Old Jun 24, 2012, 05:45 AM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
Can someone tell me how fast this goes
Can someone do a doppler on this video, I am wondering how fast it flys...
http://www.rcgroups.com/forums/showp...postcount=1462
Thank in advance.
frank40 is offline Find More Posts by frank40
Old Jun 24, 2012, 12:06 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
I will guess 105 mph..sorry no doppler on hand
Old Jun 24, 2012, 12:11 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Thank in advance.
There's a lot of wind and background noise to it's going to be hard to Doppler...Even people talking close to the mic can make pulling out the audio for Doppler difficult...However, @ 1:21 into the vid I did get an RC Speedo clocking of 103.4MPH...It's been my experience that the RC Speedo app shows about a couple of MPH faster than Doppler...Still, 103MPH ain't too shabby for as small as these models are and now at least you now have an idea of what it was doing...Get more runs without the windy background noise...If you can't get a vid without wind noise, fashion a wind muffle from some open cell soft foam...This will keep the wind from whipping across the face of the mic...
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Jun 24, 2012, 12:12 PM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Frank,
If you do not ha e your answer shortly I will Doppler it for you..
My daughter is on Netflix...and when she's done with her movie I will get it dopplered..
The program is right here in this forum..just need both my comps to do it..play it on the laptop and listen(Doppler) through the tablet....
I'll check back in 2 hours or so..
Edit,
Ah Kevin got you while I was posting...lol....
Hover or die is offline Find More Posts by Hover or die
Old Jun 24, 2012, 12:14 PM
flemsus is offline
Find More Posts by flemsus
Denmark, Nordjylland, Gistrup
Joined Aug 2005
Frank du skal have et godt tilløb og så skal du helst fortsætte ligeud i 2 sekunder efter flyet har passeret kameraet. Så skal de også vide hvad temperatur der er under flyvningen.
Mvh. Flemming
I am just trying to tell him how to make a god doppler run.
flemsus is offline Find More Posts by flemsus
Old Jun 24, 2012, 12:21 PM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Thanks for your replays, I will se if I can't get anointer video. Chris I will be happy if you could give it a try.
Old Jun 24, 2012, 04:12 PM
Joined Mar 2007
Originally Posted by Hover or die View Post
Frank,
Edit,
I didn't Doppler it but used the RC Speedo phone app so if any of you want to confirm what I got with Doppler I welcome it as I'm wanting to see/confirm how accurate RC Speedo is...
Frank---I don't know how to read Danish but it looks like our European friend was reminding us that we need to know the temperature...My RC Speedo app was used when my local temp was 94* which I'm sure your temp was lower...
I've gotta say though that Turbonut posted while I was getting the speed and his guess of 105MPH being as close to what I got is impressive!!!.....
Kevin
Old Jun 24, 2012, 10:55 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Shucks it is just my fine tuned sence of smell...ha
Old Jun 25, 2012, 09:16 AM
TheTick is offline
Find More Posts by TheTick
Spoooooon!
TheTick's Avatar
San Fernando Valley, California, United States
Joined May 2003
It's difficult to get clean doppler on that. You'll need to fly level across the camera without climbing or turning after the pass for a couple seconds. Also, don't cut the throttle during the pass. Don't forget to do up wind and down wind passes so you get the true speed. Good luck!
TheTick is offline Find More Posts by TheTick
Old Jun 25, 2012, 09:55 AM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Very fact nice speed that is we looking for this feel !!!!!!!!!! What is that models ?
kin is offline Find More Posts by kin
Old Jun 25, 2012, 11:36 AM
Joined Mar 2011
Frank,
I use the same program s Kevin uses...RCSpeedo..
It has a very hard time reading through the wind...
next time you video use the method the Tick suggested...Level passes without touching the throttle...
and we will be able to get a clean reading....
take care...............chris
Old Jun 25, 2012, 02:51 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
looks about 80mph
stoneenforcer is offline Find More Posts by stoneenforcer
Old Jun 25, 2012, 03:19 PM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Thanks again...
I can se this video is no good, after reading your replays I realized other factors as well. For most of this flight I fly with about 50-60% throttle, only one pass at full power....and the fact the the model is flying at a angle at about 30 degrees toward me, may also affect the result. I guess I have to make another video. I would estimate it to go as fast as 200 Km/h thats 125 mph with full power, but this is only a estimation.
The model is a joined design project that I started for about a year ago here in RC groups, for more info look here: http://www.rcgroups.com/forums/showthread.php?t=1428925
Temp. was around 65-70 Fahrenheit
Old Jun 25, 2012, 03:38 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Can the two passes here be dopplered?
Andy
Untitled (0 min 43 sec)
falcon5 is offline Find More Posts by falcon5
Discussion Can someone tell me what type of connector this is? ImAcracker FPV Talk 6 Jun 14, 2012 08:26 AM
Discussion Can someone tell me what this is bradenj Fuel Plane Talk 17 Jun 07, 2012 08:36 PM
Discussion Can someone tell me who makes this plane and where I can find one? Hydroman Fuel Plane Talk 4 Mar 27, 2007 02:00 PM
can someone tell me why this happened? gouch Life, The Universe, and Politics 15 Aug 20, 2003 12:07 PM
Can someone tell me what this motor is for? Bonafidepirate Parkflyers 10 Jan 07, 2002 08:33 PM
