Old Jun 24, 2012, 05:51 PM
this is nukin futs!
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
how much weight can i add on a 30cc plane?
ok. i completed my plane and i found that the CG is 119mm from the leading edge. as i balanced it, the results was pretty tail heavy. i placed my cell phone on the cowl and it balanced out without touching it.
my cell phone weighs 120 grams (4 oz) so whats the best method in adding weight to the nose? im aware that this airframe is intended for gas which is probably the reason why its tail heavy. ideally, i also know that getting a bigger battery is the efficient way in adding weight but lets exclude that for this topic.
additional information:
eg msxr 30cc (electric)
4400 mah 6s 30c lipo.
1100 mah liFe pack. (both are shifted all the way to the front i have nothing else to move)
any ideas?
out of stock is offline Find More Posts by out of stock
Old Jun 24, 2012, 06:23 PM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Get a bigger/heavier rx pack. It's much better to install useful battery capacity rather than just parasitic weight.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jun 24, 2012, 06:35 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
Joined Aug 2009
Mount your cell phone inside the cowl when you fly...
I think the obvious answer would be to add weight to balance it out. Four ounces isn't much for a plane of that size; you're not likely to notice it.
If there's a lot of heavy stuff in the back of the plane, see if you can remove it or lighten it.
C₄H₁₀ is online now Find More Posts by C₄H₁₀
Old Jun 24, 2012, 07:25 PM
Seattle Area
Joined Aug 2007
That doesn't make sense. How can he take calls while he is flying? I know Bluetooth doesn't transmit very far.
The obvious answer is to research phone weights and purchase an inexpensive phone of the same weight for ballast. No sense in signing a two year contract for four ounces either; get a pay as you go phone.
eagle777 is offline Find More Posts by eagle777
Old Jun 25, 2012, 07:17 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Change your lightweight motor spaces to heavy ones ?
eflightray is offline Find More Posts by eflightray
Old Jun 25, 2012, 07:51 AM
this is nukin futs!
Joined Jan 2012
I just got my hands on the actual manual of this model. (Eg aircraft msxr 30cc). The disc manual states i should start at wing tube. Doing so now the plane is just slightly nose heavy. I moved the battery back a bit and its balanced out.
If your wondering where did i get 119mm from the leading edge, i got it from an online shop. Its all in spanish but i did read "center of gravity 119mm. Im not sure whose right but I'm going with what the manual states.
I've also heard that the wing tube is an ideal spot to start.
Old Jun 25, 2012, 09:05 AM
Joined May 2005
1/3 back from the leading edge is often a good rule of thumb for a starting point if the recommended CG is not known. Starting with the CG a bit too far forward is likely to be less catastrophic than a CG too far back, in my experience. A plane that is overly nose heavy will usually just have a higher stall speed, while a plane that is tail heavy will often nose up, then stall one whole wing first (often the left wing) and nose in, particularly on turns. Some people erroneously refer to this as a "tip stall."
caseih is offline Find More Posts by caseih
Old Jun 25, 2012, 11:39 AM
this is nukin futs!
Joined Jan 2012
Forgive me im not inclined in measuring. When you say 1/3 does that mean 1/3 of the wing from leading edge? .thank you for your input.
Old Jun 25, 2012, 01:12 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Try this CG calculator - http://www.geistware.com/rcmodeling/cg_super_calc.htm - just enter the dimensions in the 'MAC And Neutral Point' section, then set the 'Desired Static Margin' to how you want the plane to fly.
Personally I feel the 1/3 may be too far back for a first flight. I have always worked the 25% to 30% CG range, at least until I have flown the model a few times.
Old Jun 25, 2012, 01:41 PM
Hey, watch this!
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
I always guestimate where a wing spar would be placed and try to balance withing a 1/2 inch fore or aft of that. If your wing tube is about where a wing spar should be I'd roll with that.
dedStik is offline Find More Posts by dedStik
Old Jun 25, 2012, 03:20 PM
this is nukin futs!
Joined Jan 2012
Wait, so wing tube & wing spar are two different things?
Old Jun 25, 2012, 09:47 PM
Joined May 2005
Yes. I agree with the other poster that often 25-30% is good too. And like the poster who talked about measuring from the wing spar, I do that as well.
Question How much additional weight with FPV setup? yomgui Video Piloting (FPV/RPV) 4 Jun 19, 2012 08:24 PM
Discussion how much wind can these multirotor things fly Evan03 Multirotor Talk 7 Jun 15, 2012 04:15 AM
Discussion How much weight can glue add/save on a build nfsiv Electric Plane Talk 7 Apr 10, 2012 08:36 AM
Discussion 4S Life On Rustler VXL How Much Can It Reach? Wa7sh Electric Power Cars 18 Apr 02, 2012 06:49 PM
Discussion How much battery weight can I add to the P 38 ? cyclops2 GWS (Grand Wing Servo) 25 Jan 30, 2007 01:33 PM
