Are you using the high speed mode on the TX/RX? You might try the standard mode, where it doesn't try controlling the servos at a higher data rate.
Latest blog entry: My Low Wing plane
Joined Nov 2010
Go4it,
have you tried Lipo battery then RCexl kill switch and plug into receiver??? This is just a small test to see if it works with voltage over 6v (Can't remember which opto kill switch but have read somewhere one of then needs 6v and over to work) Make sure your ignition is unplugged during this test because output voltage could be too high for some ignition systems. I have two of these and they work fine. My setup is, Lipo---switch---rcexl kill switch---battery regulator 4.8v--- ignition system Paul |
To solve my problem I installed a brushed speed controller 10amp and I use it as a switch-on/off works like a champ and half the price . The setup that works-lipo-ESC-BEC-output to ignition---ESC controlled by Rx as on/ off switch.So I have two means to shut down the gas motor--throttle close switch for carb plus another toggle switch on transmitter that turns on/off voltage to ignition via ESC. After 50 plus fights no problems. Note: Also I installed a RED LED light off the BEC output to show power is on or off to the Ignition. Also I set my radio up with a fail safe if I loose voltage to the Rx it shuts down the ESC and kills voltage to the ignition. This gives three ways to shut down the beast-[100cc gasser] |
Through the switch away. I use throttle cut and a choke servo. Both are convienient and it works to remotely kill the ignition with out some fancy switch taking up an extra channel. Both are IMAA and AMA acceptable. The rule only states that you have a means of remotely sutting down the ignition. It also eliminates an extra electronic device that may and can fail. You then can run the batteries that you want to use. I personally use LIFE batteries so I dont have to use a regulator, thats one les thing to go bad in flight. I power and control even my 35% planes with the K I S S method, Keep It Simple Stupid! It works for me and keeps me flying.
Hope it helps, Bobby |
| Thread Tools | |
| Help! Heli spins and rudder switch does not seems to be working | Henryms | Skyartec | 49 | May 04, 2012 09:11 PM |
| Help! How Does RCexl test Kit work? | Fokker DII | Engines | 6 | Mar 31, 2012 03:45 PM |
| Sold NIB RcExl Opto Gas Engine Kill Switch | svonavja | Aircraft - Fuel - Engines and Accessories (FS/W) | 3 | Aug 31, 2011 07:33 PM |
| Sold RCEXL Opto Gas Kill Switch | fritzdecat | Aircraft - Fuel - Engines and Accessories (FS/W) | 5 | Jun 06, 2011 05:40 AM |
| Sold RCEXL Opto Gas Kill Switch | bstussie | Aircraft - Fuel - Engines and Accessories (FS/W) | 6 | May 05, 2011 03:23 PM |
