Old Sep 18, 2012, 08:31 AM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
I use clear tape either Scotch 3/4" or cut strips of packing tape.
Freddie B is offline Find More Posts by Freddie B
Old Sep 19, 2012, 05:44 AM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Bill, I just use the clear packing tape on the exhaust, I don't use anything on the intakes, as fan is usually secured by screws and fit is pretty good. W
Waltjg is offline Find More Posts by Waltjg
Old Sep 19, 2012, 12:48 PM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
OK, thanks.
BillO is offline Find More Posts by BillO
Old Sep 28, 2012, 02:49 PM
BillO is offline
Firecracker!
BillO's Avatar
Exhaust duct in blue foam
Hi guys, some news from the world's slowest build! I realized that the exhaust duct design wasn't right before I started building it, so it was back to Sketchup. I am finally starting to get the hang of it after many days of practice.
The new design starts with a conical section with the shroud diameter at one end and 100% FSA at the other, long enough to clear the motor fairing. I totally left out that piece on the first design for unknown reasons. Then it splits into 2 half-circles, each with area 50% FSA (for a total of 100%). Each of those transitions to a full circle of the same area. This is the start of the nozzle, which ends with a 90% FSA circle. That's a lot of transitions in a very short distance.
I had to move the fan forward about an inch because the motor fairing is longer than the one on the Detrum unit. Anyway, it's kind of cool to see the part in reality after seeing it for so long on the computer.
The plan is to make the duct from two layers of 1.7 oz Kevlar using the lost foam process.
Old Sep 29, 2012, 03:35 AM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
Iam no expert on exhaust ducting, but that looks pretty good to me, nice job cutting that foam out!
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Sep 29, 2012, 01:57 PM
BillO is offline
Firecracker!
BillO's Avatar
Thanks Joe -- what do you think about the layup?
Old Sep 29, 2012, 02:36 PM
sloperjoe's Avatar
Joined Mar 2012
its been sooooooo long since I have done any glass work, I do remember the last intake/exhaust I did was lost foam too, I used 2 layers of the litest Sig glass cloth I could get, stuff was like tissue paper almost, then I used carbon fiber ribbon to add "hoop" supports and some longitudinally on the sides and top/bottom for torsion support, used polyester resin to lay it up, then let it sit for a week to get good and hard, then dumped lacquer wash in it to get the foam out, came out EXTREMELY lite and very very stiff
Joe
Old Sep 29, 2012, 08:28 PM
BillO is offline
Firecracker!
BillO's Avatar
OK -- was that for a 70mm fan?
Old Sep 29, 2012, 08:33 PM
sloperjoe's Avatar
Joined Mar 2012
nope, 90mm fan
Old Sep 30, 2012, 08:13 PM
BillO is offline
Firecracker!
BillO's Avatar
Ahh, so maybe I'll just use 1 layer of the Kevlar then. Thanks!
Old Oct 07, 2012, 02:08 PM
BillO is offline
Firecracker!
BillO's Avatar
Here's my duct, it's only 11 grams! It's really too flimsy so I'm going to add more Kevlar. Hopefully just another 5 or 6 grams.
At this point, I have to go back to some other projects, so it will be a while before I get back to this one. Still, I have learned a lot and it's been fun. Thanks a lot Joe!
Old Oct 07, 2012, 02:20 PM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Bill, it doesn't have to be super strong as the force works all the way around, I use a .005 Mylar for my exhaust ducting and it works great, but I'm not sure about the bi-fulcral exhaust you have there, anyone have any experience with this?? I know on intakes it needs mto be strong as the suction will collapse it if it isn't. BTW,,, what is your exhaust opening? Is it 85% of FSA??? W.
Old Oct 07, 2012, 09:37 PM
BillO is offline
Firecracker!
BillO's Avatar
Hi Walt, the opening is 1.6" dia. X 2, i'm hoping that is 90% FSA. I must have checked my math a dozen times...
Old Oct 07, 2012, 09:55 PM
sloperjoe's Avatar
Joined Mar 2012
hey Bill,
for the exhaust side that should be perfect, for the intake side put the CF ribbon on in "hoops" every 2" or so that should keep it from collapsing from the suction side.
and you are quite welcome, hope to see you finish up on this one soon!
Joe
Old Oct 09, 2012, 08:21 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
Billo,
Those look awesome for the first time around!
Im still squeamish about doing glass ducts.
Maybe i should try on the next one.
D_FAST is offline Find More Posts by D_FAST
Article Hobby Lobby 70mm F-4 Phantom ARF Jet Review Tram Foamy EDFs 67 Mar 12, 2015 09:20 PM
Build Log F-4J PHANTOM II "USS AMERICA" PLANET-HOBBY 70mm EDF GFK Balsa timmybeetle Electric Ducted Fan Jet Talk 3 Mar 28, 2014 06:01 AM
Discussion Good retracts for 70mm Phantom? metroidrc Foamy EDFs 3 Jun 11, 2009 09:31 AM
For Sale Hobby Lobby f4 phantom 70mm jet rtf 232CAP Aircraft - Electric - Jets (FS/W) 6 May 14, 2009 11:24 PM
Build Log 6mm Fly 70mm large- F-4 phantom edf conversion FlyJumper Foamy EDFs 103 Jan 03, 2009 12:00 PM
