Old Nov 10, 2003, 03:30 PM
BING! is offline
Find More Posts by BING!
BING!'s Avatar
usa
Joined Mar 2003
How dangerous are aluminum solder fumes?
I unintentionally inhaled some and I have been having nausea and flu like symptoms since.
I am not sure if the solder is the cause but I am trying to figure my ailment out.
JT
BING! is offline Find More Posts by BING!
Old Nov 10, 2003, 05:40 PM
utahrc is offline
Find More Posts by utahrc
Provo, Utah, United States
Joined May 2002
I'd call poison control before asking E-Zone, but that's just me.
utahrc is offline Find More Posts by utahrc
Old Nov 10, 2003, 06:48 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Not to unduly alarm you, but the inhalation warning on the particular aluminum solder paste covered in the Material Safety Data Sheet linked to below is pretty strong. I also think that you should get a professional opinion. Odds are you have not done serious damage to yourself. But it's just not worth gambling on your long-term health.
http://www.esabna.com/msds/75.pdf
Dave Hederich is offline Find More Posts by Dave Hederich
Old Nov 10, 2003, 09:01 PM
BING! is offline
BING!'s Avatar
usa
Joined Mar 2003
I soldered a lithium poly pack with aluminum solder on Tuesday last week and another on Thursday.
It did not occur to me that I could get flu like symptoms from soldering. I did the soldering as usual on my hobby work bench in my living room. The room is like any indoor living room and is moderately ventilated. I have soldered on that bench countless times but this was the first time using aluminum solder.
I started to feel bad the next day after soldering. This aluminum solder makes more fumes than the usual lead, tin or silver solder.
Symptoms were joint aches, nausea, the CHILLS and fever (and little stumbling/disorientation).
I only started to suspect the aluminum solder after I had a relapse thursday (after soldering the second pack) and the fact that I do not get sick too often.
I really thought that it was "FAR OFF" that soldering could cause me to be sick like I was and I did not want to go to a hospital emergency room.
I called the poison control as advised and I have been told that I likely have METAL FUME FEVER as a result of soldering. The main culprit is tin and flourine fumes they say. If I do not get better in another 48 hours, I was advised to see a doctor due to resulting infection due to my body weakening from the POISONOUS fumes.
I am posting this as footnote to my post. I did not know any better. I should have gone straight to a doctor but I thought it was just a bout of the flu. I AM AN IDIOT. I hope this post makes others know better.
Old Nov 11, 2003, 12:19 AM
Mikey C. is offline
Find More Posts by Mikey C.
"Hobby Apparatus" Flyer
Mikey C.'s Avatar
Oxford, PA
Joined Aug 2003
Hope you get better BING. Lesson learned, ok? We all make errors in judgement from time to time...
Mikey C. is offline Find More Posts by Mikey C.
Old Nov 11, 2003, 01:23 AM
Dax is offline
Dax
Find More Posts by Dax
Dax
There is no spoon
Dax's Avatar
Vancouver BC Canada
Joined Aug 2002
I'm glad you posted this because I wouldn't have thought twice about soldering amuminium on my hoby bench.
Dax is offline Find More Posts by Dax
Old Nov 11, 2003, 03:20 AM
rorywquin is offline
Find More Posts by rorywquin
Turbines suck ;-)
United Kingdom, Hillam
Joined Mar 2000
I worked on a job where we were welding up aluminium bus bars BIG ones - (about 2 foot x 3 foot made up of several thick ally plates) - I recall that we supplied gallons and gallons of milk for the welders to drink - apparently this helped prevent them from getting ill - also they were all positive pressure ventilated in their helmets!!
rorywquin is offline Find More Posts by rorywquin
Old Nov 11, 2003, 03:21 AM
Greebe is offline
Find More Posts by Greebe
radar jammer
Greebe's Avatar
Bradenton, Florida
Joined May 2003
Also understand that there is a reason for many products sold under the Industrial/Commercial classification for reasons just like this. Joe average consumer does not normally take the time to read the label/directions or the MSDS and heed their warnings. Sad but true
BTW it's not so much the tin that's causing the issue, but the florine component.
Hope you're feelin better JT. Lets hope this incident prevents another from similar situation
Greebe is offline Find More Posts by Greebe
Old Nov 11, 2003, 03:51 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Thanks for posting this JT, hopefully it will make the hazards of products of this type known to fellow modellers and I hope that you have a speedy recovery.
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old Nov 11, 2003, 06:41 AM
Joined Feb 2000
JT, this is the kind of thing that could happen to any number of us. You did the right thing by posting the question here, and by following up with the medical opinion. With so many people starting to solder their own Li-poly cells with aluminum solder, this thread will serve as a good warning to all. Please let us know how you're feeling in a few days.
Old Nov 11, 2003, 07:43 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
It does sound like you had a real infection (fever/joint pains) as well as being badly affected by the fumes.
