Old Jun 25, 2012, 08:44 AM
noobee is offline
Find More Posts by noobee
Joined Dec 2006
Question
frsky range check w/ telemetry
just got the frsky system (djt, d4r-ii, fld-02, etc). looks like a nice system.
how do you guys perform the range check? the manual says
- place rx antennas horizontally (right angles) but 2ft up
- place tx antenna vertically (orthogonal to the rx antennas)
- set tx to range check mode, walk 30 paces (meters?) and verify control
do you hear the rssi warning beeps as you walk away from the radio? i get the occasional beep after just a few paces from the rx.
i have an fld-02 display that shows the rssi value. even just after a few paces, the rssi value drops rapidly to around 50 (close to the 45 threshold). at 30 paces. it can hover between 40 and 50 and is beeping often. i think i still have control. is this normal and expected?
so, do you guys use the rssi warning beep (or fld rssi display) as an indicator for the range test?
thanks!
noobee is offline Find More Posts by noobee
Old Jun 26, 2012, 11:10 AM
igorp is offline
Find More Posts by igorp
FPV Crash Dummy
igorp's Avatar
United States, CT, Bloomfield
Joined Aug 2007
You will get beeps, but you should be able to get say 100ft away and still have control of the surfaces.
igorp is offline Find More Posts by igorp
Old Jun 27, 2012, 02:40 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
The "orthogonal to the rx antennas" statement is wrong and I am very curious to see in which manual you read this...
The universal rule is: Tx antenna must be parallel and not colinear with at least one receiver antennas.
renatoa is offline Find More Posts by renatoa
Old Jun 27, 2012, 03:52 AM
noobee is offline
Joined Dec 2006
you're right that the manual did not state those specific instructions (only just that the tx antenna is vertical). however, in range check mode, shouldn't we verify that we still have control of the rx in the worst case condition (orthogonal)?
Old Jun 27, 2012, 04:07 AM
renatoa is offline
Joined Sep 2007
If you want it this way, you are right.
Orthogonal is not the worst case, it 26dB signal drop "only" i.e. about 20x range decrease.
The worst is when both receiver antennas and Tx antenna are collinear, i.e. pointing to each other, theoretically this is an absolute null signal case.
Discussion Range check with a DX6i & PZ T-28 SohoR1 Beginner Training Area (Aircraft-Electric) 30 Jan 25, 2016 05:58 AM
Sold FlySky 9x TH9X radio w/ FrSky Telemetry Module and 2s 1300 battery. NEW! JIMinKENTUCKY Aircraft - General - Radio Equipment (FS/W) 1 Feb 25, 2012 06:08 PM
Sold FrSky DF Combo Long Range TX and RX Package With Telemetry for Futaba - NEW djdaveq FPV Equipment (FS/W) 2 Aug 06, 2011 03:43 PM
Sold FrSky DF Combo Long Range TX and RX Package With Telemetry for Futaba - NEW djdaveq Aircraft - General - Radio Equipment (FS/W) 1 Aug 06, 2011 02:50 PM
