Old Jun 26, 2012, 08:22 PM
flyracer is offline
Find More Posts by flyracer
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
Slipstream 30cc Yak55M
I got a Slipstream 30cc Yak55M for Father's Day.... she's pretty close to being ready for the maiden. Hopefully the week of July 4th.
Here's a few pictures... one with all the parts dry fitted and the other with the DLE30 mounted and the engine cowling cut.
This is my 2nd Slipstream airframe... my 1st was the sBach342 (green/white color scheme). The Yak55m kit came with a new version tail wheel assembly and the firewall/engine cowling distance was preset for a DLE30 V2.. which made for a perfect bolt on of the engine.
Anyone else got this Yak55m?
Flyracer
flyracer is offline Find More Posts by flyracer
Old Jun 27, 2012, 08:51 AM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
I just seen one in Texas.
He didn't put her through her paces though just mainly few her around.
kerwin50 is offline Find More Posts by kerwin50
Old Jun 27, 2012, 10:18 AM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
some encouraging vidoes...
Slipstream Yak55m Russian Thunder (0 min 16 sec)
Aztech Aeromodels 30cc Slipstream Yak 55M - Do Svadanyia (6 min 8 sec)
Flyracer
Old Jun 28, 2012, 12:09 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Ok Fly your going to have to give us a build/flight report
Old Jun 28, 2012, 12:54 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
well I've already built her! I upgraded the CA hinges to Robart Pin Hinges cause I like the smoother movement and full deflection. I think I've got at least 50 degrees on all surfaces.
I'm down to installing the control arm/bolts and setting the rates.... and setting up the pull pull rudder. I found a great deal on aluminum control arms (for the HS645MG servos) on HK USA warehouse website! $4.50 each for the 2" long control arms. I did have to tap them out for the larger retaining screws but still a scammer deal IMHO
I hope to maiden her next week.
Old Jul 05, 2012, 07:12 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
Missed my opportunity on Tuesday this week for the maiden flight. Shooting for this coming Saturday if the weather holds out.
Flyracer
Old Jul 07, 2012, 04:10 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Hope all goes well
Old Jul 07, 2012, 08:01 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
Here's the report.... I put two flights on the Slipstream 30cc Yak55M this morning... the used DLE30 (bought it from Rich B at an amazing price) performed flawlessly and had plenty of power to haul this setup around. The AUW with a full tank of gas is 10lbs 12oz.
1st flight of 8 mins long was to get the control surfaces dialed in. It took some right aileron trim and two ticks of down elevator to get straight and level flight patterns. Tested the stall point up high and she dropped her right wing predictably. Did about 1/2 dozen touch n goes to get a feel for the proper landing speed. I checked the fuel level after flight 1 and there was still 1/2 a tank left in the 12oz can.
2nd flight I took the timer up to 10 mins and flipped her to high rates (full deflection on all surfaces 45 degrees or better, 80% expo on ailerons and elevator and 60% expo on the rudder).
Excellent characteristics in full on harriers.. she floats predictably and only had a slight wing rock. Rolling harriers almost do the full circle by themselves with just elevator input during the roll. She did have a slight tendency to pull to the LG during Knife Edge flight. Excellent flat spins...
IMAC/Pattern type flying... easy to control humpy bumps, slit S, half cuban 8's, loops and inverted flight.
Now the bad part... the land gear is WAY to soft... on the 2nd flight I had a small bounce that squatted the landing gear enough to allow the prop tip to strike...I'm using an 18x8 Xoar... the prop was toast and I hadn't packed my spares... the flying for the Yak was done for the day.
I'll be looking at TNT's website for a compatable aluminum replacement for the stock landing gear.
Flyracer
Old Jul 08, 2012, 06:55 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Thanks for the report
Old Jul 09, 2012, 09:39 PM
bdboy007 is offline
Find More Posts by bdboy007
bdboy007's Avatar
United States, OH, Loveland
Joined Jun 2004
Hey fly I know what you mean about the gear I have the Sbach and the gear is very soft let me know what you find because I am eyeing this model and might pick it up in the next few days, also the dle is a perfect fit? I hate to cut another motor box.
Subscribed
bdboy007 is offline Find More Posts by bdboy007
Old Jul 09, 2012, 10:03 PM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
BDBoy
Here's the two options I'm looking at.
The Aluminum Yak-54 73" WS 8" tall PN: LG27-1747 for $49.00 from
http://www.tntlandinggear.com
Or the GraphTechRC CF landing gear for the Slipstream 30cc Sbach 342 is $47 http://www.graphtechrcshop.com/produ...&categoryId=34
I'd recently put TNT Aluminum LG on my 30% Pilot RC Extra 260 (replacing the frail CF gear) and I love it. I'll probably go with the TNT gear for the Yak.
Flyracer
Old Jul 09, 2012, 11:34 PM
bdboy007 is offline
bdboy007's Avatar
Joined Jun 2004
did you see the goldwing yak 55m gear? acording to the specs they use the same specs and grade aluminum in their gear
Old Jul 09, 2012, 11:39 PM
bdboy007 is offline
bdboy007's Avatar
Joined Jun 2004
I just noticed your Yak has the same looking gear as my Sbach not the bowed gear you normally see on Yaks
Old Jul 10, 2012, 12:09 AM
flyracer is offline
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
yes, you are correct, I think the Yak and sBach from Slipstream use the same landing gear.
Old Jul 10, 2012, 03:07 PM
bdboy007 is offline
bdboy007's Avatar
Joined Jun 2004
I went to the shop today and ended up getting the mxs the red white and blue yak was just not attractive orientation would of been hard since top and bottom are the same the bright green just stood out so looks like I will be modifying another motor box, and wait for another scheme yak
Sold Slipstream 30cc Sbach DLE 30 $600 LPU only bdboy007 Aircraft - Fuel - Airplanes (FS/W) 12 Jun 12, 2012 11:39 PM
Build Log New Slipstream aircraft. The MXS 30cc and the SBACH 342 30cc cryhavoc38 Glow to Electric Conversions 12 Feb 06, 2012 09:52 PM
Sold Goldwing rc Yak55M 30cc version 3 ibcinyourc.com Aircraft - Fuel - Airplanes (FS/W) 0 Aug 03, 2011 12:32 PM
Discussion Goldwing 30cc Yak55M/V3 Hunkus Glow to Electric Conversions 3 Feb 21, 2011 09:38 AM
