Old Jun 25, 2012, 09:34 AM
NickBee is offline
Find More Posts by NickBee
Flanders, NJ USA
Joined Jan 2001
Charging 2 batteries on a PL6 vs a duo charger (Hyperion or TP charger).
I was all set to get either the hyperion or TP charger and then discovered the PL6. If I want to charge two batteries at once (say 2 6s 5000 packs) that are not exactly at the same starting voltage is that possible? I am trying to wrap my head around the advantages of a PL6 over a dual charger. Or would I need 2 PL6ís to have the same functionality of a dual charger?
Thanks!
NickBee is offline Find More Posts by NickBee
Old Jun 25, 2012, 09:46 AM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Hi, Nick-I'm going to confuse it further for you!
I use two PL-8's, each fitted with an MPA board, which allows me to charge 6 various capacity 3s batteries on one "channel" and 6 various capacity 2s batteries on the other "as if" a "duo" charger; however, if I hose one charger by negligence, or one fails, I still have a fully functioning charger while the other is being repaired.
So, if you want to simultaneously charge 2, 3, 4 or whatever cell batteries, you can use two PL-6's in the Primary/expansion mode, each fitted with an MPA (or not), and rest assured you will never be without a charger (it is far more than a mere charger).
Neither Hyperion nor TP "repair" their devices, so keep that in mind, too.
Check out the MPA board from FMA and primary/expansion use.
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Old Jun 25, 2012, 10:09 AM
NickBee is offline
Flanders, NJ USA
Joined Jan 2001
cool... now what about if your batteries are at different starting voltages. Like say I want to charge 2 4s 5000 mha batts and one is at 3.75v per cell and one is at 3.95 per cell? Is this possible with one PL6? For now I am ok with charging one battery at a time. But buy next year I will have the need to charge two 5s 4400 packs at the same time. My thinking is I can get one PL6 now then get a second one when it's needed.
Thanks!
Old Jun 25, 2012, 10:22 AM
Greenland
Joined Mar 2012
Thanks!
Inverse order: or, why not one PL-6 and one MPA?
That variance is nothing: there is a rule of thumb, as I recall, and maybe someone can comment. I routinely parallel charge with that variance or more, and with cells that can take 3 to 5 C charges, that's chicken doodle!
Old Jun 25, 2012, 10:23 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
If you connect the pack via the main discharge connectors prior to the balance connectors, .2 volts per cell differential should pose no issue. I have long recommended .1V/cell to keep current flow under control. Anything greater than this should be tested with a wattmeter.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Sold New-Sealed In Box Hyperion 720 Duo Charger philip frank Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jun 20, 2012 05:11 PM
Wanted Looking for new or slightly used - Charger Hyperion EOS 720i super duo 3 ganapati08 FPV Equipment (FS/W) 0 May 27, 2012 01:23 PM
Found Hyperion charger 615 Duo 3 (300+300Watt) or 720 Duo 3 (500+500 Watt) wanted bluelevel Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 29, 2012 04:40 PM
Found Hyperion EOS0610i Duo charger or EOS0615i Duo charger Adroc3905 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 05, 2010 04:51 PM
Discussion Hyperion 615i Duo 3 charger (can I charge 4 batteries simulateously?) dgfinch Batteries and Chargers 3 Sep 10, 2009 12:45 AM
