| Thread Tools |
| This thread is privately moderated by Vantasstic, who may elect to delete unwanted replies. |
I'd just remove the antenna if it comes with one installed. The antenna is worthless without the module so why leave it in place. It won't hurt anything...but maybe just get in the way. One of the links in post 1 covers how to remove the antenna from the 9X. If I had one with an antenna I'd pull it and throw it in the 'box-o-stuff'.
Latest blog entry: Transplanting a Spektrum Dx4E Rf Deck...
The one I linked is a 3 pole dual position On-Off-On switch. It is a 'locking switch' where the middle position sits in a detente with neither deck powered...this is what I used when using my DL. One position powered the DSM1 deck, the other position powered the DSM2 deck, the middle position didn't power either deck and my DL was plugged in to a separate port. You don't have to go fancy with this. A simple single pole dual throw switch is all you really need to power one deck or the other by just switching the power line.
Joined Mar 2010
http://www.radioshack.com/product/in...ductId=2102475 --- i got this double throw 2 pole switch. could you draw a wiring diagram for this? i know you explained it in the ealier post, but id like a picture too.
thank you very much for your help |
Before soldering things up, verify the connections on your switch. Do this with a multi-meter. Using either a continuity test (beeper) or ohm test, put one lead on each center pin and touch the other lead to each one of the end pins. You should get a beep or 0 ohms reading one only one of the pins. This will verify which pins are the 'common' (where you want to connect the wires from the Tx) and which pins are 'active' for the selected switch position. |
There could be several different possibilities of how to switch power to different rf decks. All will require some degree of surgery to intercept power from the boards and route it to different locations. From what I'm gathering of what you want to do, I'd just open up the 2.4G deck, find the power input trace, cut it, and add wires from the cut traces to the switch. This way the switch is on the rf deck vs in the radio. I'm not sure that's what you're looking to do though. |
Joined Jun 2012
Hi Vantasstic, your mod sounds very interesting to me. Did you do a range check? How many km did you reach?
I have a very first model of Turnigy 9X transmitter, that's 99% time out of stock, i've used it for nearly 2 years without any signal problem, just like you I love that TX. Which is your DL module version? |
The furthest I've flown on my 9X and Dragon Link V1 wa 10+km...no problems... I just got a DL V2, but haven't flown long range with the new system yet.
Joined Jun 2012
Hi Vantasstic,
Is this smarty board you're using? http://www.smartieparts.com/shop/ind...roducts_id=331 I see some seller's description about the error with 1st batch of boards he received from the factory. With dragon link installed, does it have any problem with multicopter? And the short-range is also good as the long-range. Thank you! |
I fly everything on my 9X and ER9X firmware...Spektrum DSM2, Dragon Link UHF, park fliers, multi-copters, long range FPV. It's served me well...hence I bought a backup should anything happen to the first one. The stock 2.4Ghz Rx is kind of big. I use the much smaller Spektrum/Orange receivers with the Spektrum DM9 (for JR) rf module. I wouldn't use 2.4G for any long range flights...you want a good UHF system for that. I'm using Dragon Link and have been to 6.5miles/10+km with no issues. |
| Thread Tools | |
| Help! Setup Dragon Link V2 System with Spektrum DX6i | boulderwapiti | Video Piloting (FPV/RPV) | 10 | Apr 17, 2013 09:11 PM |
| Discussion The unofficial dragon link thread without the tracking requests | LoneWolfRC | Video Piloting (FPV/RPV) | 20 | Jun 21, 2012 04:25 PM |
| Sold Dragon Link | sawman | Aircraft - General - Radio Equipment (FS/W) | 0 | Jun 18, 2012 07:27 PM |
| Sold New Dragon Link V2 Tx / Rx Combo | cbcalhoun | FPV/RPV - Equipment and Vehicles (FS/W) | 0 | Jun 17, 2012 10:36 AM |
| Help! NAZA with GPS +Dragon Link | markeydoo | Multirotor Talk | 1 | Jun 15, 2012 10:39 PM |
