Old Jun 25, 2012, 06:18 AM
jcervantes11 is offline
Find More Posts by jcervantes11
jcervantes11's Avatar
Joined Sep 2003
What do you use as a flight stand? I'm a heli flyer and plane flyer.
Looking for flight stand for my heli. Let me know what's in the market. Thanks.
jcervantes11 is offline Find More Posts by jcervantes11
Old Jul 02, 2012, 05:25 PM
deckert is offline
Find More Posts by deckert
Plowin Dirt
deckert's Avatar
USA, WA, Benton City
Joined Oct 2007
http://www.precision-aero.com/index.html
You'll need to put a finish on it as there is none. Kinda spendy but mine sure works well.
Dan
deckert is offline Find More Posts by deckert
Old Jul 02, 2012, 06:08 PM
Joined Sep 2003
Dan
I will be getting one but don't know when. I need to get the flybarless system first and head.
Old Jul 02, 2012, 11:32 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
I have three stands, one for smaller .40 sized models, one for my 2m F3a aircraft, and another wider one for my 2m (18" wide) cap 10.
They're simply cut out of ply, clamped together and have 2-3 holesaws cut into them to accept a 24" long dowel (I use 1" dowel). It's a tight fit, but I can knock them apart and flat pack them
Where they touch the airplane they're lined with pipe lagging sliced longitudinally and cemented onto the ply. so they don't scratch the aircraft.
The wide one also makes a nice stand for working on small wings too!
Curare is offline Find More Posts by Curare
Old Jul 09, 2012, 12:21 AM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
I use a DIY colapsable work bench. Works great for all my models. I've added now a small plastic container, screwed into the top, for bolts etc, and two small hooks on the underside, to hang my Tx.
Best $10 ever spend on RC stuff!
Up&Away is offline Find More Posts by Up&Away
Old Jul 13, 2012, 02:31 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
When i was "on my own" before joining a club I have used a stand that opens up and placed a wood top on it with ply rails extending top and bottom around the perimieter. Bottom o keep it from sliding around and . top to keep things on it.
http://www.harborfreight.com/200-lb-...and-38778.html
Thermalin is offline Find More Posts by Thermalin
Discussion If you were the CD what would you do? GliderDriver45 Electric Competition Soaring-F5J/ALES/e-Soaring 53 Sep 29, 2012 10:02 AM
Discussion How do you tell a flyer he's too old to fly? zeezee Electric Plane Talk 75 Jul 04, 2012 09:38 PM
Discussion What do you use to keep count of your flights and battery cycles? Left Coast DJ Parkflyers 22 Apr 27, 2012 04:54 PM
Discussion Using Virtualdub to record FPV - What settings do you use? NorCalMatCat FPV Talk 12 Feb 25, 2012 08:33 PM
Discussion Large heli flyers. What else do you do with your free time? Greybird Large Electric Helis 22 Sep 14, 2009 08:26 PM
