Old Aug 28, 2012, 09:20 AM
oneniner is offline
Find More Posts by oneniner
Riley Winglow
oneniner's Avatar
Belt, Montana
Joined Feb 2007
Thanks for the pictures, Steve. I was wondering if the Calypso had a stiffener tube in the fuselage. That is a good deal. Is it accessible, so a guy could run a 72 MHz antenna in there?
Looking forward to the RX ready model to become available.
Riley
oneniner is offline Find More Posts by oneniner
Old Aug 28, 2012, 09:48 AM
Vintauri is online now
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
Yes Peter, I forgot to mention that my friend also has a calypso and his tail was not tightened down all the way and he had trim issues as well. So it's a good idea to double check that tail screw.
Riley, I'd have to look to see if there is a way to thread a 72 mhz in the fuse tube. I have not had to worry about that for a while so I didn't even look.
Steve
Vintauri is online now Find More Posts by Vintauri
Old Aug 28, 2012, 05:25 PM
drmwmc is offline
Find More Posts by drmwmc
Independence MO.
Joined Mar 2007
Originally Posted by seabass1005 View Post
Drmwmc, Sorry about the mishap. I think I'll check my prop before I fly again!
I wanted to report back with some poor quality videos of my Calypso flights 3 and 4.
http://www.youtube.com/watch?v=FPPHn...ature=youtu.be
The plane was balanced OK as far as I could tell but the trim was way too far forward. If I let go of the elevator, the plane would go into a dive. This issue is me and the radio and not the plane.
I thought your video was pretty good, what camara are you using?.
drmwmc is offline Find More Posts by drmwmc
Old Aug 28, 2012, 09:18 PM
seabass1005 is offline
Find More Posts by seabass1005
Joined Aug 2012
Calypso - Tiny HD camera
Camera is an 808 #16 key chain camera. Found only on Ebay
seabass1005 is offline Find More Posts by seabass1005
Old Aug 29, 2012, 06:43 PM
txg8gxp is offline
Find More Posts by txg8gxp
Joined Aug 2012
Any update on the upgrade?
Originally Posted by Esprit Model View Post
Calypso upgrade
(1) BB 45/3/8mm folding spinner
(1) Aeronaut 9x5 folding propeller
txg8gxp is offline Find More Posts by txg8gxp
Old Aug 31, 2012, 12:28 PM
Greywing is online now
Find More Posts by Greywing
USA, CA, Pismo Beach
Joined Oct 2007
Riley
It depends on whether the stiffener is carbon or not . If it's carbon you'll need to run the 72 Mhz antenna elsewhere.
Greywing is online now Find More Posts by Greywing
Old Aug 31, 2012, 12:37 PM
oneniner is offline
Riley Winglow
oneniner's Avatar
Belt, Montana
Joined Feb 2007
Yes, so they say. Not sure why, but it worked fine in my Art Hobby Sky EV. I ran the long antenna inside the carbon tail boom and had full range. (Had it so high it was just a dot.) In a smaller diameter, thicker tube it may not work.
Old Aug 31, 2012, 12:54 PM
peterlngh is online now
Find More Posts by peterlngh
Joined Apr 2012
We got my friend's Calypso back in the air after he was assaulted by a tree. We must have gotten the nose back on pretty straight cause it flies straight but the canopy doesn't quite fit any more. I still love the slow floating ability but wind penetration, at least with a fairly aft CG, isn't its strong suit. Has anyone tried ballasting theirs for windier days?
peterlngh is online now Find More Posts by peterlngh
Old Aug 31, 2012, 07:09 PM
Joined Oct 2007
I think you should count yourself as lucky. You probably had some part of the antenna that extended outside the aft end so it wasn't totally masked. The Art Hobby tailboom is a carbon fiber and fiberglass composite so it may not be totally opaque to RF signals. Carbon is like a shield to RF signals which is why the 2.4 MHz antenna whiskers are always put outside of carbon pods and fuselages.
