http://www.rcgroups.com/forums/showthread.php?t=1607270 Also strongly recommend you spend lots of time in this forum and ask lots of questions before your next attempt: http://www.rcgroups.com/beginner-tra...ft-electric-8/ |
Bought a new Hacker A10-15S, and it's going in today. Already verified that it's working fine with the stock ESC. |
*sigh* Actually, I bought an A10-12S.
This turned out to be a nicely sized replacement for the ET800's stock motor. I had to modify the motor mount area to fit it in, but it seems sturdy enough to me. (I'll try to add a pic, here, in a sec.) As (I hope) you can see, I also added a GWS 5043 prop, trimmed down to fit. |
United States, IL, La Grange Park
Joined May 2012
Oldeman
Thanks for your vote of confidence. The flight information you provided also will help. I know I posted in an earlier message that the plane was tail heavy I meant that it was nose heavy which is why I was concerned about the CG location. I'll try flying again after I get a little more success with the UM T-28 and do some necessary repairs on the ET 800 (bashed up nose). |
After my motor burned out, and I had already bought and installed a new (slightly bigger) one, I got curious about other options I should have explored first -- other motor/prop/ESC combinations. So I pulled up a motor/prop calculator and spent hours experimenting.
Here is what I found out: The Turnigy 1811-3800 (memory?) motor that came with the plane, and the 6A FMS ESC that came with it, are nearly perfect for that installation (Easy Trainer 800). Because the prop is physically constrained to a max 3" diameter... there is really no viable prop you can put on that plane that would draw more power than the motor and ESC already provide. (* See disclaimer below, eh?) The best thing you can do.. and the simplest... is to remove the stock prop, and add a GWS 5043 that is trimmed down to the 3" diameter (making it, effectively, a 3x4.3). You'll get quite a bit of extra "push" for very little work and money. [You might need a prop adapter, too, I forget?] The only way to get even more thrust on this plane would be to mount the motor on a raised pylon (or something), so you can put on a prop with more diameter. Then, a bigger motor/ESC/(battery?) would be required. -- * Disclaimer: No promises. I feel comfortable with the calculations I performed, but you make changes to your stock configuration at your own risk. Test, whatever you do, for overheating! |
I'm using a cut down and carefully balanced GWS 504x3 on my EZT800 and it draws just over the 6A rating of the stock ESC at WOT on a freshly charged pack, my EZT800 with this prop provides sparkling performance and little chance to burn out the motor/esc if used with restraint, I rarely fly this model at prolonged full throttle because it is so quick and will get out of sight in a blink of the eye if not careful,. |
Well... I tried the new Orange 3-axis stabilizer this past weekend... in my ET800. Not because it felt unstable -- it flies fine. I just thought it would be a lot of fun to try. (My field is pretty gusty sometimes. Why not?)
I started by moving the plane's Rx toward the back, in the fuselage, so the stabilizer unit could be right behind the servos where the body is widest. The unit is too fat to fit anywhere else inside. I tried snugging it in with Velcro to minimize any possible shifting while in-flight. The "fit" was *really* tight... especially so because the servo leads point "up" on this unit, and the servo push-rods pass over the top right where the servo leads are standing. I ended up leaving off the rudder stabilizer so the pushrods had room to move. In the end -- it all worked as expected at my kitchen table. Shake, rattle, and roll... and the ailerons and elevator would instantly counter whatever movement I threw at it. Nice. I left the gains at factory settings, because I didn't know what else to do with them. So I went to the park to try it out. Not so nice. It felt like I'd given my airplane a Valium. Super sluggish feeling... basically hugging the ground because it was so reluctant to climb. Managed wide circles... and that's about it. Unfortunately, with the unit sandwiched in so tightly, field adjustments were really difficult. I tried dialing back a bit, and got a little more control, but gave up when I noticed an odd coupling effect that I couldn't decipher: Sharp elevator movements we're resulting in occasional wild aileron snaps (momentary/recoverable). I went home mystified and disappointed... and took it all out. I need to rethink my approach. A) I think, for fun, I'll try the i86AP... which is only a few bucks more expensive... but has the advantage of servo leads that stick out "lengthwise" instead of "up"... so it should lay under the pushrods without interference. B) I'm going to look for more advice on fine-tuning the gains on the bench. The only advice I've seen so far is to turn up all gains until chattering starts, and then back off just enough for it to quiet down. Sounds like a "maximal" approach to me... not sure that's what I want. (My servos were not chattering, btw.) C) Need to find a layout that allows easy field adjustments. D) The unit also needs, I think, a rock solid attachment to the body. Maybe Velcro was too susceptible to vibrations (confusing to gyros?). Has anyone else tried a stabilizer with this a/c? Any advice on what else to do/investigate? |
Joined May 2012
I have had two successful flights with this plane (finally!). I find the plane very slow to respond to inputs and a tendancy to tip stall. The motor is also very loud at half throttle and sounds way worse as you increase power. I would bet that if I ran at full throttle for any length of time the motor would fail quickly because it sounds rough.
