Old Oct 08, 2012, 01:21 PM
G-LO is online now
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Originally Posted by DLG fan View Post
I am also eagerly awaiting a Calypso ARF. I preordered one from Hobbyzone and the anticipated delivery date was originally 9/10. This got pushed back to 10/10 and now 10/20 for both the RxR and ARF. The only real delivery date you can believe is when it shows up on your doorstep. What ticks me off is that all of the spare parts you need for an ARF have been in stock for weeks. I could assemble an ARF now but at a much higher cost.
Don't make sense to me either. I'm waiting for the same thing. The only thing they have to do is what...take the motor and the radio out? With all this wait, you would think it supposed to be new and improved or something .
G-LO is online now Find More Posts by G-LO
Old Oct 08, 2012, 02:12 PM
KRProton is offline
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
There's a shipment of ARFs (FLZA3006) actually in transit scheduled to arrive 10/22 barring anything unforseen.
Tim
KRProton is offline Find More Posts by KRProton
Old Oct 08, 2012, 02:32 PM
Himself is offline
Find More Posts by Himself
Joined Aug 2012
Tim
And the RxR (FLZA3004)?
Himself is offline Find More Posts by Himself
Old Oct 08, 2012, 03:20 PM
KRProton is offline
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Same deal - they're in transit and computer says they're due on the 22nd. Must be in the same container - again, barring anything unforseen - and I can't make any guarantees - just going by what I see on the computer.
Tim
Old Oct 08, 2012, 03:24 PM
Vintauri is offline
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
Originally Posted by rycomm View Post
We have found that if you use lighter batteries (1300s) moved to the rear of the compartment, this moves the cg back a bit, which helps the up trim issue, and the plane seems to fly better. We were getting 20+ min flights with about 4 climbs in dead air. I was also doing 5 sec motor runs, then attempting precision landings. All very fun, and great practice.
I've also considered embedding an ounce or so in the rear of the fuselage to see if that makes any difference. It wouldn't affect the wing loading enough to be noticable, but it may help the trim issue a bit. However, the Calypso I've been flying is not mine, so it is up to the owner.
Ryan
I'll second this setup. I first flew mine with a 3s 2100 and found it needed a fair amount of up trim to fly but with a 3s 1300 it climbs better and needs very little up trim.
Steve
Vintauri is offline Find More Posts by Vintauri
Old Oct 08, 2012, 07:24 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
LOS maiden went well. I put my gopro on my head and tried to record video, but it was angled to far up. You can still see the glider in many cases, but it's just the glider against blue sky. Handlaunch was uneventful, used a good amount of up trim.
For gliding in general, it needed a decent amount of up trim, using the stock 1300 in a slgihtly nose heavy attitude. Climbouts were strong, although not blistering.
Got about 20 minutes on the 1300, although I didn't really push it. I have a feeling my battery was only about 60% depleted, though I didn't check.
I ran right home after the successful maiden and began work on the FPV system. I'm using a Fatshark CCD killer camera, an Immersion 600MW 5.8ghz transmitter, and a Cloverleaf antenna on the transmitter. The fatshark camera comes with a Pan/Tilt setup, and I added a servo stretcher on pan, so I can look 180 degrees back and forth. The transmitter and camera are powered by a 3S 1000mah. Here are pics for those interested:
The 3S 1000mah velcro's to the side of the canopy, were the hard velcro is.
I'm using some fatshark predator goggles, with a Turbine antenna on the reciever, and have headtracking enabled and all ready to go.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Oct 08, 2012, 07:52 PM
Himself is offline
Joined Aug 2012
Tim
Thank you very much, Tim.
Richard
Old Oct 09, 2012, 08:34 PM
Team White Llama!
FPV maiden went off without a hitch. This camera has a narrower lens than I'm used too, but it was really nice for looking down over the nose of a floating sailplane
It's hard for me to judge altitude with this lens at the moment, so no idea how high I got, but I had crystal clear video the whole time. Really relaxing, for a change.
I swapped connectors, so tomorrow morning I'll have four 2500's to run through it. My timer is set to 7 minutes, and is only activated when the throttle is above 10% (basically, timer is only counting when the motor is on, gliding doesn't reduce time). So hopefully, with 4 2100's, I should get a decent amount of flying in tomorrow morning.
Old Oct 10, 2012, 06:03 PM
george@dream-flight is offline
Find More Posts by george@dream-flight
Wind Powered
george@dream-flight's Avatar
United States, CA, Goleta
The Calypso is super fun on the slopes! I maxed out the mechanical throw everywhere...and it carves very well in slope lift. I plan on building a pure glider version for more slope flying when the ARFs ship.
Flyzone Calypso Slope Style (0 min 33 sec)
george@dream-flight is offline Find More Posts by george@dream-flight
Old Oct 10, 2012, 06:53 PM
Greywing is offline
Find More Posts by Greywing
USA, CA, Pismo Beach
Joined Oct 2007
Looks nice George. Did you shoot that today? Where abouts is Elwood Bluffs?
Greywing is offline Find More Posts by Greywing
Old Oct 11, 2012, 12:35 AM
Wind Powered
Hey. Nope..a little over a week ago. I forgot it was on my phone ;-).
Check out this link for some Ellwood info.
http://www.sbslopers.org/index.php?pid=2
George
Old Oct 11, 2012, 06:37 AM
ory69 is offline
Find More Posts by ory69
....left up, right down !!!
ory69's Avatar
United States, OR, Depoe Bay
Joined Nov 2010
George
George. Thanks for posting that. First time I've seen the Calypso sloping.
Wow. It looks fairly fast along that crosswind leg down the beach, and it turned in, downwind, very responsively and recovered to cross slope without hesitation. Would you say that this is a fairly good "performance sloper"? I innitially thought it was a beginner's sailplane, but judging by what I just saw I think it will really perform. It reminds me of the old Hobie Hawk with the first ever eliptical wing. That bird really hauled AND was rigid and nearly indistructable. Would you say that the Calypso is as well?
Thanks, Robert
ory69 is offline Find More Posts by ory69
Old Oct 11, 2012, 08:54 AM
Greywing is offline
Joined Oct 2007
Thanks for the info George.
Old Oct 11, 2012, 11:08 AM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
Hi, ory69.
The Calypso is really nothing like the Hobie Hawk. It's foam so it will take some impact but the similarity ends there. It's much lighter and has a thicker airfoil so, while it will fly faster than some other foamies, it will also float at low speeds.
peterlngh is offline Find More Posts by peterlngh
Old Oct 11, 2012, 11:58 AM
Wind Powered
Having always wanted one...but never owning or flying a Hobie Hawk...I can not compare the two.
It is fun affordable well rounded floater.
Discussion Flyzone Calypso george@dream-flight Electric Sailplanes 93 Jan 13, 2016 03:15 AM
For Sale Flyzone cessna 182 ep rtf 2.4 radio mike robson Aircraft - Electric - Airplanes (FS/W) 3 Apr 07, 2012 08:23 PM
Discussion How to set up and trim an EP glider JJ460 Electric Sailplanes 2 Mar 24, 2012 08:27 PM
Wanted Wanted, Electric flightnose cone for Calypso contest F3B glider graham johnson Aircraft - Electric - Airplanes (FS/W) 0 Dec 06, 2008 04:35 PM
