Old Nov 07, 2012, 07:48 PM
txg8gxp is offline
Find More Posts by txg8gxp
Joined Aug 2012
I just re did mine with a torque 20t/1030 and a cam 10x8 prop. amperage draw in equal to or less then factory i'm sure. I haven't tested amp draw with the 10x8 yet but was only pulling 12-13 max with a 9x5 and I was pulling 18 with the factory motor. The pull is great with this new setup, twice factory for sure.
txg8gxp is offline Find More Posts by txg8gxp
Old Nov 12, 2012, 12:09 AM
Glidertech is offline
Find More Posts by Glidertech
New bee to the sport.
Joined Nov 2012
Few question for those out there with a Calypso. Can please tell me where your CG is located along with your decledge changes. I bought a RTF how far can I expect the range the radio will guide the glider. Thanks for your help in me learning my new sport.
Glidertech is offline Find More Posts by Glidertech
Old Nov 12, 2012, 04:21 AM
ombudsman is online now
Find More Posts by ombudsman
Oklahoma
Joined Sep 2010
CG ~1/4 inch forward of the spar visible on the bottom of the wing.
Rear of horizontal stabilizer shimmed 1/8".
Others can speak to the range of the Tx-ready system.
Have fun with your glider!
Dave
ombudsman is online now Find More Posts by ombudsman
Old Nov 12, 2012, 05:49 AM
ory69 is offline
Find More Posts by ory69
....left up, right down !!!
ory69's Avatar
United States, OR, Depoe Bay
Joined Nov 2010
Range
If you are truly new to this sport, I can offer meager answers. If you are a bit experienced, then you already know what I do.
If your plane has a standard transmitter and standard receiver you will have enough range to LOSE that airplane while still under control. In other words, you can fly as far out and as high as you would dare while still being able to see its flight attitude.
If you have the Tactic brand "Anylink" set-up, your range will be slightly less, but I am told it will still allow you to have control while at nearly the limits of flight attitude visibility. Others ?......
ory69 is offline Find More Posts by ory69
Old Nov 14, 2012, 12:00 PM
Pimimo is offline
Find More Posts by Pimimo
The Big Pimimo
United States, FL, Miami
Joined Feb 2008
This is my Calypso flying ...
Calypso First Flight... (10 min 3 sec)
Enjoy...
Pimimo is offline Find More Posts by Pimimo
Old Nov 15, 2012, 01:26 AM
Joined Nov 2012
Well my glider arrived from KY today. I had bought it while on business and shipped it to my next stop here in Fresno. I will set it up in the morning and look to try my hand at getting this thing trimmed and ready for a successful first flight. Thank you for the answers to my radio range an cg questions. I'm sure I will have many more to come.
Old Nov 18, 2012, 08:34 PM
Citationfxr is offline
Find More Posts by Citationfxr
United States, PA, West Chester
Joined May 2012
This weekend I added approx 1/8" shim to the aft side of the horizontal stab as others suggested here to alleviate the sharp pitch down with power off. I just used two small pieces of balsa CA'd together and then CA'd to the aft portion of the horizontal stab to decrease the angle of incidence and it DOES make a difference in flight.
With power on I had to take away some of the up elevator trim and when I brought power back (not too quick), the nose did not drop as before. I guess the best way to put it is the plane "sailed" with power off, instead of me working the elevator in some balancing act to maintain forward tracking without losing so much altitude. A huge thank you to those suggesting this mod in this thread, I was happy with this purchase before and after this evening's flight I'm very happy!
Citationfxr is offline Find More Posts by Citationfxr
Old Nov 18, 2012, 08:45 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
....what motor/prop upgrade are you guys using?
I saw the video on there website and its grossly underpowered....
Thanks!
(I had a Radian with custom motor mounts for upgraded motor,
does the Calypso need a custom motor mount for upgraded motor?)
http://www.rcgroups.com/forums/showthread.php?t=1361677
LexusFPV is offline Find More Posts by LexusFPV
Old Nov 18, 2012, 09:44 PM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
Great news, Citationfxr. This bird floats very nicely. I have also found that slowly reducing throttle gets rid of the rest of the pitching down.
