Old Jun 24, 2012, 09:38 AM
Riodiler1 is offline
Find More Posts by Riodiler1
United States, CA, Livermore
Joined Jan 2005
What motor/ESC comes with the ST-Models ASW28 from Tower Hobbies?
Does any know the specs for the motor and ESC that comes with the ST-Models ASW28 from Tower Hobbies? I am trying to determine battery options that would be safe to use with the stock motor/ESC setup so I don't fry anything.
Thanks!
Riodiler1 is offline Find More Posts by Riodiler1
Old Jun 24, 2012, 10:01 AM
peterlngh is online now
Find More Posts by peterlngh
Joined Apr 2012
The motor is a 1000kv that maxes out around 8 amps with the stock prop. The best guess is that the ESC is around 10-15 amp. Just about any 2 cell between 1000 and 1300mah should work. I'm using a 1300mah Turnigy Nano-tech and it seems to work very well for both power and balance.
peterlngh is online now Find More Posts by peterlngh
Old Jun 24, 2012, 10:17 AM
Joined Jan 2005
Thanks for the info! I have been using a Sky Lipo 1300 mAh, 2-cell, 20C and want to get a 2nd one but nobody stocks the 20C version. I can find similar ones with different "C" ratings like 15C, 25C, etc. and I'm wondering which one to go with and if it even matters??
Old Jun 24, 2012, 10:30 AM
Joined Apr 2012
I would think that a 25C won't seem any different that a 20C. My Nano-techs, from HobbyKing, have a 25-50C discharge rate. I must admit that I don't fully understand the effect of discharge rate very well but I don't think that a high rate will cause any problems for a system that isn't being taxed by too big a prop or something. Here's where I found them.
http://www.hobbyking.com/hobbyking/s...dProduct=20422
Discussion FMS ASW28 vs ST-Models ASW28 - Comparisons Riodiler1 Electric Sailplanes 8 Jun 28, 2012 02:03 AM
Discussion What is CG for ST-Models ASW28 Riodiler1 Electric Sailplanes 2 Jun 23, 2012 12:02 PM
Discussion Replacement motor/prop for Hobbyking / St Model ASW28 ? frank48 Electric Sailplanes 0 Apr 10, 2012 09:49 AM
Discussion Hobby King (ST Models) ASW28 in action :) venquessa Slope 0 Jul 23, 2010 04:43 PM
Discussion Which glider to upgrade to? From ST Models ASW28? Kn0bby Sailplane Talk 4 Jul 19, 2009 01:32 PM
