This thread is privately moderated by Mutchy, who may elect to delete unwanted replies.
Old Jul 18, 2012, 02:58 AM
Mutchy is offline
Find More Posts by Mutchy
Mutchy's Avatar
Wollongong Australia
Joined Dec 2003
Originally Posted by Ricardo Trevisan View Post
OK I really liked your project ........
But I will make it a radio, with ergometry .... perfect .... keys within easy reach and a very good support in the sticks ... to put it here in the forum in Brazil a question ....
What is the correct way to hold the sticks the Radio?
well with an idea of what I'm searching, and I want a radio that you can use for a long time .....
I'm following the project ..... congratulations .....
Hello Ricardo.
Thank you for your kind words.
I hold the stocks on my tray radio between my thumb and first finger. I use a long extension on each stick.
In case I did not understand your question properly, the sticks will be held onto the top by four socket head screws. There will be a hole moulded into the surface with a flange to the inside which will locate the stick a little lower than the top surface and maybe allow the screw heads to be countersunk.
I hope I have explained myself clearly.
Steve
Mutchy is offline Find More Posts by Mutchy
Old Jul 23, 2012, 02:54 AM
Mutchy is offline
Mutchy's Avatar
Joined Dec 2003
The plug fabrication and shaping is finished. The base board for making the moulds is also finished with three dowel holes to take the dowels used for locating the top and bottom halves of the plug. In the pictures below you can see the complete plug, the top and bottom halves and some of the things I had to make to shape the plug. There are two templates used with the router as guides and a sanding block for shaping the concave face of the plug. I have a lot of test and practice pieces made while learning to use the router. You could make a serious mistake very rapidly with one of those......
To strengthen the top surface of the transmitter I decided to mould in flanges for the stick apertures and the screen aperture. The switch aperture is large enough to accept the FlySky/Turnigy/Eurgle/Etc 9x switch slider for anyone who wishes to use all or some of the parts from a FlySky/Turnigy/Eurgle/Etc 9x hand held transmitter. It will also be deep enough to provide some protection against accidentally turning the switch off in flight. Its also big enough to use a rocker or other design of on/off with as long as it's double pole double throw.
Now to finish sanding and filling the surfaces of the plug. I plan to use Shellac to seal the timber and polish it to a shiny finish.
Steve
Old Jul 30, 2012, 07:50 AM
Mutchy is offline
Mutchy's Avatar
Joined Dec 2003
The plugs are now sealed and (French) polished with Shellac. The finish must be allowed to harden for a few days so while they do that I will make the digital trim circuit boards with four momentary switches each with their part of the wiring harness attached. Then It's time to make the top and bottom moulds for the case.
Steve
Old Jul 30, 2012, 08:42 AM
jirvin_4505 is offline
Find More Posts by jirvin_4505
working to the closest cm
jirvin_4505's Avatar
brisbane australia
Joined Nov 2002
Steve
Looking very nice Steve
Cheers Jeff
jirvin_4505 is offline Find More Posts by jirvin_4505
Old Aug 01, 2012, 03:40 AM
Mutchy is offline
Mutchy's Avatar
Joined Dec 2003
Here's the first digital trim board. It's made from Veroboard with four 'push to make contact' switches which are the printed circuit mount types.
Because the JR 388 I started with has analogue trims - i.e. potentiometer type I decided to use a cross shaped arrangement of push buttons like the Jeti Tx to match the ErSky9x hardware and Er9x firmware. If you are using parts from a Turnigy/FlySky/Eurgle/etc Tx then you merely plug the existing harnesses into the ERSky 9x motherboard.
The green dots are the ends of the legs of the push button switches. The red lines are the jumpers on the other side of the board. The switches are held in place at the correct depth, square and true using a piece of modelling clay (also known as Plasticene in some places)
Cheers
Steve
PS It's important to orient the switches correctly. Because the legs are in a square plan form it's easy to get disoriented.
Old Aug 04, 2012, 06:10 PM
Ricardo Trevisan is offline
Find More Posts by Ricardo Trevisan
Ricardo Trevisan's Avatar
Joined Jul 2012
HI
Dear friend my research in Brazil found that the practice of the hobby,
There are two riding styles, the two fingers holding the oldest rookies in the hobby and use as the game PS supporting the fingers on the sticks ....
Then I killed a doubt ...
Now I have the housing for mold ..... use the experience of games and most of the old let's see what comes out of the mold.
Thank you
Mr. Trevisan
Ricardo Trevisan is offline Find More Posts by Ricardo Trevisan
Old Aug 09, 2012, 06:27 AM
Mutchy is offline
Mutchy's Avatar
Joined Dec 2003
Progressed today on the mould for the top of the Tx case. The fibreglass popped off the plug with only two bubbles. Three coats of PVA mould release ensured that the plug was undamaged. The red stuff is modelling clay to fill gaps which would otherwise have caused the glass to lock under the plug or leak into the stick cavity.
