Old Jun 24, 2012, 05:14 AM
geoffers0_0 is offline
Find More Posts by geoffers0_0
I'd rather be.....
geoffers0_0's Avatar
Bristol, UK
Joined Jun 2008
Vac Bagging - how long to keep pressure on?
Hi
Noob- Just venturing into vac-bagging, and I have a simple question: How long is it neccessary to keep the pressure on when vacuum bagging fibreglass onto pre-shaped foam wing cores?
I appreciate that when making (for instance) skateboard decks from layers of rigid flat laminate, where you're bending it into a moulded shape it would be neccessary to keep the pressure on until the glues are fully cured to hold the laminate in the new shape.
However is this neccessary when pressing flexible glass to the shape of the wing? Presumably the vac-bagging here is more to squeeze excess resin out of the laminate and produce a uniform smooth surface.
Is it critical to keep the vacuum applied right through the final cure?
Thanks, G
geoffers0_0 is offline Find More Posts by geoffers0_0
Old Jun 24, 2012, 05:44 AM
KevinSharbonda is offline
Find More Posts by KevinSharbonda
Make Flying Fun
United States, CO, Castle Rock
Joined May 2003
Yes
KevinSharbonda is offline Find More Posts by KevinSharbonda
Old Jun 24, 2012, 10:00 AM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
The "final cure" can take up to 30 days (unless you use heat). Typically, it's only necessary to apply vacuum until the resin has set. The composite laminate at this point will take on a memory. The resin set point varies from resin to resin and is also dependent upon the temperature. Most resins will set within 12 hours. Some slow hardener combinations can take over 30 hours to set at 72*F. If you remove the Mylars at this set point the fabric pattern will print through to the part surface. You don't want to remove the Mylars until the resin has progressed much further in the cure (4 days at room temp - or use heat).
wyowindworks is offline Find More Posts by wyowindworks
Old Jun 26, 2012, 12:42 AM
Bosk is offline
Find More Posts by Bosk
Melbourne, Australia
Joined May 2005
Originally Posted by wyowindworks View Post
... If you remove the Mylars at this set point the fabric pattern will print through to the part surface. You don't want to remove the Mylars until the resin has progressed much further in the cure (4 days at room temp - or use heat).
Do I understand this correctly, if we remove the mylar before about 4 days at room temp, the fg cloth pattern will print through to the surface? So we need to keep it under vacuum with the mylars on for at least 4 days (at room temp)?
I thought that once the resin had set ~24hrs then that was it and the mylars could come off and nothing would change except for the final 10% or so of hardening which could take days-weeks.
Bosk is offline Find More Posts by Bosk
Old Jun 26, 2012, 07:48 AM
Just fly it!
Cody, WY
Joined Nov 2007
You only need to keep the vacuum on until the resin has set (12-30 hours). If you want the best surface finish you shouldn't take the Mylars off for several more days. Do a test. Peel half the mylar off after set and then peel the rest after 4 days. The surface finish difference will be quite obvious.
Old Jul 12, 2012, 07:44 AM
al010964 is online now
Find More Posts by al010964
Australia
Joined May 2010
Hmm... Thanks for that, I have always keen to get the mylars off after about 24 hours and was never 100% happy with end product. Will give it try.
Cheers,
.adrian
al010964 is online now Find More Posts by al010964
Discussion How long is too long to keep lipos fully charged? electricrc68 Batteries and Chargers 4 Jun 19, 2012 04:15 PM
For Sale Sold - Mighty Mini Vac for sale - with wing bag Pflyinguy Aircraft - Sailplanes (FS/W) 4 Mar 04, 2012 04:50 AM
Discussion If followed Radd's school, how long keep training gear on? Trinot Micro Helis 24 Sep 23, 2009 03:31 PM
Lipos keeping their charge on the Shelf? How long BladeBilly Batteries and Chargers 6 Oct 11, 2004 04:43 PM
How to do leading edges on vac bagged wings? chlee Electric Sailplanes 7 Mar 04, 2002 08:37 AM