Its quite likely that anything that irritates the lungs will cause a fever to flare up, and get worse. As an inveterate smoker, I know that is true.
If yu have any chest infection symptoms at all - coughing, sore nose/throat, and in particular any asthma like symptoms - wheezing shortness of breath etc - stay well away from the model room.
I have found that balsa dust, solvent fumes and in particular CA fumes do very bad things to my lungs - it passes, but if there is an infection there, it can get VERY serious indeed. I have had two infections that got very bad associated with me being a bit ill and working with heavy dust and/or solvents.
The doctor who attended me said that to completely clear a lung infection takes a long time, and free passage of fresh air deep into the lungs: If they are all swollen from irritants, they don't get the fresh air, and the infections linger.
In the case of serious persistent lung irritation, they never go. Its called Emphysema - Chronic bronchitis, or 'smokers cough'.
If you do get stuff in there, concentrate on breathing OUT as FAR as you can ...it takes many secnds to completely collapse the lung and expel all the muck - before taking a gulp of fresh air deep into the lungs. With luck, you will then be able to cough up the irritants. Works for me anyway.
Look after those lungs. They can take short doses of many things, and recover well. Just don't mmake a habit of it.
Old Nov 11, 2003, 08:27 AM
headless is offline
Find More Posts by headless
Does anyone hear a cat?
headless's Avatar
Tallahassee, FL
Joined Sep 2003
Ow... i was just thinking this week 'maybe soldering aluminum isn't too bad, i'll look around on e-zone and maybe build my own lipo packs"
hell no.
headless is offline Find More Posts by headless
Old Nov 11, 2003, 08:42 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Just use a dust mask and keep the window open.
Old Nov 11, 2003, 09:06 AM
BING! is offline
BING!'s Avatar
usa
Joined Mar 2003
some reference material...
Metal fume fever
Zinc oxide fumes cause a flu-like illness called Metal Fume Fever. Symptoms of Metal Fume Fever include headache, fever, chills, muscle aches, thirst, nausea, vomiting, chest soreness, fatigue, gastrointestinal pain, weakness, and tiredness. The symptoms usually start several hours after exposure; the attack may last 6 to 24 hours. Complete recovery generally occurs without intervention within 24 to 48 hours. Metal Fume Fever is more likely to occur after a period away from the job (after weekends or vacations). High levels of exposure may cause a metallic or sweet taste in the mouth, dry and irritated throat, thirst, and coughing at the time of the exposure. Several hours after exposure, a low-grade fever (seldom higher than 102 F or 39 C). Then comes sweating and chills before temperature returns to normal in 1 to 4 hours. If you encounter these symptoms, contact a physician and have a medical examination / evaluation. There is no information in the literature regarding the effects of long-term exposure to zinc oxide fumes.
Symptoms: Systemic illness caused by inhalation of the oxides of various metals (including zinc). Symptoms include nausea, chills, diarrhea, headache and respiratory complaints.
Signs: leucocytosis (high white blood cell count) is common; normal chest x-ray;
Onset after exposure: 3-10 hours;
Heavy exposure to: zinc oxide fume or dust, e.g., after welding or flame cutting of galvanized steel, high temperature zinc coating processes, or metal pouring in brass foundries; (Brass is an alloy of copper and zinc.)
Resolution: spontaneously within 48 hours;
Comments: After an episode, there is a temporary period of tolerance for a day or two afterwards. Copper and magnesium fume can also cause metal fume fever. It is important to distinguish metal fume fever from cadmium pneumonitis.
__________________________________________________ __
Thanks to UTAHRC. Your frank remark led me to act on my suspicion that I was perhaps poisoned by the fumes.
Old Nov 11, 2003, 09:16 AM
KLH is offline
KLH
Find More Posts by KLH
KLH
Pack Rat
KLH's Avatar
Hayward CA / Valley Springs CA USA
Joined Jan 2001
BING!
Sorry about your problem, hope your lungs clear up soon!
Thanks for posting the info.
Like a lot of us here I've recently done some Lipo pack soldering with alum, but fortunately I didn't have the kind of problem you did. Been soldering things for years without any problems so just ASSUMED using alum. would be the same and didn't bother to read the warnings. I'll be a lot more careful with it in the future.
Kern
KLH is offline Find More Posts by KLH
How hazardous are soldering fumes ? Al P Power Systems 26 Jun 08, 2009 08:30 AM
Discussion How dangerous are micros? stellar Micro Helis 30 Nov 24, 2006 06:25 AM
Question How dangerous is SOLDER? Smokescreen38 Beginner Training Area (Aircraft-Electric) 34 Jun 10, 2006 10:46 PM
Discussion LIPO CELLS how dangerous are they really??? NZ_Nitro Mini Helis 15 Mar 19, 2006 12:49 PM
How much are those spot solder iron things? Joat Batteries and Chargers 5 Jul 06, 2005 10:58 PM
