Old Aug 22, 2012, 12:21 AM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
Originally Posted by Toysrme View Post
i think the entire premis of this post is newbie and boarderline moronic.
it was put to death june 26. why is there still discussion on it?
You find weevils in your cheerios this morning or something?
seeingeyegod is offline Find More Posts by seeingeyegod
Old Aug 22, 2012, 04:27 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Yet you still had to have a look to see what was posted, and even posted yourself.
Welcome to the club for the 'boarderline moronic'. We need a President, fancy the job ?.
eflightray is offline Find More Posts by eflightray
Old Aug 23, 2012, 10:14 PM
bjr_93tz is offline
Find More Posts by bjr_93tz
Toowoomba, QLD, AUSTRALIA
Originally Posted by CNY_Dave View Post
What's funny is I've been having this discussion with fairly senior people and experienced pilots, context is aircraft separation assurance maneuvers and collision avoidance maneuvers.
"If 2 planes are approaching at right angles and one is downwind and the other turns away from the downwind plane because of the wind the downwind plane is approaching faster until the turning plane can speed up'.
Shoot me, shoot me, shoot me.
This is the best part about education and training. As you move up each level you realise that what you were taught wasn't exactly true but it was close enough to the truth to keep you out of trouble.
Sticking a metal tool into either or both of the correct 2 of the 3 holes in an electrical outlet is perfectly safe even if it's switched on but you'd certainly never try to teach that to a child, just as the level of aerodynamic principles taught to pilots is enough to allow them to operate their craft safely even if some of the info is a bit dodgey and not always 100% correct.
As an Electrical Engineer I apply the simpliest level of electrical principles I can that adequately describe the systems I'm working on, even though I know full well that that's not what's REALLY going on.
bjr_93tz is offline Find More Posts by bjr_93tz
Old Aug 24, 2012, 10:21 AM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
That is a very interesting perspective, and it does apply to the downwind turn phenomenon. There have been a few times in my life when people have asked me how a transistor works. I usually explain how a triode tube works instead, because the concepts of particles moving through space and valves are easier for laymen to understand. Then I tell them that the transistor uses a very different method to achieve a similar effect.
The title of this thread should really be called "How to land a plane in windy and gusty conditions", but it's all working out anyway. There have been several people who have submitted some well thought-out strategies complete with do's and don'ts. Couldn't have hoped for more.
Jovanx is offline Find More Posts by Jovanx
Old Aug 24, 2012, 11:32 AM
sablatnic is online now
Find More Posts by sablatnic
Joined Oct 2010
Originally Posted by Jovanx View Post
Well, it sorta makes sense as long as "faster" and "slower" are referring to ground speed and not air speed. The statement as quoted is a little confusing because of the grammar, but I think I know what you mean.
Nobody ever has a problem with a downwind turn at 9000 feet. It's when we are close to the ground and thinking about landing that the phenomenon occurs. I am assuming that the word "approaching" means they are working on their landing strategy.
What many people think of as 'the dreaded down wind turn' is in fact a quite different phenomenon, 'ground affect'.
sablatnic is online now Find More Posts by sablatnic
Old Aug 24, 2012, 12:40 PM
Jovanx is offline
Joined Nov 2011
Ground effect is a completely different phenomenon and it occurs whether the wind is blowing or not. When a plane is only a few feet off the ground, the air being pushed down by the underside of the wing creates a "cushion" of air that pushes back up against the wing, increasing the lift. That is why birds like to cruise along so close to the surface of the water. It's a free ride.
The downwind turn is a phenomenon that occurs at an altitude that is too high for the ground effect. It is usually when the pilot is making his second-last turn before landing, and he is planning on the last turn bringing him back around into the wind for the landing.
The ground does have an effect on wind, creating turbulence that can be a problem for pilots, but that is not what is meant by the term "ground effect".
Old Aug 24, 2012, 09:52 PM
Fox-composites is offline
Find More Posts by Fox-composites
Thailand
Joined Aug 2010
Flying upwind or downwind is the same for the model but the pilot perceives the speed differently. It looks like it's flying faster on the downwind leg but it's only the ground speed that is higher.
