Old Jun 26, 2012, 08:23 PM
ooby is offline
Find More Posts by ooby
ooby's Avatar
Joined Jan 2006
Build Log
1:8 scale, Maritime 34', 51" LOA, 20" beam
Sometime ago, I committed to providing constructions details of this scratch built project. They will be in the following sequence:
Boat
Plug
Mold
Part
Build
Sea Trials
The Boat
The 32' version of this boat was fished in Bristol Bay, Alaska. It was powered by a 600hp Lugger, 4-blade 30 x 26 prop, which resulted in a top speed of 21 kts. Fishing weight probably added 750 lbs of net, and 1,800 lbs of crew and provisions, which slowed the boat to a top speed of 17 - 18 knots, with an all-day cruise of 15 - 16 its. At sea trials, it displaced 19,600 lbs. (tare weight plus 100 gallons of fuel. (425 gal capacity). If memory serves, immersion rate was about 1,760 lbs/inch. The actual fish hold was about 300 cu ft, holding 50 lbs of Salmon per cu ft in deck brailers. Largest single delivery was 23,000+ lbs.
This model was built from real boat plans of the 34ft version (not Bristol Bay legal due to length), resulting in 51" x 20".
Electric twin motor unit is MACK Prooducts #2540 (600 size@) with 4:1 gear.
ESC is Astro Flight Reversing, Model 208D, with BEC.
Batteries are two 7.2V, 5,000 mAh, wired in series, fused at 20A.
Prop is Raboesch 3", 4-blade, #177-25.
Shaft is s/s 3/16" with oil lite bearings.
Rudder servo is Hitec HS-985MG, with dual ball bearings and metal gears.
Radio is JR
Paint:
Rust-Oleum, Satin, Midnight Blue
Rust-Oleum, Semi-Gloss, White
Rust-Oleum, Satin, American Accents Stone Grey
Decals:
"Light Navy" color
ooby is offline Find More Posts by ooby
Old Jun 26, 2012, 08:29 PM
ooby is offline
ooby's Avatar
Joined Jan 2006
The Plug
The "Plug" was built from Baltic Birch Plywood, 1/2" keel, 1/4" bulkheads, and 1/8" Basswood planks.
Old Jun 26, 2012, 08:33 PM
ooby is offline
ooby's Avatar
Joined Jan 2006
Mold
Original idea was to make a mold so we could have a total of 4 hulls, however, so far, this is the only "part".
Old Jun 26, 2012, 08:35 PM
ooby is offline
ooby's Avatar
Joined Jan 2006
Part
Overall, it worked out very well, though a little rough inside.
Old Jun 26, 2012, 08:41 PM
ooby is offline
ooby's Avatar
Joined Jan 2006
Build
Working from real boat plans leaves many questions unanswered, particularly "how to", e.g., attaching forward deck to the sheer.
Old Jun 26, 2012, 08:43 PM
ooby is offline
ooby's Avatar
Joined Jan 2006
Sea Trials
The main modification during sea trials was changing the gear from 3:1 to 4:1. Performance stayed about the same with motors running cooler.
Old Jun 26, 2012, 08:51 PM
ooby is offline
ooby's Avatar
Joined Jan 2006
Many details are left, primarily the hydraulic deck gear:
Anchor winch
Drum
Level wind
Power roller
Old Jun 26, 2012, 09:07 PM
gpzy is online now
Find More Posts by gpzy
FROM THE MIND OF A MADMAN
gpzy's Avatar
Joined Apr 2007
Great looking boat !!!!
gpzy is online now Find More Posts by gpzy
Old Jun 26, 2012, 09:47 PM
Gravman is offline
Find More Posts by Gravman
United States, TX, La Porte
Joined Apr 2007
Very nice, you have done some fine work. Very skilled.
Gravman is offline Find More Posts by Gravman
Old Jun 26, 2012, 09:52 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
I like it. You don't realize just how big it is until you see the batteries and motors swallowed up in that hull.
green-boat is offline Find More Posts by green-boat
Old Jun 26, 2012, 10:05 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Good looking boat! I'm amazed that behemoth actually moves with those seemingly puny 550 motors!
Kmot is offline Find More Posts by Kmot
Old Jun 26, 2012, 10:22 PM
jerryj98501 is online now
Find More Posts by jerryj98501
Olympia WA
Joined Nov 2004
OOBY Thanks for posting the build photos of your new boat. I was able to see the plug in the finishing stages and knew this was going to be another great build. It looks great in the water, let us know how the mechanical gear is coming along also as you progress. I have been busy helping my friends with their ON30 model RR, preparing for the narrow gauge nationals this fall in Bellevue. When you are in Olympia again and would like to visit it, I can arrange that as I know you had some interest in O scale, I think. Keep up the great work. jerryj98501 in Olympia
jerryj98501 is online now Find More Posts by jerryj98501
frankg is offline
Find More Posts by frankg
Joined Dec 2004
ooby- Really nice job on the model. She looks like she can get up and go pretty good by the pictures.
I have a question? Do you think that you could have raised the bulwarks on the forward deck of the plug before making the split mold. That way you could have framed for the front deck right at the top of the fiberglass hull. Any way you look at it the model is going to be great.
frankg is offline Find More Posts by frankg
Old Jun 26, 2012, 11:06 PM
ooby is offline
ooby's Avatar
Joined Jan 2006
Originally Posted by frankg View Post
ooby-
It was considered. For somebody more experienced, as this was our first one, the answer is likely, "Yes". My brother and I opted not to, simply because we didn't want any problems removing the part. Interesting to hear from the pros on this site to learn what they would have done.
Old Jun 26, 2012, 11:47 PM
ooby is offline
ooby's Avatar
Joined Jan 2006
Gpzy, I'm glad you do. I think that this boat's lines are aesthetically pleasing when compared to most Bristol Bay boats, which are made from aluminum.
Discussion 1/8 scale Mako 20 Center Console mitchlandry Scale Boats 561 May 24, 2016 05:49 PM
Build Log 1/8 scale F-20 TIGERSHARK 2600W 90mm corsair nut Foamy EDFs 77 Nov 10, 2009 02:39 AM
Found OS 1.20 or a Saito 1.20 for my T-34 tigermike Aircraft - Fuel - Engines and Accessories (FS/W) 3 Mar 15, 2009 02:18 PM
Question best foam p-51 1/8 scale jbaumshelter Scale Kit/Scratch Built 2 Aug 10, 2007 09:10 AM
