Nov 09, 2012, 05:46 AM
Australia, QLD, Woody Point
Joined Nov 2006
Josh, I "covered that" in my enormous long post on the previous page - haha! I write so much stuff it's overload and people can't take it all in!
No I don't use any splooge. Basically, as long as the bag is big enough, and doesn't have any leaks itself, it won't leak at all if there are no gaps for it to have an aneurysm and blow/pop into the gap. Splooge can just get pushed thru a small gap easier than the plastic bag, so it won't prevent the pop. But any amount of cloth overlap covering every bit of the mould join will completely prevent any popping. A common place to pop is the nose tip because it's hard to get the overlap right there. So I cut a circle of floppy satin cloth and wrap it over the tip of the bladder, like a small parachute, so that as you inflate it, it pushes the cloth into the nose tip and seals off any gaps.
Adam (Wyowindworks) has moulds that are so absolutely perfect and tight sealing, that he can pump up to 60psi. I've gone up to 30 but generally it's overkill.
At the end when putting the bladder in, If I have some epoxy going sticky, I'll dab it here and there on the bladder to help tack it down to itself while I join the mould.
When you say layups will be green by the time you close up ... keep persevering. I was like that but honestly even with my klutzy pfaffing absent minded old fart behaviour, I've got it quite fast now. The things that helped me most were working out a pattern of cloth pieces that fit together like a jigsaw in the mould (overlapping of course) then making good templates for them from thin MDF. It's not as easy as it sound and I'm onto Templates Mark 3 now. Do the mould release and do the cutting of all the cloth pieces, strips of tow etc, and lay them out in piles (top half and bottom half) and have every piece cut and ready before you start.
I cheat by laminating a layer of glass over a layer of Kevlar stuck together with a light misting of Super 77. I then treat it like one cloth. I use all the MDF templates to mark the shapes on the glass side with a pencil according to the pattern. Depending on the required weight/ strength, each shapes gets marked out one, two or three times. Some with overlap, some without. Then cut them out and set them out in piles ready to go.
Once you've done it with exactly the same shapes a few times you get quicker. I've been rather surprised how quickly I got the latest ones done. But the Scratcho doesn't have a fin built into the fuz ... that probably helps.
Oh, and remember just before you close the mould to have a look back where you had the cloth bits ready! More than once I've thought I was finished and closed up and there were bits still waiting ... !