I don't think the Calypso is underpowered, LexusFPV. It won't set any time to height records but the stock motor seems more than adequate. And I say that despite the fact that I have a Specter 1800 that will climb nearly out of sight in 10 seconds. If you want a screaming climb then the KD A22-20L I use in the Specter would be hard to beat but you would probably have to add a few grams of weight, in addition to the aforementioned shim, in the tail. My best climb rate came with an 11X6" prop, that I keep breaking on the only rock in the landing area, but just about anything between 9 and 11 inches will work just fine. However, with anything over a 9 inch prop, you will need at least a 30amp ESC. The motor itself might even handle a 12 inch prop but I haven't tried it myself.
Here's a link to the only place I know that currently has the motor in stock.
http://www.giantshark.co.uk/a22l20l-...otor-p-49.html
The stock motor mount is a bit flimsy but it has standard hole placement. I fixed the mount for my buddy, after he hit a tree, by doubling it with 1/32" plywood and epoxy and it's been good since then.
peterlngh is offline Find More Posts by peterlngh
Old Nov 19, 2012, 10:19 AM
GTstrudl is online now
Find More Posts by GTstrudl
GTstrudl's Avatar
United States, MA, Boston
Joined Oct 2011
I got a Rx-R version. The interesting thing is the 3.5mm connectors on the ESC's battery side are both male. I was told by Flyzone that the battery sold by Flyzone would have two female connectors. I thought for 3.5mm or 4.0mm connector, because all the metal connectors are shielded by the plastic cover, it should have one male and one female within the plastic cover?
GTstrudl is online now Find More Posts by GTstrudl
Old Nov 19, 2012, 11:14 AM
Oklahoma
Joined Sep 2010
RC batteries always have female connectors. The plastic connector housings may have a "male" and "female" side (e.g. EC3), but the actual connectors are always female.
Old Nov 19, 2012, 11:51 AM
GTstrudl's Avatar
Joined Oct 2011
Just look at the attached photo. The ESC has one female and one male connector. The battery has the same thing. I understand that as for electrical connection concern, it doesn't make any difference.
Old Nov 19, 2012, 12:31 PM
gentle ben is offline
Find More Posts by gentle ben
semper mitis
gentle ben's Avatar
Paducah, Kentucky
Joined Nov 2004
Those type connectors are just a ploy to try to lock in use of Parkzone batteries. Since those batteries are a little rich for my blood, the speed controller gets it's a connector clipped and the appropriate Dean's connector/ T connector is soldered in. I have adapters that will fit in between all of the batteries that I purchase. The adapters are ridiculously easy to make.
gentle ben is offline Find More Posts by gentle ben
Old Nov 19, 2012, 12:39 PM
Joined Apr 2012
My very first LiPo came with 4mm bullet connectors so I just decided that I would go with them for all my batteries and ESCs. Then i discovered that the plastic housings differ just a bit between brands. So? I use the bullet connectors with shrink tube instead of the plastic housings. This works out beautifully because it saves a bit of bulk and one can even run the wires along opposite sides of the battery or anything else in the way.
Old Nov 19, 2012, 02:15 PM
Greywing is offline
Find More Posts by Greywing
USA, CA, Pismo Beach
Joined Oct 2007
Actually, the connector housing on the battery is female even though there is one male pin and one female socket inside the housing to maintain polarity. The point is to have the pins covered to help prevent shorting out the live battery pins although I believe the style of housings in your picture cover the pins in either case. On the more common deans connectors, the pins are fully exposed on one half of the mating pair.
Greywing is offline Find More Posts by Greywing
Discussion Flyzone Calypso george@dream-flight Electric Sailplanes 93 Jan 13, 2016 03:15 AM
For Sale Flyzone cessna 182 ep rtf 2.4 radio mike robson Aircraft - Electric - Airplanes (FS/W) 3 Apr 07, 2012 08:23 PM
Discussion How to set up and trim an EP glider JJ460 Electric Sailplanes 2 Mar 24, 2012 08:27 PM
Wanted Wanted, Electric flightnose cone for Calypso contest F3B glider graham johnson Aircraft - Electric - Airplanes (FS/W) 0 Dec 06, 2008 04:35 PM