As model pilots we force the aircraft into a circuit that is relative to the ground and there seems to be a difference between up and downwind flight.
If you have ever watched a free flight model doing circuits and flying off downwind then you will notice the non circular flight pattern but yet the model thinks it just flying in circles.
Fox-composites is offline Find More Posts by Fox-composites
Old Aug 24, 2012, 10:34 PM
The model does experience different aerodynamic effects depending on whether or not its flying in a tail wind or head wind, just like a real plane. A tail wind can both make a plane move faster relative to the ground, and reduce lift. A full scale pilot can also tell he/she is moving slower relative to the ground facing a head wind than in a tail wind, both by looking outside, and watching ground speed on the GPS.
"downwind turn" is usually with a tail wind, because runways designated for landing (full scale) are always into the wind because it is much easier to land into a head wind than a tail wind. That said, even if there is 0 wind it is still called a downwind turn as long as you are headed parallel to the runway in the opposite direction as you are intending to land.
Old Aug 25, 2012, 09:35 AM
AeroKen is offline
Find More Posts by AeroKen
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
Assuming the same airspeed (which presumably you are based on the "faster relative to the ground" part) there is no difference in lift regardless of the planes orientation relative to the wind. See previous posts in this thread.
AeroKen is offline Find More Posts by AeroKen
Old Aug 25, 2012, 02:38 PM
Exactly, the air speed is NOT the same if you get a sudden tailwind. The air flow relative to the wings can suddenly slow down, reducing lift.
Old Aug 25, 2012, 07:15 PM
cfircav8r is offline
Find More Posts by cfircav8r
You can't take the sky from me
cfircav8r's Avatar
United States, IA, Hampton
Joined May 2012
First base!
cfircav8r is offline Find More Posts by cfircav8r
Old Aug 25, 2012, 07:35 PM
Chophop is offline
Find More Posts by Chophop
Turn that thing around...naaaa
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
So turning downwind is making some pilots feel like they are stepping out on a glass bottom catwalk that is up 100 stories. It ain't that bad if you just carry a bit of extra airspeed for that one turn and if low, keep the power up. It's a mainly worthless worry.
Chophop is offline Find More Posts by Chophop
Old Aug 25, 2012, 08:52 PM
cfircav8r's Avatar
Joined May 2012
Why do you need extra airspeed and power?
Old Aug 26, 2012, 04:35 AM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
To have enough inertia to carry ther airplane through abnormal atmospheric deviations.
Old Aug 26, 2012, 07:28 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Where does the 'sudden tail wind' come from ?, or do you mean turbulence and gusting.
If a model is flying at say 30mph air speed, (actually that's quite slow), and the air 'suddenly increases' from any direction, it will not greater affect that 30mph air speed. Not unless you are talking about a hurricane.
People here keep relating everything to 'downwind'. There is basically no such thing as 'downwind' to the plane, only to the person standing still who perceives a difference by relating it to ground speed.
Remember that the plane is in a block of air and is moving forwards through it at its flying speed, exactly the same as on a calm day. The only thing that can affect it is turbulence and gusting, which can happen in any situation, even during the in to wind landing.
Now if there was a sudden outbreak of FPV fliers who keep crashing during the turns on the landing leg, now that would make an interesting thread.
Astro Flight 109 Facts or Fiction. everydayflyer Batteries and Chargers 12 Jan 22, 2005 11:27 AM
Stock: Fact or Fiction..... Geoffrey109 Micro Helis 0 Nov 26, 2004 09:26 PM
Razor Fact Or Fiction? mike3976 Power Systems 9 Oct 26, 2003 05:12 PM
LI-PO Fact or Fiction? gbruce Electric Ducted Fan Jet Talk 4 Oct 24, 2002 01:48 PM
Kyosho F16, Fact or Fiction? Stuart Warne Electric Ducted Fan Jet Talk 20 May 31, 2002 12:49 AM
