Old Sep 03, 2012, 08:34 PM
ALEX HEWSON is online now
Find More Posts by ALEX HEWSON
Remember... Fly for fun!
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
Nope. Cant say yet till I get it done. Just need thick enough material
ALEX HEWSON is online now Find More Posts by ALEX HEWSON
Old Sep 03, 2012, 09:11 PM
josh18 is online now
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
I think you're thinking wing Tim and Alex is thinking fuse maybe.
Alex its actually not that hard to make an epoxy mould of your fuse and you can make your wing really accurate with templates and use that as a plug too. Now I know some of the tricks that Tim and the other guys have shared with me its really not that hard at all and for your size plane might not even take as long as machining. My moulds are really simple and I dont even use a gell coat. I make sure I use pva, and so far have pulled 4 wings and maybe 8 fuses and had no damage to the moulds at all. Check out the Wabbit build thread if you want to see how accurate you can make a bagged wing plug. Otherwise you could machine positives into mdf and make epoxy moulds of them. I know this is what Tim and Sean have done- What do you reckon fellas?
josh18 is online now Find More Posts by josh18
Old Sep 03, 2012, 11:57 PM
Joined Jul 2005
Cheers Josh. Yep i am making the RT42 molds that way, but the RT30 is way too complicated to make a plug for.
I will get aluminium if I fail to get suitable resin type block
Old Sep 04, 2012, 01:17 PM
wdeighton is offline
Find More Posts by wdeighton
Where is the inspiration
wdeighton's Avatar
Moira
Joined Feb 2006
a mate of mine got plugs made for a 3mm model.
It still hasn't been made.
main reason is the amount of work to do finishing it off.
1. to get the finish
2. to get the wings straight
I am not saying it cant be done, I am just saying think hard, and speak to people that have done is successfully to learn the tips and techniques.
If I had cnc access I would take that over foam cutting any day.
For the smaller models cutting positives from MDF could be quite a good solution. But as said before, take off more than you want, then put a layer of glass on, and machine that back. then a layer or 2 of gel coat and do a final cut, polish and mould.
If you work in an engineering shop and can access big plates of steel, to use as backing plates, go for it. It will help the accuracy.
Start small. Maybe the fuz first, pull one out and then go for the wing. The learning you get between your first couple will be invaluable.
good Luck, I can wait to see these things available commercially.
William
wdeighton is offline Find More Posts by wdeighton
Old Sep 05, 2012, 02:20 AM
Joined Jul 2005
Well the RT42 does wicked Ninja stars!!!!!!!!!!! Better than the D60 or Scratcho! Got it on video too Did 156mph in rough air. Was not used to the site and air was too huge for it's light weight. If anyone saw my RT30 first DS lap on April 5th at Weldon, you will know what too light means in big air!
Old Sep 13, 2012, 07:41 PM
Joined Jul 2005
Stuff it, about time the world sees what I am trying to cut on the CNC
RT30 molds prior to TE trench and tail boom blending
Old Sep 13, 2012, 10:18 PM
timbuck is online now
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
Look cool. Great minds think alike..
timbuck is online now Find More Posts by timbuck
Latest blog entry: More colours
Old Sep 14, 2012, 04:45 AM
two stroke is online now
Find More Posts by two stroke
two stroke's Avatar
Slovenia, Kamnik
Joined Jan 2011
WOW,very nice Alex love the shape!
Regards Simon
two stroke is online now Find More Posts by two stroke
Old Sep 14, 2012, 05:59 PM
608 km/h!
josh18's Avatar
Joined Jan 2010
Nice Alex, looks slick as!
Old Sep 14, 2012, 06:34 PM
flyonline is online now
Find More Posts by flyonline
Twisted and Confused
flyonline's Avatar
Joined May 2003
It looks like a Ninja star
How will you fit the top of the fin in on top side? A 2pc seperate mold for the fin that will drop onto a lip/recess on the top half?
Steve
flyonline is online now Find More Posts by flyonline
Old Sep 15, 2012, 12:15 AM
Joined Jul 2005
Nothing too fancy. Probably just screw from underneath onto a flat on the top
Old Sep 19, 2012, 03:56 AM
Joined Jul 2005
Got the plugs done for the RT42 and parting boards cut out. Hopefully laying up molds tomorrow.
Old Oct 22, 2012, 03:30 AM
Joined Jul 2005
Well foamies have been ruling my building time recently, plus having to drive to the other side of town to do any work on the molds also puts a stop to much progress.
But they are almost done. Pics:
Old Oct 23, 2012, 01:54 AM
radacl69 is offline
Find More Posts by radacl69
New Zealand, Canterbury, Christchurch
Joined Mar 2012
Lookin Good Alex
radacl69 is offline Find More Posts by radacl69
Old Oct 23, 2012, 02:11 AM
Joined Jul 2005
All credit needs to go to Graham for his work on them. All i did was build him a Reaper make the plugs and wax them! He has done ALL the rest!
Discussion 10 in1 servo tester (professional servo tester) flydreamrc Radios 21 Jul 17, 2012 01:50 AM
Alert RT Models Beaver Pre-release build St. Martin Scale Kit/Scratch Built 86 Jun 29, 2008 04:01 PM
Build Log kin'Brilliant Build Pics (PU-RT) wdeighton Slope 30 Mar 18, 2008 02:38 AM
Discussion RT Models MIG-15 Build AeroDude Electric Ducted Fan Jet Talk 34 Mar 02, 2008 04:49 PM
Discussion RT Mig 15 Build nut Electric Ducted Fan Jet Talk 8 Jul 30, 2007 12:17 PM
