I have a strong hunch the Joysway boat I bought is a brushless upgraded version of the Offshore Warrior Lite:
http://www.rcgroups.com/forums/showthread.php?t=1663518 Look at the pictures inside and see if it looks familiar. My flexshaft, which is probably the same as yours wasn't going to last much longer so I replaced it (also in the thread above). It's not hard to do and most of the tubing can be found at Ace Hardware. I bought the rest of my stuff at OSE: http://www.offshoreelectrics.com/ You can get stock drop in replacements, or upgrade in size like I did, but be careful to make sure your motor can handle the extra load. Had my prop stub not been made of cheap metal I would have stuck with the existing setup with the small brass tube acting to convert the system to a straight shaft. |
Latest blog entry: Making a Super Sized Frankenquad
Sorry I created another thread about it and forgot to link it:
http://www.rcgroups.com/forums/showthread.php?t=1674652 I created my own larger stuffing tube from 7/32" brass tube. Inside of that I used 3\16" brass tube as a liner and to take up slack so my new flexshaft wouldn't whip around. The flexhaft I used was Octura .130. The new propshaft I used was an Octura with a 3\16" stub with a step down to use my existing 1\8" props: http://www.offshoreelectrics.com/pro...od=oct-oc64pkg The 3/16" stub fits nice and snug in my new stuffing tube. I initially got a new compression collette, but it was too heavy so I drilled out my existing grub-screw collette for the new flexshaft. |
Original prop should fit, it's why I went with that particular propshaft. How does the inside of the Warrior look compared to my Super Mono X? Look like the same hull?
That's actually too light. This is what I'm using:
http://www.agscompany.com/lubricants/automotive/160 It flows nicely not creating friction and stays on the parts creating a nice clingly film. WIth the tight tolerances of the stub shaft in the stuffing tube I have no problems with water trying to enter. There's also Grim Racer Speed grease, which I haven't tried myself simply because it's not readily availble in local stores. |
No worries Ollie. Joysway parts are easy to find in your neck fo the woods.......kind of makes me jealous. Did your Warrior Lite come with a lexan hatch cover that goes on before the main cowl?
Rhodes island Greece
Joined Jul 2003
Comparing the two boats
Guys, I don't know if you still follow the thread but here's my two cents:
I originally bought the Warrior Lite and the problems I had was with the brushes of the motor mostly. Right now I am looking for replacement brushes. Meanwhile, I was thinking to get rid of the brushes all together and upgrade to a brushless setup. I saw your link with the photos and all and I supposed I could fit the exact Super Mono setup to Warrior lite hull. So I called my supplier, I asked for the ESC and the motor and he told me he doesn't have in stock BUT he has a Super Mono X without shaft that he can give me for the price of ESC and motor!! So, that's what i did... Now I have both models on my desk. I tried to fit the flex shaft from Lite to Mono but it's too short!! The brushless motor sits more in front than the brushed one and the hull **suprise** is not exactly the same! The bases for the motor are in different place so you can't just exchange motors between the two models! So, right now, I am still trying to fit new brushes to the Lite one and waiting for replacement shafts to arrive from China (www.banggood.com)... |
Can you show us some side-by-side pictures? Other than the motor mounts, do the hulls look the same?
| Thread Tools | |
| Discussion offshore warrior motor choices | ashcossie | Racing Boats - Electric | 3 | May 03, 2012 02:45 AM |
| Question joysway offshore warrior | dan1987 | Dock Talk | 1 | Jul 16, 2011 04:35 PM |
| Yippee! My New Joysway Offshore Warrior and how to use a Condom on your boat | RChelisrule | Racing Boats - Electric | 22 | Jun 18, 2011 12:08 AM |
| Question b2445 water cooled brushless motor offshore warrior | dan1987 | Racing Boats - Electric | 2 | May 11, 2011 06:06 AM |