I admit the only reason I am flying this is because my UM T-28 is under repair after a significant meeting with the ground. I do like learning more on a larger plane which should help me get up to purchasing the Art-Tech (of HK) Pitts byplane. That looks like a blast to fly. |
I've had very good luck with a GWS 5043, cut down to 3" to clear the tail boom. This simple prop change dramatically improves the feel of the plane. (You'll need a prop adapter to get it to fit.) |
You know... I really like this little plane.
I've tinkered with a variety of non-stock items: Different receivers, different speed controls, different motor and prop. I even tried the ORx 3-axis stabilizer. And I've altered the servo pushrod arrangements with the rudder and elevator. I've learned the following... The stock motor and ESC are very nicely sized for this airplane. After a number of experiments... I've actually restored the original ESC and bought/reinstalled a new motor of the same make/model as the original (because my original motor crapped out). However, the original prop is really wimpy. I replaced that with a GWS 5043 that is cut down to 3" (to just clear the tail boom)... and made sure it was well balanced so it wouldn't vibrate anything to death. The resulting prop, motor, and ESC make a very zippy combo for this plane. This *one* dirt-cheap mod, more than anything else, did wonders to the way this airplane flys. (Noobie tip: Make sure the prop is facing the right direction when you put it on... it makes a big difference. Sometimes I am an idiot.) I had a bunch of Rx problems early on... I *believe* aggravated by intense humidity (based on my experiences so far) but I don't know how to prove that. I swapped out the stock Rx for an OrangeRx 6ch + satellite... very disappointing. I swapped that out for an OrangeRx 4ch... (hey, it was available)... blah. I finally bought an honest-to-goodness Spektrum AR400 for US$30... pure happiness... worth every penny. If you aren't having range problems... great... you won't need to worry about this issue. I did, and a genuine Spektrum solved my problem. Lesson learned. The ORx stabilizer was a fun disappointment. It was a tough fit, it was hard to adjust it to a point were it felt fun to fly and, in the end, I took it out. I must say, though, the process of experimenting with it was really fun. I'm about to borrow a Guardian... (hey, it's available)... but, to be honest, I love the free-wheeling feel of my plane without one. While it's fun to tinker, I'm not expecting to adopt the Guardian permanently. Last... I took out the pushrods going back to the rudder and elevator. Early on, when I was crashing a bunch (inexperience made worse by radio problems)... the pushrod's inertia was being jammed forward, during nose-in impact, resulting in the gears on both servos getting stripped... repeatedly. I replaced both rods with... I don't know the proper name... tube-guided push-wires? This change also made it easier to put more stuff in the fuse cavity... no pushrods taking up space straight down the center. As I say... I really like this little plane. I think it says something about the overall package that, after all of my experimenting, the best upgrade I've put into it was a new prop. And, man, is it fun to fly. So... I'm about "tinkered out" on this one... it's dialed in and flying beautifully. Now I'm starting to wonder, what should I buy next? |
| Thread Tools | |
| Discussion fms easy trainer 1280mm | dazza44 | Foamies (Kits) | 280 | May 12, 2013 12:05 PM |
| Discussion Thunder Tiger Easy Trainer 40 conversion | stevo1957 | Glow to Electric Conversions | 37 | Oct 28, 2012 05:31 AM |
| Discussion Easy, Cheap Fuselage For 40 Sized Trainer | NEW222 | Fuel Plane Talk | 2 | Jun 14, 2012 12:02 AM |
| Sold FMS Mini A-1 Skyraider 800 Series RTF Electric Warbird | MIKEYOUR | Aircraft - Electric - Airplanes (FS/W) | 2 | May 09, 2012 01:00 AM |
| For Sale NIB PNP Skyangel JAS39 Mirage 2000 FW190 T28 FMS 1400 & 800 warbirds | www.hobbyb.com | Aircraft - Electric - Airplanes (FS/W) | 1 | Apr 29, 2012 07:30 PM |
