Old Jun 25, 2012, 08:03 PM
doughpat is offline
Find More Posts by doughpat
Indonesia, Special Capital Region of Jakarta, Jakarta
Joined May 2009
SPW w/ Omni vs. Omni w/ Omni
Hi guys,
While I wait for my cloverleaf/SPW setup to be repaired (the cloverleaf is broken), I am wondering what situation is better for now. I have a functioning skew planar wheel (thanks IBCrazy), and a couple of stock whip omnidirectional antennas.
Am I better off going with an omni on BOTH the Rx *and* the Tx, or should I leave the SPW on the Rx and just replace the cloverleaf with an omni? Or perhaps even switch them around--put the SPW on the quadcopter and the omni on the Rx?
I'm not planning on going too far--just got my OSD configured and want to tool around the field. Not sure if it makes any difference, but I'm using a 1.3 gHz 800mW vTx and a SAW-upgraded Rx.
Here is a picture of 4 omnidirectional antennas I have laying around. I'm not sure exactly where all of these came from, but they *should* all be 1.3 gHz, since that's the only frequency I've ever dealt with. If they are all the same performance-wise, then I'll go with the skinniest/lightest one. However, if the bigger guys will give me better signal, weight is not a major issue here.
Thanks for any tips-
Ryan
doughpat is offline Find More Posts by doughpat
Old Jun 26, 2012, 02:43 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Go with two omnis. Mixing is a recipe for disaster. The multipathing between a circular omni and a linear one is even worse than two linears.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jun 26, 2012, 11:12 PM
doughpat is offline
Joined May 2009
Roger that. Experimental evidence agreed with you Omni w/ SPW was terrible. Omni w/ Omni was better (still pretty lame though).
Old Jun 27, 2012, 12:27 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I fly with linear Vee on the plane and SPW on the Rx all the time out to a mile or two, without issue.
FPV - Chasing Jeff's warbird (7 min 6 sec)
Jump to 4:50 to see it out over a mile.
In this particular flight, the Vee itself was actually a bit mangled (had landed in a bush previously and
bent the ground plane) so this wasn't even its best.
Your results may vary.
ian
Daemon is offline Find More Posts by Daemon
Question SPW / Clover vs Turbine / Windmill Funky Diver FPV Talk 14 Jan 24, 2012 10:29 AM
For Sale 900 mHz Video Rx's w/3dbi omni and 8dbi patch Slaphappysamy FPV Equipment (FS/W) 10 Sep 17, 2011 03:13 PM
Discussion 100mw 5.8ghz and CP SPW/Cloverleaf. Need a little help w/ signal Matt Gunn FPV Talk 9 Sep 10, 2011 04:16 PM
Discussion Omni vs Patch vs Yagi vs Dish blade thrasher FPV Talk 2 Apr 05, 2009 11:17 AM
2.4GHz antenna comparison video- 5dbi omni vs. GP Patch maximal Aerial Photography 11 Mar 24, 2005 02:42 PM