Old Aug 31, 2012, 08:25 PM
rabshell is offline
Find More Posts by rabshell
Eastern PA
Joined Feb 2011
Calypso review follow up - loose tail
After 1st flight (flew great) tail seemed a bit loose. Tightened assembly screw a bit. Seemed a little better. 2nd flight, no issues. Flew fine. Checked tail, loose again. Tried to tighten screw, but it felt tight as should be. Packed it up, brought it home. Didn't want to lose control in flight.
On the bench, dis-assembled the tail section. Checked screw depth in nut, it bottoms out in nut, looks like the threads are slightly crossed, maybe mis-aligned. Gently tried to re-thread screw in to nut while apart. Doesn't want to go past depth of nut. Appears the screw cannot be tightened enough to provide a tight connection between fuse and elevator. I don't want to force the screw any tighter since the nut is housed (cemented) in a plastic assembly.
Two good flights, no crashes, perfect soft landings in grass field. Hate to do it, but I guess it should go back to the LHS. No other Calypsos on the shelf right now. Hope the CS is better than HK stories.
Just finished the flap install tonight. Guess I won't get to try them out now. Darn shame, I love this plane. Anyone else have an issue with this assembly point?
rabshell is offline Find More Posts by rabshell
Old Aug 31, 2012, 08:48 PM
KRProton is offline
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
I'm quite certain a call to Hobby Services should provide assistance (new parts if no way to remidy?).
If you want to mess with it yourself at home first, you should be able to extract the nut from the tab in the vertical stab. Then, maybe a new nut and bolt from the hardware store? Either 4mm or 5mm - I can check from work, but not until Tuesday.
Tim
KRProton is offline Find More Posts by KRProton
Old Aug 31, 2012, 09:05 PM
rabshell is offline
Eastern PA
Joined Feb 2011
What keeps the screw head from pushing through the fuse? Is there a washer or stop inside? I hope it is simple as you said, but if not, I would hate to mess up a brand new plane. The nut is glued in the plastic retainer. Not sure I can get it out without breaking or loosening the assembly.
Stopping by the LHS tomorrow, see what they say. If I try to repair it and it doesn't correct it, I want the option to return for a replacement.
Old Aug 31, 2012, 09:49 PM
G-LO is offline
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Well, you can do all those things. Oor you get the part at ebay
G-LO is offline Find More Posts by G-LO
Old Aug 31, 2012, 09:57 PM
rabshell is offline
Eastern PA
Joined Feb 2011
I would hope the LHS and Hobbico would help me with this problem on a one week old plane with two flights. If not, they would be no better than overseas suppliers.
Old Aug 31, 2012, 10:09 PM
KRProton is offline
KRProton's Avatar
Champaign, IL
Joined Dec 2009
I'm just trying to help. There isn't very much I can do on the weekend over the internet.
What keeps the screw from pushing through the foam is the tube inside the fuselage - the screw goes through the tube up into the nut in the clamp that secures the vertical stab.
If the threads are crossed in the screw it should be a simple matter of getting a new screw. If the threads are crossed in the nut...same thing. If you cannot extract the nut without damaging the vertical stab or the clamp maybe you could run a tap up through it? If that's not an option, I'm sure we can replace your vertical stab (with a new nut therein).
I'm not sure if your hobby shop will be able to help (maybe they can). If there is something wrong with your plane/defective parts I'm sure Hobby Services will assist.
Sincerely sorry.
Tim
Discussion Flyzone Calypso george@dream-flight Electric Sailplanes 127 Today 08:03 PM
For Sale Flyzone cessna 182 ep rtf 2.4 radio mike robson Aircraft - Electric - Airplanes (FS/W) 3 Apr 07, 2012 08:23 PM
Discussion How to set up and trim an EP glider JJ460 Electric Sailplanes 2 Mar 24, 2012 08:27 PM
Wanted Wanted, Electric flightnose cone for Calypso contest F3B glider graham johnson Aircraft - Electric - Airplanes (FS/W) 0 Dec 06, 2008 04:35 PM
