand. Then I just poured the material in and left them. They are firm now but maybe a little soft. I did tap the box for a while and a lot of bubbles did come to the surface.
Dave
Old Jun 27, 2012, 04:49 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Great advice Glenn, and it was worth mentioning it. A slow bake well onder 170 degree F, will help dry out the parts, but I never do that untill a day or 2 went by first.
I don't use silicone spray. If you ever need to paint the original part used for a mold, or something you vac-form, if any silicone is left at all, the paint won't stick. I don't think you can ever gett all the silicone off anything.
Fred
Mini-HowTo Thermal forming, Vacuum forming methods & devices. Freddie B Foamies (Scratchbuilt) 81 May 20, 2013 11:35 PM
Discussion Making vacuum formed body shells Aussie Mick Car Talk 3 Jun 20, 2011 11:07 PM
Cool Someone with some vacuum forming skills needs to make this... Akura2 Motorcycles 6 Apr 18, 2011 06:44 PM
Mini-HowTo make a vacuum forming oven from a two-burner hot plate and disposable aluminum pans drcrash The Builders Workshop 16 Jan 07, 2010 03:09 AM
Making a Vacuum Forming Plug MetroGTi The Builders Workshop 31 Jul 18, 2005 10:50 PM
