Old Jun 24, 2012, 03:21 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
Build Log
Unusual Quad frame - Z600
Introducing the experimental Z600.
600mm M2M
Jakub's Multiwii
Turnigy Plush 25A ESC
Turnigy Park450 890KV motors
GF 10x4.5 propellers
Turnigy Nano 3300mAh 3S battery
Power distribution board inside, between the 2 plates
Weight 1320g, AUW with battery 1570g
Motor test with 11.9V battery :
Mid-throttle : 4.3A - 50W - Thrust 380g = Total 1520g - Efficiency 7.6 g/W
WOT : 14.5A - 161W _ Thrust 930g = Total 3720g - Efficiency 5.8 g/W
Flying quite well.
First flight :
Z600 - First flight (1 min 23 sec)
Mortimer is offline Find More Posts by Mortimer
Old Jun 29, 2012, 09:59 PM
Juggsterbate is offline
Find More Posts by Juggsterbate
Joined Feb 2012
That's some fine looking piece of machinery you got there sir.
Juggsterbate is offline Find More Posts by Juggsterbate
Old Jun 30, 2012, 02:25 AM
Sad Sack is offline
Find More Posts by Sad Sack
What's a servo?
Australia, QLD, Brisbane
Joined Nov 2008
What software did you do your sketch and measurements in?
Sad Sack is offline Find More Posts by Sad Sack
Old Jun 30, 2012, 09:37 AM
Mortimer is offline
Mortimer's Avatar
Joined Apr 2010
Software is PageMaker7.
I expect Illustrator will also be fine.
Old Jun 30, 2012, 10:11 AM
gvr63 is offline
Find More Posts by gvr63
Joined Jan 2012
Nice work, but you need 10 % more Al tubing than the classic cross form. So this config is per default heavier than the classic cross form.
Just my two cent
gvr63 is offline Find More Posts by gvr63
Old Jun 30, 2012, 10:23 AM
Mortimer is offline
Mortimer's Avatar
Joined Apr 2010
Thanks a lot!
Old Jul 06, 2012, 04:00 PM
Mortimer is offline
Mortimer's Avatar
Joined Apr 2010
This frame has been crash tested yesterday.
It felt from about 100m high and landed upside down on a hard surface.
It made a loud noise. It was mainly my fault.
3 damaged motors, maybe repairable, 2 propellers, one HK Wing Cam and dome broken.
No bent arm or cracked plate, motors are noisy but everything works normally.
Working to make it fly next weekend.
Old Jul 06, 2012, 05:04 PM
Buzz_Man is offline
Find More Posts by Buzz_Man
Fly safe, fly often!
Buzz_Man's Avatar
United States, GA, Powder Springs
Joined Dec 1999
Sorry about the crash.
Do you feel like telling us why it happened so we can avoid doing the same thing?
Was it a power failure?
Buzz_Man is offline Find More Posts by Buzz_Man
Old Jul 06, 2012, 06:27 PM
Mortimer is offline
Mortimer's Avatar
Joined Apr 2010
It was in the evening, no wind at ground level but a bit windy higher.
I climbed too high for my sight, drifted in the wind, lost orientation and control and crashed.
I will be more cautious in the future.
Old Nov 08, 2013, 06:45 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Is there a dxf file available for the frame plates? Or maybe some other type of file that I can get converted to a dxf file?
Jack
jackerbes is offline Find More Posts by jackerbes
Discussion New Quad Frame Ottomite Multirotor Talk 3 Jul 07, 2012 01:47 PM
For Sale Convertable frame (tri.quad or hex) actionplus Aircraft - Electric - Multirotor (FS/W) 4 Jul 07, 2012 01:30 PM
Wanted looking for X650 quad frame. tc3wins Aircraft - Electric - Multirotor (FS/W) 0 Jun 14, 2012 05:06 PM
Discussion Parrot ar drone flight controller on other quad frame and motors? unfaix Multirotor Talk 0 Jun 13, 2012 07:49 PM
For Sale G10 FPV/AP Boom Style Quad Frames. tosjduenfs Aircraft - Electric - Multirotor (FS/W) 9 Jun 12, 2012 05:14 PM
