Old Jul 29, 2012, 06:50 PM
flyracer is offline
Find More Posts by flyracer
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
Saturday morning was another AMAZING flying sessions out at Superstition Airpark... got to meet Seth who I let fly my 30% Extra260... I got to fly my buddy Jay's new 24% Extra330 and I rang the snot out of der 30cc Slipstream Yak55m....
I'm convinced the Yak is tail heavy... she bobs a but while inverted. I went ahead and spent some time moving receiver batteries forward of the wing tube (instead of behind).
sorry no video everyone was busy getting their fly time in.....
Flyracer
flyracer is offline Find More Posts by flyracer
Old Jul 30, 2012, 12:07 PM
bdboy007 is offline
Find More Posts by bdboy007
bdboy007's Avatar
United States, OH, Loveland
Joined Jun 2004
I hear you I too flew the Sbach like crazy yesterday was at the field from 8am till 6pm sbach is flying great and unfortunatly had prop strike when the gear flexed that cracked one blade I am almost 1 gallon of fuel in the dle30 and I swear it is getting alot more powerful, I am running 32:1 stihl ultra and a switched out the dle plug for a ngk gapped at .024, still no progress on the mxs yet trying to sell off a few of my glow planes so I can start it then who knows maybe the yak that I meant to get instead of the mxs lol
bdboy007 is offline Find More Posts by bdboy007
Old Aug 06, 2012, 02:57 PM
bdboy007 is offline
bdboy007's Avatar
Joined Jun 2004
Started my mxs last night and the gear is different then the sbach, did you compare your yak gear to the sbach? Them mxs gear looks like it will hold up better
Old Aug 06, 2012, 08:44 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
the gear on the sBach and Yak are the same..... almost like butter!
Old Aug 06, 2012, 09:23 PM
bdboy007 is offline
bdboy007's Avatar
Joined Jun 2004
same dimensions width etc?
Old Aug 06, 2012, 09:30 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
yup.... Its the same gear.
Old Aug 06, 2012, 09:32 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
working on repositioning the receiver batteries and switched over to a 3 blade CF prop and spinner tonight... can't wait to try this in the air! I tested the on ground thrust in the driveway this evening... the sound at full throttle is significantly quieter than the 2 blade wood prop!
Flyracer
Old Aug 06, 2012, 10:33 PM
bdboy007 is offline
bdboy007's Avatar
Joined Jun 2004
i thought about going to a 3 blade prop what size should I get to replace a 18x8 2 blade?
Old Aug 06, 2012, 11:39 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
I checked the TroyBuiltModels website and they recommend either a 16x10 or a 17x10 prop for 30cc to 35cc engines... I went to the larger of the two plus the matching spinner...
I will need to bust out the RPM gauge and see what the 3 blade prop is generating at full throttle. As I mentioned in my earlier post, I tested the setup in the drive way and the "feel" with my hand holding the airframe by the rudder was good... it seems to be making close to the same thrust as the 18x8 if not slightly more at full throttle.
Old Aug 06, 2012, 11:40 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
the whole setup not only sounds quieter it revs smoother from idle up to full throttle...
Old Aug 08, 2012, 06:14 PM
bdboy007 is offline
bdboy007's Avatar
Joined Jun 2004
Ok the instructions are worthless which direction do I mount the gear on this mxs one direction looks straight when mounted and turned around looks raked forward a little
Old Aug 08, 2012, 08:55 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
I personally like it if the LG is raked forward slightly... the sweep is usually not more than a degree or two so it really shouldn't matter.
Old Sep 13, 2012, 06:03 AM
v1nn1e is offline
Find More Posts by v1nn1e
Joined Jun 2008
I am considering either the MXS or Yak 55 Slipstream, over here in the UK.
So, apart from the undercarriage, what is the rest of the hardware like on this kit? Do you need to replace horns/linkages etc?
I'll be electrifying mine.
v1nn1e is offline Find More Posts by v1nn1e
Old Sep 13, 2012, 06:26 PM
bdboy007 is offline
bdboy007's Avatar
Joined Jun 2004
yes the stock gear is junk replace all the soft phillips head screws with good dubro stuff, also didnt use the stock control horns they looked like they would rip right through the control surface
Old Sep 13, 2012, 07:10 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
I did dubro pin hinges instead of the CA hinges... mostly because I like the free movement and full deflection of pin hinges.... like Bdboy says, the landing gear is like butter! you will want to replace that for sure... any load bearing screws need to be replaced with quality hardware. I used the stock control rod hardware and have "tested" this repeatedly with aggressive flying without any failures.
Sold Slipstream 30cc Sbach DLE 30 $600 LPU only bdboy007 Aircraft - Fuel - Airplanes (FS/W) 12 Jun 12, 2012 11:39 PM
Build Log New Slipstream aircraft. The MXS 30cc and the SBACH 342 30cc cryhavoc38 Glow to Electric Conversions 12 Feb 06, 2012 09:52 PM
Sold Goldwing rc Yak55M 30cc version 3 ibcinyourc.com Aircraft - Fuel - Airplanes (FS/W) 0 Aug 03, 2011 12:32 PM
Discussion Goldwing 30cc Yak55M/V3 Hunkus Glow to Electric Conversions 3 Feb 21, 2011 09:38 AM
