| Thread Tools |
| This thread is privately moderated by LICobra, who may elect to delete unwanted replies. |
FMS P-51 4 blade vs 2 blade
Because of the discussions about speed of the FMS 1450mm P-51...or the lack of....I decided to test the FMS version 6 (500kv motor) with the stock 4 blade against an APC 14X12 2 blade.
I know alot of people say it sure looks like it's going XX miles per hour....and there usually way off as I would have thought different also.....but I will say this....a Parkzone P-51 going an actual 70 mph looks so much faster on a low fly by then an FMS P-51 going by at the same 70 mph....as the much larger airframe makes it look so much slower.....so with that said... I took my V6 out this morning at 7am as it was already hot but there was zero wind, so I thought it was perfect for a prop speed test using the Voltron GPS data logger which gives accurate top speed , highest altitude, flight time and duration. I static tested, then (GPS) flight tested both stock V6 4 blade and an APC 14X12 2 blade with the stock 500 motor and a 3600 4S 25C lipo....each test consisted of flying a 2 direction full throttle pass using 2 lipos for each prop. I recorded the average of both lipos. The stock 4 blade static tested 58.92 amps, 5900 rpms @925 watts with a calculated pitch speed of 55 The stock 4 blade actual in-flight GPS test logged an average of 62 mph The APC 14X12 2 blade elecrtic prop static tested 42.62 amps, 6300 rpms @ 672 watts, with a calculated pitch speed of 71. The APC 14X12 actual in flight GPS test logged an average of 73 mph... The 4 blade seems to unload and gain some speed over the static test. and now we know if we remove the 4 blade and replace it with a 14X12 you'll get an instant 10+ mile per hour increase along with less amp consumption. I know I can hear the skeptics now....and I agree....the stock 4 blade looks like its going 40 mph....but it's not. |
Latest blog entry: FMS P-51 4 blade vs 2 blade
Eric...I think the testing is fun, but like you I question it's accuracy. Tom tested his FMS back in the early days with his Castle Creations ICE ESC in-flight data recorder and recorded basically the same rpms static and he did in level flight.....only the amp draw and watts were lower as the prop unloaded in flight.
I doubt the amps will be higher in flight then they would be in static testing. Since I don't have in flight testing capabilities, I took my static rpms and converted them to pitch speed.....the Voltron gps only gives highest achieved speed and height....but the speed was very close to static calculated pitch speed on several of my warbirds....so like you...I'd really like to know more with the in-flight data...and compare at least my level top speed to the GPS. |
| Thread Tools | |
| Discussion FMS P-51 - How to adapt 2 blade prop? | indyjon | Electric Warbirds | 8 | Mar 11, 2013 04:35 PM |
| Discussion have a fms 800mm p-51 need some help | Iceman320 | Electric Warbirds | 15 | Aug 31, 2012 09:55 PM |
| Found 4" P-51 style 2 blade spinner | djmoose | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Sep 01, 2011 09:59 AM |
