Old Jun 24, 2012, 08:51 AM
krexken is offline
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
Why Does My Plane Need So Much Uptrim?
I've got one of these http://www.valuehobby.com/airplanes/...dy-to-fly.html. It's good flying airplane but pretty hard to keep it from being tailheavy, IMO. Mine's a bit heavy at around 53 ounces with a 3s 2200 and a 3548 sized motor. The reason I don't like having to use so much uptrim to fly level is that when I hover, it always wants to roll over or fall back on itself. I have a hard time using a little bit of elevator to consantly hover. Not sure if motor angle or anything can be adjusted to help. Perhaps a switch to change elevator trim for hovering? I'm not much on radio programming but I guess I need to learn. I'm using a Turnigy 9x radio.
krexken is offline Find More Posts by krexken
Old Jun 24, 2012, 09:01 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
You haven't mentioned the CG, I assume it is correct and not well forward ?
eflightray is offline Find More Posts by eflightray
Old Jun 24, 2012, 09:42 AM
krexken is offline
Longview, Tx
Joined May 2008
It's actually about a quarter to half inch tailheavy. Still flies stably. I'd have to add weight to get it any better. Really don't want to.
Old Jun 24, 2012, 09:47 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
A 3D aerobatic model should fly inverted with no or only the slightest touch of down elevator.. does it?
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Jun 24, 2012, 12:44 PM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
What strikes as strange is that you say it's TAILHEAVY but you mention UPTRIM.
Usually with a tailheavy model - you would be putting in DOWNTRIM.
I can understand it FALLING BACK on itself ( that wording indicates model is falling back to INVERTED ). The tail would be pulling her back. If she was balanced correctly - then I would expect this to stop.
solentlife is offline Find More Posts by solentlife
Old Jun 24, 2012, 02:10 PM
gyrocptr is offline
Find More Posts by gyrocptr
Neenah, WI
Joined May 2006
Perhaps both ailerons are trailed-up (?)
gyrocptr is offline Find More Posts by gyrocptr
Old Jun 25, 2012, 02:54 PM
Harold H is offline
Find More Posts by Harold H
United States, NJ, Middle Township
Joined Oct 2011
here again try and balance inverted
Harold H is offline Find More Posts by Harold H
Old Jun 25, 2012, 03:30 PM
BE77 Pilot is online now
Find More Posts by BE77 Pilot
SUPER DOG!
BE77 Pilot's Avatar
Joined May 2010
Does throttle position in level flight make a big difference? If it does I would suspect thrust angle.
BE77 Pilot is online now Find More Posts by BE77 Pilot
Old Jun 25, 2012, 03:46 PM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
I thought 3d planes were balanced tail heavy.
dedStik is offline Find More Posts by dedStik
Old Jun 25, 2012, 03:56 PM
Aberdeen
Joined Mar 2006
Depends what you call tail heavy. Generally they are balanced about neutral, so that they fly upright and inverted without any pressure on the elevator, though some prefer a slightly more forward CG that still needs slight forward pressure on the elvator when inverted.
Old Jun 25, 2012, 05:53 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
Yep, and many fly the 1st flight or so a bit on the nose heavy side and work their way back. I have mine close to neutral and they fly inverted with almost no stick needed. I do not fly 3D, but I use 3D planes for aerobatics and I find that a balance near to what 3Ders use is good for me. That point makes landings easy for me also. They are going to stall unless I use a bit of power and fly them down to near touchdown. Power off will work if you "force" the nose down a bit to keep speed up. I like it that way.
Don
dkrhardy is offline Find More Posts by dkrhardy
Old Jun 28, 2012, 10:27 PM
krexken is offline
Longview, Tx
Joined May 2008
Got a few wind free flights in this morning. It flies level inverted. Anything half throttle or better doesn't change anything, inverted or upright. Ailerons look nice and level. Perhaps wing or elevator incidence is off a bit. Really not a big deal. I'd almost call this plane an aerobatic model and not really 3d. Ailerons are big and elevator is effective but rudder is kinda smallish. Hard to get it pointed back up when it falls to the side when hovering. This thing flat spins like nothing else I've flown though. Loses very little altitude when doing them. Afraid I'm going to burn the motor up doing them. It's so fun and easy to do them. Gonna swith to a 4s setup soon for more snap.
Old Jun 29, 2012, 06:40 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Might be something to do with the throws. Rudder needs to almost touch the elevators. Lots of elevator also. I find the elevator never stops moving when in hover unless you get it dead on vertical, but hard to get that point. In hover, all you depend on is propwash over the surfaces, so you need lots. I've found it helps to pulse the throttle. That way you get more prop blast over the surfaces.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Jun 29, 2012, 10:22 AM
xrx1113 is offline
Find More Posts by xrx1113
xrx1113's Avatar
United States, FL, Lehigh Acres
Joined Aug 2011
I go spin crazy with my stryker lol.
Try going up as high as you can and start the spins and count them , its fun and then you try to beat the old score . it gets interesting when you tru to squeeze just 2 more in lol.
xrx1113 is offline Find More Posts by xrx1113
Old Jun 29, 2012, 12:03 PM
rockom is offline
Find More Posts by rockom
rockom's Avatar
United States, IL, Genoa
Joined Jan 2004
Looks like your 10oz. over the recommended weight using the recommended battery. Where is all the extra weight?
rockom is offline Find More Posts by rockom
Discussion Why does my smaller motor give more thrust ? DaN_Th3_MaN 3D Foamies 13 Jun 17, 2012 12:50 PM
Question Why does my plane pitch up? rollercoaster24 Fuel Plane Talk 12 Mar 19, 2012 02:20 PM
Discussion Why is B400 so much harder than mCPX? HeliDaddy Mini Helis 16 Mar 02, 2012 09:29 AM
why does my soarstar climb so much under power? waagbuck Foamies (Kits) 2 Sep 09, 2001 06:55 PM
