This thread is privately moderated by Endlesslag, who may elect to delete unwanted replies.
Old Jun 24, 2012, 02:55 PM
Endlesslag is offline
Find More Posts by Endlesslag
Trader Rating: 30
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Daytona Beach
Joined Jan 2011
Trader Rating: 30
Wanted
WTB Air Retracts- 5/8 bore x 1-5/8 stroke actuator
Looking for a 5/8 by 1-5/8 actuator. If you have any retracts, can you please check the cylinder size/stroke for me? I'm trying to get a Byron Staggerwing flying, and leaking retracts all that's holding it back. PM me.
Even if you have one that's close it might work.
Endlesslag is offline Find More Posts by Endlesslag
Old Jun 24, 2012, 04:04 PM
probuilder is online now
Find More Posts by probuilder
Trader Rating: 20
Southern California
Joined Sep 2003
Trader Rating: 20
Leaks
Were is the leak coming from? I have a few staggerwings and usually it leaks from the air fitting at the end of the cylinder! Squirt it with windex to be sure, and see were the bubbles are coming from. If it is the fitting they can be twisted out with a pair of pliers. put a little thick CA around the fitting, and reinsert with a slight twisting motion then sap with kicker.
probuilder is online now Find More Posts by probuilder
Old Jun 24, 2012, 04:07 PM
Trader Rating: 30
Endlesslag's Avatar
Joined Jan 2011
Trader Rating: 30
Yeah, coming from the end of the cylinder on the rod side.
What fitting are you talking about? The endcap is crimped on on both ends.
Old Jun 24, 2012, 04:24 PM
Trader Rating: 20
Southern California
Joined Sep 2003
Trader Rating: 20
Leak
Were the air line attaches! Look carefully, because this leak may look like it comes from the shaft O ring.
Old Jun 24, 2012, 06:09 PM
Trader Rating: 30
Endlesslag's Avatar
Joined Jan 2011
Trader Rating: 30
Nope, definitely the shaft O-ring. Is there a fix for that?
Old Jun 24, 2012, 06:43 PM
Trader Rating: 20
Southern California
Joined Sep 2003
Trader Rating: 20
Leak
Before you throw in the towel. Try either baby oil or vegtable oil in the cyl. Draw it into your hand pump then squirt in the cyl, a little at both ends and work the cyl.
Old Jun 25, 2012, 04:30 PM
warbirdguyn951 is offline
Find More Posts by warbirdguyn951
Trader Rating: 52
United States, CA, Corona
Joined Nov 2003
Trader Rating: 52
Dave, Im shocked your actually helping someone... good for you!!
warbirdguyn951 is offline Find More Posts by warbirdguyn951
Reply With Quote  (Disabled)
Old Jun 25, 2012, 04:36 PM
Trader Rating: 30
Endlesslag's Avatar
Joined Jan 2011
Trader Rating: 30
I let it sit overnight with some oil in it after working it in...still a no go
Anything else?
Old Jun 25, 2012, 04:59 PM
Dad_Roman is offline
Find More Posts by Dad_Roman
Trader Rating: 172
Twistaholic AMA 134406
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
Trader Rating: 172
Depends on the O-ring material. A dab of Brake Fluid may swell it back up and seal. Or a dab of Transmission repair fluid or PS repair fluid. That stuff is designed to swell seals.
Worth a shot
Dad_Roman is offline Find More Posts by Dad_Roman
Old Jun 25, 2012, 05:06 PM
Trader Rating: 30
Endlesslag's Avatar
Joined Jan 2011
Trader Rating: 30
Worth a shot
going to have 40 different types of fluid in it when im done.....
I'm on it now though
Old Jun 25, 2012, 05:07 PM
Trader Rating: 172
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
Trader Rating: 172
LOL...we stabbin in the dark tryin to make a save
Old Jun 25, 2012, 05:48 PM
Trader Rating: 30
Endlesslag's Avatar
Joined Jan 2011
Trader Rating: 30
I think the internal O-ring is dead....HOWEVER!!! I got it to seal using an o-ring pushed on the outside. Or at least seal enough it holds pressure for more than 10 seconds It has threads on the front and a small recess that an O-ring fits into, so I'm working on finding a nut that will thread on and then attach a washer onto it to compress the O-ring in place. It should work...tiny ray of hope
Old Jun 25, 2012, 06:13 PM
saltydog56 is offline
Find More Posts by saltydog56
Trader Rating: 10
William from Windham NH USA
saltydog56's Avatar
United States, NH, Windham
Joined Apr 2005
Trader Rating: 10
byron retracts
Greetings from the North East you could try contacting....
http://www.ironbaymodelcompany.com/
last time I checked they had replacment cylinders for the staggerwing!
Just get the contact info from the above site and make a call, forget trying to locat it on the web site
William
saltydog56 is offline Find More Posts by saltydog56
Sold New - Ultra Precision UP-8 Retract Valve, Quick Disconnects, air fill valve, 1/16th T whatasteele Aircraft - General - Miscellaneous (FS/W) 1 May 09, 2012 07:34 AM
Sold $350 1/4 1/5 scale 28cc 2 stroke unleaded gas TITAN truck 28CC TRADES WELCOME reddyrightnow Cars - Trucks and Parts (FS/W) 3 Apr 09, 2012 01:17 AM
World's smallest air actuated retracts LJE4357 Electric Ducted Fan Jet Talk 424 Feb 05, 2008 08:54 PM
WTB (wanted) 14 x 8.5 folding prop dang Aircraft - Electric - Airplanes (FS/W) 0 Sep 20, 2002 11:00 AM