Steve
Old Aug 09, 2012, 06:47 AM
cr8tive_leo is offline
Find More Posts by cr8tive_leo
cr8tive_leo's Avatar
Canada, ON, Cochrane District
Joined Oct 2011
Outstanding!
Hey, did you check out the rotary encoder/directional buttons that were posted on the 9xforums,
http://9xforums.com/forum/viewtopic.php?f=5&t=1239
http://uk.farnell.com/jsp/search/pro...sp?sku=1908271
Have a few on order. Should be useful I think.
cr8tive_leo is offline Find More Posts by cr8tive_leo
Old Aug 09, 2012, 05:48 PM
Mutchy is offline
Mutchy's Avatar
Joined Dec 2003
Originally Posted by cr8tive_leo View Post
Outstanding!
Hi Leo.
No I didn't see them but I followed your links. If it needs code then I am lost. I find that I don't use trims as often as I used to now that I fly ER9x for almost all my planes. I set the TRN momentary switch to activate all trims at once unless I am trimming a model into a thermal turn so I can take my hands off the sticks while the model goes around.
Steve
Old Aug 09, 2012, 08:31 PM
Mutchy is offline
Mutchy's Avatar
Joined Dec 2003
The frame is glued onto the top mould for support. It is partly filled with a dry sand and epoxy mixture to give the mould rigidity and is about to go into the "oven". The plug is left in the mould to maintain it's shape while the epoxy cures.
Steve
Old Aug 11, 2012, 01:31 AM
Mutchy is offline
Mutchy's Avatar
Joined Dec 2003
Top mould now cured and polished with 1000 grade wet and dry paper. The gel coat being white and the brown sand behind the clear parts of the fibreglass are a bit confusing, I know. Sand is cheaper than gel coat....
Steve
Old Aug 11, 2012, 05:13 AM
Joined Oct 2011
Hi Leo.
Steve
Only the directional button replacement, it has a rotary encoder wheel, centre push button and the four directional buttons...
The new trims , nah, happy with the ones we have, and i do the same, much easier.
Can't wait to see the final product!
Old Aug 16, 2012, 03:34 AM
Mutchy is offline
Mutchy's Avatar
Joined Dec 2003
The mould for the transmitter case bottom is now finished.
The next thing to make is the 10 mm thick plate which goes over the top mould against which to lay up the flange.
Steve
Old Aug 21, 2012, 11:58 PM
Mutchy is offline
Mutchy's Avatar
Joined Dec 2003
Being unsure of how thick the fibreglass will be I have not yet made the frame for making the flange, but the first parts for the case are now moulded.
The quality of the top is very poor. It has many bubbles compared to the bottom which has two only. When moulding the bottom I let the gel coat partly cure until tacky and then started laying in the glass cloth. When moulding the top I had a lot of gel coat left over so decided to start laying up immediately. I won't do that again. The integrity of the gel coat was destroyed by the extra work of laying up the first layer of glass cloth.
Both parts consist of Araldite LY 3600 Epoxy resin, Aradur 3600 hardener, a gel coat of West Systems 411 colloidal silica and microballoons mix, one layer of crows foot weave 60 oz/sq.m. glass cloth, and three layers of plain wave 110 gm/sq.m. glass cloth.
The case is light but has sufficient rigidity when the top and bottom are taped together to have a satisfactory feel when handling it. However to give a better feel and provide a better base for the electronic components the top should be thicker.
So the first top part of the case will be used for assembly of the electronics and positioning of the switches. I may need to reposition a few things, and I may make a mistake or two so it won't be filled or finished. A second, heavier top part will hopefully have fewer bubbles be easier to finish and paint and will have the final switch positions. And while it is being made I can get on with the electronics.
Steve
Old Aug 22, 2012, 03:20 PM
Joined Oct 2011
Looks great!!! NICE!
Love the Yellow on the Gimbal.
Discussion Radio FPV tray cougar2465 FPV Talk 4 Nov 27, 2012 04:09 PM
Sold SOLD 600 Pro KDE Battery Tray(2 trays) SOLD jgpncll Aircraft - Electric - Helis (FS/W) 0 Jun 22, 2012 10:06 PM
Sold Ultimate radio tray. happybird Aircraft - General - Radio Equipment (FS/W) 3 Mar 11, 2012 08:14 PM
For Sale Multiplex Royal Evo 12 radio & Cockpit MM radio & Spacebox tray JoeR Aircraft - General - Radio Equipment (FS/W) 10 Jun 01, 2009 11:19 AM
For Sale RC Tray Man Radio Tray StrangeRanger Aircraft - General - Radio Equipment (FS/W) 4 Feb 22, 2007 09:45 AM
