Old Jun 25, 2012, 05:09 PM
duworm is offline
Find More Posts by duworm
Sherman Knight
Kirkland Washington
Joined Feb 2002
Spektrum DX18 Sailplane Support
This thread is specifically for owners of the DX18 that want to discuss how to program their radio to provide the Sailplane features they are looking for. Please stay on topic. This thread is not intended to discuss the merits of various manufactures programming or method of modulation.
A current copy of “The Guide to Programming a Six Servo Sailplane” is available at
Soaring USA http://www.soaringusa.com/Spektrum-DX18.html
Kennedy Composites http://www.kennedycomposites.com/transmitters.htm#
Seattle Area Soaring Society http://www.seattleareasoaringsociety.com/
As the guide is updated, information on it's availability will posted here.
Sherman Knight
duworm is offline Find More Posts by duworm
Old Jun 26, 2012, 06:51 AM
davidmc36 is online now
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
16 mixes
Was just browsing the guide at Kennedy Composites. It mentions 15 non-dedicated mixes. Sholuldn't it say 16?
davidmc36 is online now Find More Posts by davidmc36
Old Jun 26, 2012, 07:08 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Typo. What happens with these things that describe features is that with every airware update they get more and more inaccurate.
freechip is offline Find More Posts by freechip
Old Jun 26, 2012, 06:43 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Subscribed.
Thanks for all you do, Sherman.
VR,
Target
target is offline Find More Posts by target
Old Jun 27, 2012, 12:23 AM
SlayerNZ is offline
Find More Posts by SlayerNZ
Spektrum Fan Club
SlayerNZ's Avatar
New Zealand, Southland, Gore
Joined Jan 2011
Subscribed, let's hope this thread doesn't get clogged up with It
SlayerNZ is offline Find More Posts by SlayerNZ
Old Jun 27, 2012, 05:34 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
If it ever does, you can check this one out. It's a bit more popular right now and it won't get clogged up with anything but useful info.
Old Jul 14, 2012, 04:08 PM
Gordon is offline
Find More Posts by Gordon
Gordon's Avatar
Joined Aug 2000
I got both my RCRCM Tomcat and Dorado slope aerobats programmed during the past week using your download Sherman. It took me quite a while to sort them out and incorporate the necessary mods to your original program to suit my purposes, but without your programming guide and download I'm sure that I'd still be nowhere near getting them operational.
I'm really grateful for your painstaking work in deciphering the DX18 software and presenting it with such clarity for us all to use. I'm planning to launch the gliders off my local slope tomorrow.
Many many thanks and best regards.
Gordon
Gordon is offline Find More Posts by Gordon
Old Jul 14, 2012, 05:19 PM
duworm is offline
Sherman Knight
Kirkland Washington
Joined Feb 2002
Thanks Gordon, I really appreciate it. If you have any feedback, please let me know. Assembling a guide in this format was a first for me.
Thanks again
sherman
Old Jul 16, 2012, 07:57 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I right clicked and saved as target but when I import into the radio I got an error MSG
GPSstatus device not found.
Any comment?
Old Jul 18, 2012, 12:21 AM
SlayerNZ is offline
Spektrum Fan Club
SlayerNZ's Avatar
Joined Jan 2011
Hi all, new thread here if you are interested
http://www.rcgroups.com/forums/showthread.php?t=1693832
Old Jul 24, 2012, 06:51 AM
mgmodels is offline
Find More Posts by mgmodels
Joined May 2011
Hallo to everybody,
I've spent a couple of weeks on DX18 and me too follwed the guide, excellent job !!
I'm programming an F3B/F3F glider and I'm have a problem,with the Aileron to flap mixer
My flaps have a great down travel -90 degree and only +10/15 degree so when I use the AIL->FLP mixer I got the flap move far down of the Aileron.
I found no way to programm a different Travel UP and travel DOWN.
I use the flap as airbrakes only in "land" so I think that I can change the travel
of the flap during "cruise" to match the down aileron travel or in some case to have no down travel at all.
What do you think about ?
Thank you and sorry for my english
Giuseppe M
mgmodels is offline Find More Posts by mgmodels
Old Jul 25, 2012, 06:28 AM
mgmodels is offline
Joined May 2011
Originally Posted by mgmodels View Post
Hallo to everybody,
Giuseppe M
Sorry I missed the line flap in the Differential menu,
I've setted up the ail dif first and then activated the AIL->FLP mixers so when I was in the differential the screen only shows up Aileron.
now that I've enabled the AIL->FLP mixer in the differential screen I can adjust the differential for both Aileron AND Flap.
Thanks to Andy for the tips !
Bye
Giuseppe M
Old Jul 25, 2012, 03:47 PM
duworm is offline
Sherman Knight
Kirkland Washington
Joined Feb 2002
Flap Differential
000
Old Jul 25, 2012, 04:02 PM
duworm is offline
Sherman Knight
Kirkland Washington
Joined Feb 2002
IN an effort to make the programming simpler, the DX18 only shows you what you need to program your particular sailplane setup. The default is to show the least complicated setup out there, RES.
If you want to see all the stuff possible, you have to convince the radio it needs to show you everything. In Setup, select 2FLP, 4AIL, V-Tail and a Motor. This will “trick” the radio into thinking you are trying to setup a complicated aircraft. Then in Mixes you have to inset a value in Ail > Flp mix to turn on differential for flaps and Tip ailerons.
Once you have done the above, just about all the features are now active and will appear on the function list.
Sherman
Old Jul 26, 2012, 02:03 AM
CurtissP40 is offline
Find More Posts by CurtissP40
Bona Fide Cub Nut
CurtissP40's Avatar
Northwest Oregon
Joined Jan 2006
Re your post (#14)
That's really good to know!!
Thanks for continuing to give us insight into the DX18!!
CurtissP40 is offline Find More Posts by CurtissP40
New Product Spektrum DX18 Victory Pete Radios 11858 Yesterday 11:35 AM
Discussion Spektrum DX18 Hoot Multi Task F3X 128 Sep 17, 2015 11:09 PM
Sold New in Box Spektrum DX18 PatternFlyer Aircraft - General - Radio Equipment (FS/W) 10 Jun 25, 2012 08:32 PM
Discussion Spektrum DX18 owners thread Minimog Radios 0 Jun 25, 2012 12:05 PM
