Old Jun 25, 2012, 09:57 PM
Props is offline
Find More Posts by Props
pilot
Props's Avatar
United States, AZ, Prescott
Joined May 2011
How to transfer lines on plans to Balsa for cutting?
STARTING TO SCRATCH BUILD!! How do you guys transfer the shapes and lines on the plans to the wood for sawing and shaping?
Also, can someone recommend an excellent band saw for RC airplane building?
Thanks in advance for your help.
Kevin
Props is offline Find More Posts by Props
Old Sep 29, 2012, 06:33 PM
335driver is offline
Find More Posts by 335driver
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Sometimes plans come with a template sheet that you can cut out and a mist of contact cement on the wood and paste the template down and cut away. No templates, go to copy store and make a copy of the plans to cut up. You can trace the parts on tracing paper and use carbon paper. You can also carefully use carbon paper and trace the part onto the wood. Several ways to do it. I even used a dress pattern wheel, and traced the parts on to the wood. With this method you get a series of pin holes in the wood that you can connect with a soft pencil.
335driver is offline Find More Posts by 335driver
Old Sep 30, 2012, 05:31 PM
jjkupinski is offline
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
Another method is to make a laser copier copy of the parts you need. Then take them face down on the balsa and use an iron on its highest heat to transfer it. Laser ink is basically carbon with a heat activated binder.
jjkupinski is offline Find More Posts by jjkupinski
Old Nov 19, 2012, 10:09 PM
swilson is offline
Find More Posts by swilson
Flying W Models CustomBuilders
Princeton Indiana
Joined Apr 2009
Two words SEE TEMP Its a think platic film you lay over your plans, trace on to the see temp and then cut out your pattern. Scratchs builders have been using it for years!!!
Check with
Dynamic Balsa & Hobby Supply
PO Box 107
Leonore, IL 61332
swilson is offline Find More Posts by swilson
Discussion how to transfer paper plan on foam Almaz Foamies (Scratchbuilt) 18 Apr 17, 2008 11:00 AM
Discussion On Line Plans For Genie Line Of Thermal Ships harleym Thermal 31 Nov 23, 2007 12:46 PM
Building parkflyers from plans: How to transfer plans to wood? War Bird Radio Parkflyers 13 Jun 20, 2003 09:58 PM
Transfer of plan lines to balsa...help! JonB The Builders Workshop 12 Dec 13, 2002 01:28 PM
transfering plans to Balsa Da Flying Man Electric Plane Talk 5 Nov 30, 2002 09:16 PM
