Old Jun 03, 2013, 07:54 AM
ripacheco is offline
Find More Posts by ripacheco
rip
ripacheco's Avatar
United States, FL, Niceville
Joined Jan 2013
Originally Posted by netarc View Post
flew my new calypso this weekend, it's a pure joy - very floaty, great little performer. Was doing loops on the 2nd flight ... didn't try any rolls yet, curious to see whether it'd do that.
One thing - I started out with an 1800mah battery, with which it performed great; when I switched back tot he 1300mah battery, I had to push the battery all the way forward in the hatch AND add a couple of lead weights in order to get the glider to balance at the recommended points - not a big deal, but just kind of surprising that the stock battery wouldn't allow for the recommended balance on its own?
My thunderpower 1350 mAh battery balances the plane being pushed all the way to the front
my Cheetah 1300 mAh battery needs to be pushed a bit back.
Otherwise it balanced well within the range indicated.
ripacheco is offline Find More Posts by ripacheco
Old Jun 03, 2013, 07:55 AM
rip
ripacheco's Avatar
Joined Jan 2013
Did you find the recommended throws to be "too much" when you first started flying the plane?
Old Jun 03, 2013, 10:43 AM
netarc is offline
Find More Posts by netarc
netarc's Avatar
Joined Apr 2013
Not at all...Plane was responsive, but not twitchy. I tried first low, and then high rates of my tx.
I started the flaps mod, and I'm thinking to move the aileron servo rods from the 1st (farthest) hole on the servo horn to the last (closest) to account for the lessened surface area, since with flaps the aileron loses 1/3 of its length. Thoughts?
netarc is offline Find More Posts by netarc
Old Jun 03, 2013, 01:08 PM
rip
ripacheco's Avatar
Joined Jan 2013
If u have a Computer radio have the flaps move with the ailerons.
If u don't them u will have to compensate more
BUT
keep in mind that the closest to the wing the less effective ailerons are so you prob won't miss much aileron authority
Old Jun 03, 2013, 01:11 PM
GTstrudl is online now
Find More Posts by GTstrudl
GTstrudl's Avatar
United States, MA, Boston
Joined Oct 2011
Flew Calypso second time, the maiden (with 2200 mAh battery) ended with crash. Have to push 1300mAh battery all the way to the front. At the recommended CG, she was not floaty at all. Had to continuously push throttle more than 70% to maintain altitude. I flew at about 50', how about you? Stock ESC was extremely hot at the end of 4 min. flight.
GTstrudl is online now Find More Posts by GTstrudl
Old Jun 03, 2013, 01:49 PM
rip
ripacheco's Avatar
Joined Jan 2013
Keep in mind that because of the way they work, ESC will get hotter a low power settings than at full power.
When I fly the calypso I go full-power climb to altitude and then I shut the motor off. When I've lost too much altitude I repeat the drill. My ESC never gets more than slightly warm.
Old Jun 03, 2013, 01:50 PM
rip
ripacheco's Avatar
Joined Jan 2013
The CG range is very generous. I have to admit though I do not have it close to the rearmost of the range. I have it square the middle or slightly forward.
Old Jun 03, 2013, 01:52 PM
GTstrudl's Avatar
Joined Oct 2011
So how high in you case?
Old Jun 03, 2013, 01:53 PM
GTstrudl's Avatar
Joined Oct 2011
Me too.
Old Jun 03, 2013, 02:08 PM
rip
ripacheco's Avatar
Joined Jan 2013
I climb as far up as I feel comfortable. Your eyes tell you so.
I let the model go down to about 20 feet then I apply power and climb back up. Trying to catch thermals.
Old Jun 03, 2013, 02:49 PM
GTstrudl's Avatar
Joined Oct 2011
Got it. I'll try this way on my next flight. Thanks
Old Jun 04, 2013, 11:02 PM
GTstrudl's Avatar
Joined Oct 2011
Fuselage set has already discontinued on TH site. So quick ?
Old Jun 04, 2013, 11:55 PM
Fentonflyers is offline
Find More Posts by Fentonflyers
United States, MO, Fenton
Joined Jan 2012
Just the V1
Fentonflyers is offline Find More Posts by Fentonflyers
Old Jun 05, 2013, 10:48 AM
Willie T is offline
Find More Posts by Willie T
What goes up, will come down..
Willie T's Avatar
United States, FL, Zephyrhills
Joined Jun 2011
Per telemetry, I go up to 500ft. I may go higher when I become more comfortable but that is about it for now.
Willie T is offline Find More Posts by Willie T
Old Jun 05, 2013, 11:26 AM
rip
ripacheco's Avatar
Joined Jan 2013
Good eyes to see this glider that high
Discussion Flyzone Calypso george@dream-flight Electric Sailplanes 93 Jan 13, 2016 04:15 AM
For Sale Flyzone cessna 182 ep rtf 2.4 radio mike robson Aircraft - Electric - Airplanes (FS/W) 3 Apr 07, 2012 09:23 PM
Discussion How to set up and trim an EP glider JJ460 Electric Sailplanes 2 Mar 24, 2012 09:27 PM
Wanted Wanted, Electric flightnose cone for Calypso contest F3B glider graham johnson Aircraft - Electric - Airplanes (FS/W) 0 Dec 06, 2008 05:35 PM
