Old Jun 23, 2012, 02:50 PM
TBello is offline
Find More Posts by TBello
Joined May 2007
Help!
Battery question, help... Amps?
Hey guys, I'm new to battery power and I need some help...
As I was fixing a problem with my FPV equipment (it was drawing way to much amps way toooo fast) I might of destroyed my batteries.
My batteries show .01 amps. Does this mean the batteries are destroyed? Is it possible to bring back a battery when it shows .01 amps? They are 2200mah batteries.
Thank you, Tim...
TBello is offline Find More Posts by TBello
Old Jun 23, 2012, 02:54 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
You mean .01 volts?
mrforsyth is online now Find More Posts by mrforsyth
Old Jun 23, 2012, 02:56 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
How are you measuring the .01amps? What you are asking is confusing....more info please.
hoppy is offline Find More Posts by hoppy
Old Jun 23, 2012, 03:38 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
What batteries are these ? 2200mAh lipo ? How many cells/what voltage ?
What EXACTLY is it that you are measuring, how are you measuring it and what instrument/meter are you using ?
Steve
slipstick is offline Find More Posts by slipstick
Old Jun 23, 2012, 04:13 PM
TBello is offline
Joined May 2007
Sorry guys, like I said I'm a newbi at batteries...
No not Volts, volts are good I'm reading 12.63V on my Lithium charger but 0.1A. Doesn't that mean there's no Amp left?
Old Jun 23, 2012, 04:23 PM
So. Cal.
That means it's fully charged. At 12.63 volts for a 3-cell lipoly, it's actually slightly overcharged.
Mark
Old Jun 23, 2012, 05:36 PM
TBello is offline
Joined May 2007
Yes you are correct about the voltage but what I need help in is the amps. How can I tell if the battery has any "juice" left in it, regarding amps (mAh)?
Also take a look at the picture, is the battery suppose to be 0.0A ?
Thank you again....
Old Jun 23, 2012, 05:45 PM
TBello is offline
Joined May 2007
They are 2200mAh lipos, 3cells, 11.V..
Steve
Old Jun 23, 2012, 05:47 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
The charger decreases the charge current, as designed, as it charges.
You really should read, so you understand them a bit better. Here is a great place to start.
http://www.rcgroups.com/forums/showthread.php?t=209187
You are charging your LiPoly batteries ON THE WRONG BATTERY TYPE on your charger. You really need to be careful! Please select LiPo.
Charging them with the wrong battery type selected can cause an overcharge and cause your battery to start a fire - NOT good.
Old Jun 23, 2012, 06:28 PM
TBello is offline
Joined May 2007
OK, very good.. Thank you. So a Lipo battery isn't LiIo on my charger? My charger doesn't say Lipo anywhere for a type. Just NiMH, Pb, LiIo and NiCd.
Old Jun 23, 2012, 07:00 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
The original Triton calls lipo and lii-ion both Li-ion. It does provide 2 different charge voltages, one (3.6V) for the old Li-ion packs and 3.7V for the LiPoly packs.
The current you are seeing has nothing to do with the juice in the pack. That's the charge current. When it's full, that is .1 or less.
The 12.6+V tells you the pack is filled to the top with amps, ready to fly your plane with gobs of power.
Discussion Battery amp draw hexacopter question Reginak Batteries and Chargers 6 Aug 03, 2013 12:01 AM
Help! Basic Battery Help Questions: TBello Batteries and Chargers 4 Jun 04, 2012 08:01 AM
Discussion Battery question for 6EXP - HELP!!!!!!! Gooseoverland Radios 11 May 25, 2012 02:04 AM
Discussion Propeller & battery size questions Electrofish Electric Plane Talk 2 May 17, 2012 08:22 AM
Discussion Battery question using older Aveox motor&bec Red Raider Electric Plane Talk 1 Mar 13, 2012 03:12 AM
