Old Jun 24, 2012, 10:44 AM
Victory Pete is offline
Find More Posts by Victory Pete
Rhode Island USA
Joined Aug 2010
Question
How low should an ESC/BEC drop the Rx voltage?
I have a 4S3200mah LiPo powering a Power 32 via an E-flite 60amp ESC/BEC. I noticed my Rx voltage dipped down to 4.1v today. The Lipo went down to 13.7v. I am monitoring with my DX8 and telemetry log. Is this a normal reading?
VP
Victory Pete is offline Find More Posts by Victory Pete
Reply With Quote  (Disabled)
Old Jun 24, 2012, 11:02 AM
Wintr is online now
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
Since that ESC is supposed to have a switch-mode BEC, dropping that low is unusual. Do you exceed the servo load as shown in the manual?: http://www.horizonhobby.com/pdf/EFL6...CInstSheet.pdf
If not, maybe you have a binding servo?
Wintr is online now Find More Posts by Wintr
Old Jun 24, 2012, 11:10 AM
Rhode Island USA
Joined Aug 2010
I am not sure of the servo load, but I was doing some fancy manuevers.
VP
Old Jun 24, 2012, 10:53 PM
Wintr is online now
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
Make sure your servos don't reach the stops and grind with full motion on the sticks, as that will really increase the current draw. Also, check to see that all the control surfaces work smoothly throughout the range by disconnecting the control rods at the servos, and move the controls as though you are the servos. If you feel any tight spots, try to figure out how to eliminate them.
Old Jun 25, 2012, 01:42 AM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
Pete, I know you are aware of clearing the readings on your DX8 but I have forgotten a couple of times and freaked out when I checked at the end of a flight when I saw similar readings. Did it happen more than once? Just a thought.
Harry
Harry H is offline Find More Posts by Harry H
Old Jun 25, 2012, 05:53 AM
Rhode Island USA
Joined Aug 2010
Harry
Actually this is a replacement ESC from Horizon, the one in it before seemed to be defective, I had brownouts and the Rx dropped to 3.2. Horizon never said if there was a specific problem with the ESC, they just said they would replace it. So I dont know if this is the same issue. I will check for binding.
VP
Old Jun 25, 2012, 07:24 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
"..The Lipo went down to 13.7v..."
That would be 3.45V per cell. Was that the lowest under load voltage during the entire flight and taken from a data logger? If it was the voltage at the end of the flight, the voltage was probably quite a bit lower at some point during the flight.
For best battery life (and voltage stability for the BEC and receiver) you would not want to take the cells lower than 3.7V at any point in the flight. And if you found the cells around 3.7-3.8V immediately after landing the battery would not have any useable capacity left, if would be about 90% or so depleted.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jun 25, 2012, 07:40 AM
Rhode Island USA
Joined Aug 2010
Jack
Yes, 13.7 was the lowest. end of flight was 14.5. I have an alarm set for 13.7 to alert me when to end the flight. So do you think this is what caused the Rx voltage dropping?
VP
Old Jun 25, 2012, 10:50 AM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
How about trying a separate BEC if you have one available. Personally, I don't use the BEC that is combined with the ESC. At least if you have a ESC failure, you will still have control with a separate BEC.
Harry
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
VP
Being a voltage regulator, the BEC only needs 6.5 to 7 volts input to supply the required 5 volts out. So as long as the main battery is above 7 volts it cannot be the cause of the low voltage out of the BEC. The only reason the BEC output would be so low is that it had too high of a load. i.e., the receiver and servos simply pulled more current than the BEC was designed to supply.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Jun 25, 2012, 10:51 AM
Rhode Island USA
Joined Aug 2010
Harry
I dont have one, but that would be an interesting experiment.
VP
Old Jun 25, 2012, 10:56 AM
Rhode Island USA
Joined Aug 2010
Larry
Yes, thanks. The original ESC dipped the Rx v to 3.2 and I would lose motor controll for a few seconds while the Rx went into failsafe. I just wish I knew if Horizon found an actual problem with it or not. I did fly a few weekends with the new one without a low Rx voltage reading. It was just this last flight that I got the low reading and I was doing nonstop aerobatics so it seems it may be a servo load issue.
VP
Old Jun 25, 2012, 11:08 AM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
Pete, is this the ESC you have ?
http://www.e-fliterc.com/Products/De...rodID=EFLA1060
Harry
Old Jun 25, 2012, 11:11 AM
Rhode Island USA
Joined Aug 2010
Harry
Yes.
VP
Old Jun 25, 2012, 11:25 AM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
I read the specs on that one, they say you can run 6 standard digital servos on 2.5 amps?? That sounds really optimistic. I have had a few conversations with a tech at Castle about the 10 amp BEC I was using with standard digital servos. He was very clear that using the 10 amp (5 amp continuous / 10 amp max) with anything over 4 servos (in his opinion) was borderline. I have switched to the 20amp pro in all my A/C and set it at 6v. Never see it drop down below 5.9 unless I forget to clear the DX8. Don't know if this applies to your setup.
Harry
Discussion How ''Bad'' is is not to run an external bec? SARCFAN Racing Boats - Electric 8 Jun 19, 2012 02:18 AM
Discussion High Voltage Low Amp Esc PatrickRC Power Systems 12 Jun 14, 2012 03:53 AM
Discussion Lipo voltage drops off rapidly on full charge, should I discard it? RaffiNY Batteries and Chargers 10 May 10, 2012 10:31 AM
Discussion At what voltage should my low voltage alarm sound? Physics_Dude Multirotor Talk 5 Mar 12, 2012 04:07 PM
Discussion How low should you go? Battery voltage under load.. GigaahXL Batteries and Chargers 6 May 18, 2011 10:51 PM
