Old Apr 22, 2013, 01:50 PM
HARD DRYVE is offline
Find More Posts by HARD DRYVE
Puerto Rico, MayagŁez
Joined Jan 2011
Originally Posted by ripacheco View Post
That is good. This will be a good sport-competition plane.
I may put a scorpion motor in the front and a better prop:
http://www.scorpionsystem.com/catalo...I-3008-1090KV/
I hope it fits. but I cannot find any tech drawings of the nose.
Maybe this helps? from towerhobbies Calypso replacement motor specs:
*This is the C28-30 Brushless 1100kV Motor
For the Flyzone Calypso Glider
FEATURES: Red and silver colored case
INCLUDES: One Brushless Motor
REQUIRES: (2) 3mmx6 Mounting Screws
SPECS: Bullet connectors: 3mm
Motor wire length: 2.5in (64mm)
Motor rating: 1100kV
Diameter: 1-3/32" (28mm)
Length: 1-3/16" (30mm)
Shaft diameter: 3mm
http://www3.towerhobbies.com/cgi-bin...?&I=LXCGHU&P=Z
HARD DRYVE is offline Find More Posts by HARD DRYVE
Old Apr 22, 2013, 02:29 PM
ripacheco is offline
Find More Posts by ripacheco
rip
ripacheco's Avatar
United States, FL, Niceville
Joined Jan 2013
Shaft diameter: 3mm
that is a 28mm dia motor. prob means that the 30mm scorpion will not fit.
ripacheco is offline Find More Posts by ripacheco
Old Apr 22, 2013, 08:02 PM
Sukhoikid is online now
Find More Posts by Sukhoikid
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
My lights came out great! Kind of toooo bright lol
Night Glider (0 min 36 sec)
Sukhoikid is online now Find More Posts by Sukhoikid
Old Apr 22, 2013, 08:23 PM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
Best.
Airplane.
Horn.
EVAR!!!!!
StarHopper44 is offline Find More Posts by StarHopper44
Old Apr 22, 2013, 08:27 PM
rip
ripacheco's Avatar
Joined Jan 2013
http://www.youtube.com/watch?v=yH6zhaU7P1Q
awesome
Old Apr 22, 2013, 10:29 PM
rip
ripacheco's Avatar
Joined Jan 2013
Flap Linkage Question
I FORGOT to order the $3.00 flap linkage kit... Grrr... Do i need to use their kit or can I use normal control horns. somethign special about them?
Old Apr 23, 2013, 08:00 AM
Westranm is online now
Find More Posts by Westranm
Westranm's Avatar
United States, AZ, Chandler
Joined Jan 2011
Esprit Models recommends Hacker A20 22L which is a much lighter motor than the Scorpion one mentioned. I have one in another plane--I may pull it out to try in my Calypso. Even if the Scorpion fits, I would be concerned about the added nose weight.
-Randy
Westranm is online now Find More Posts by Westranm
Old Apr 23, 2013, 08:52 AM
ombudsman is offline
Find More Posts by ombudsman
Oklahoma
Joined Sep 2010
The only "special" thing included in their flap kit is the pair of plastic shrouds. Those should be easy enough to replicate, one way or another. I am very glad I installed the flaps. Big difference in short-field landing.
Dave
ombudsman is offline Find More Posts by ombudsman
Old Apr 23, 2013, 08:57 AM
rip
ripacheco's Avatar
Joined Jan 2013
-Randy
Yes you are right. The Scorpion motor I mentioned is simply put not the right motor for this plane. I will put an Scorpion ESC I have on hand and run the stock motor to its limit. And plan to upgrade to Hacker or other motor if the stock motor does not fit the bill.
I'm seeing this plane being used in sport ALES competitions... can't wait to take it to the field.
Old Apr 23, 2013, 09:00 AM
rip
ripacheco's Avatar
Joined Jan 2013
Dave
Or precision landing... I wonder if I can compensate the lack of flaps by mixing flaperons there. I'm trying to get the linkages from my LHS... it seems wrong to order 3.00 worth of parts and pay 10.00 worth of shipping from the internet.
Old Apr 23, 2013, 09:10 AM
Fentonflyers is online now
Find More Posts by Fentonflyers
United States, MO, Fenton
Joined Jan 2012
Your LHS should be able to order them for you without the shipping expense. For wiw there are no shrouds for the servo since it stands upright.
Fentonflyers is online now Find More Posts by Fentonflyers
Old Apr 23, 2013, 10:10 AM
Oklahoma
Joined Sep 2010
Yes, you're right. After your post, I actually looked at the plane (duh!) and saw that there is nothing special at all in the "flap kit." Sorry.
Dave
Old Apr 23, 2013, 12:09 PM
rip
ripacheco's Avatar
Joined Jan 2013
Dave
that is good news to me.
When I get the plane tomorrow. I'll take it to my LHS and tell the nice man that runs it to give me what I need to get it to work.
Hopefully my Futaba 3015 Servos will be ok:
http://www.gpdealera.com/cgi-bin/wga...pgm?I=FUTM0415
ESPRIT models recommends:
http://www.hitecrcd.com/products/ser...ini/hs-55.html
I prefer Futaba on all my radio stuff.
Old Apr 23, 2013, 01:20 PM
Westranm's Avatar
Joined Jan 2011
I just replaced a wing servo that came with the Calypso with the Hitec servo mentioned. I found it is a drop-in replacement with equivalent weight and performance.
The Futaba servo you mention weighs 2x the Hitec and is a bit larger than the recommended servo. You will need to cut some foam to make it fit.
-Randy
Old Apr 23, 2013, 01:34 PM
rip
ripacheco's Avatar
Joined Jan 2013
Just occurred to me, the servos included in the kit should plug into a futaba RX without adaptors right?
If I get the hitec servo I need a special extension I think?
Discussion Flyzone Calypso george@dream-flight Electric Sailplanes 107 Jul 24, 2016 03:18 AM
For Sale Flyzone cessna 182 ep rtf 2.4 radio mike robson Aircraft - Electric - Airplanes (FS/W) 3 Apr 07, 2012 08:23 PM
Discussion How to set up and trim an EP glider JJ460 Electric Sailplanes 2 Mar 24, 2012 08:27 PM
Wanted Wanted, Electric flightnose cone for Calypso contest F3B glider graham johnson Aircraft - Electric - Airplanes (FS/W) 0 Dec 06, 2008 04:35 PM
