Old Aug 23, 2012, 09:33 AM
DanielCV is offline
Find More Posts by DanielCV
Joined Feb 2010
I will order now from RCTimer ...
DanielCV is offline Find More Posts by DanielCV
Old Aug 23, 2012, 10:06 AM
flyboygaac is offline
Find More Posts by flyboygaac
flyboygaac's Avatar
Portugal, Lisbon, Sintra
Joined Jul 2011
Please comment
Can someone help with the meaning of this modes?
GUIDED - Follow a GPS coordinate transmitted by telemetry to Crius AIOP
CIRCLE - Circle a predetermined position
POSITION - No clue
AUTO - No clue
MANUAL - No clue
This is my interpretation. Is it correct?
Isn't there one updated manual with all this?
What is simple mode??
For those using MPNG, please help me:
1- How to assign CH6 to control COPTER_LEDS?
2- How to assign CH6 to control camera shutter?
3- Sonar SR04 can be used connected to D9 and D10? and I2C?
Anyone has experience in this?
PLEASE COMMENT. Are this questions to dumb? Are the answers in some place obvious that I should read before asking? Nobody has this questions?
flyboygaac is offline Find More Posts by flyboygaac
Old Aug 23, 2012, 10:36 AM
Orphee is offline
Find More Posts by Orphee
Joined Jan 2011
Originally Posted by Orphee View Post
Hello,
I have an issue with my Crius AIO Pro...
I tried with MegaPirateNG and MultiWii, it seems I have a big lag with the MAG...
When I rotate the board, it take between 0,5 to 1 seconde before it moves in the software (Mission Planer or MultiWiiConf)... The MAG seems to be acurate, but takes time to catch the movement.
Is it normal ? Do you all have the same ?
Thank you.
Hi everyone !
I'm updating the status of my issue :
I was unable to fly with the board, big issues on the YAW axis, I couldn't stabilize the multicopter...
I contacted RCTimer support by MSN, and I'm really happy, they are true professionals. We talked 10 minutes, and they sent me a new board to replace the buggy, I received it at the beginning of the week, here is the result :
Hunter VTail 400mm & Crius AIO Pro 1.0 (0 min 57 sec)
Really good RCTimer, thanks a lot !
Orphee is offline Find More Posts by Orphee
Old Aug 23, 2012, 10:52 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
Hi everyone !
http://www.youtube.com/watch?v=lvR9HnNpYn0
That is good news.
I love the colour of your V Tail Hunter Killer & it looks like you have it flying well.
nebstress is offline Find More Posts by nebstress
Old Aug 23, 2012, 11:28 AM
turbodriven is offline
Find More Posts by turbodriven
100mph club member
turbodriven's Avatar
NW O-town
Joined Jun 2005
I know that not many of you here are running Multiwii 2.1 but this question might transfer over to MP?
Assuming I have GPS, what is the best way to setup Aux 1 and Aux 2 switches with three position switches for each. I'm not sure I fully understand all the options yet. Currently I just have Level, Baro and Mag to activate together on one position of one 3 way switch and then "ARM" on a single position of another 3 way switch (technically, at this point they could both just be on 2 position switches). GPS antenna is in the mail so I don't have that option just yet but will soon.
___________SWITCH 1__________SWITCH 2
________pos1__pos2__pos3__pos1__pos2__pos3
Level _________________X
Baro _________________X
Mag__________________X
ARM____________________________________X
GPSHOME
GPSHOLD
PASSTHRU??
HEADFREE??
HEADADJ??
turbodriven is offline Find More Posts by turbodriven
Old Aug 23, 2012, 11:56 AM
mamut is offline
Find More Posts by mamut
mamut's Avatar
Romania,Est Europe
Joined May 2004
Originally Posted by biv2533 View Post
Partially solved
The Arduino Sketch must be exactly in Documents as show here
http://code.google.com/p/ardupilot-mega/wiki/Code
In any case now i have a new compiling error:
ArduPlaneNG2x.cpp:98:23: error: AP_Limits.h: No such file or directory
(Win7 and Arduino.exe runned ad administrator)
Same error on the first time without original libraries but try with original and ArduPlaneNG2x libraries together.
it worked on my setup
mamut is offline Find More Posts by mamut
Old Aug 23, 2012, 12:04 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
GPSHOME
GPSHOLD
PASSTHRU??
HEADFREE??
HEADADJ??
It is really down to personal preference which functions you want to use and on which switches.
With your switch setup at the moment you have a choice between Acro mode or Height + Head lock.
I have mine set:
Two position switch with "L"=Acro "H"=Self Level
Three Position switch with "L"=0 "M"=Height Hold "H"=Position Hold
Two Position switch with "L"=0 "H"=Return to Home
Old Aug 23, 2012, 02:34 PM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
Originally Posted by jy0933 View Post
it is said new version coming out in August.. any info about it?
Where did you see that?
epyonxero is offline Find More Posts by epyonxero
Old Aug 23, 2012, 02:56 PM
RHTizzy is offline
Find More Posts by RHTizzy
RHTizzy's Avatar
The Netherlands, NH, Bussum
Joined Feb 2012
Originally Posted by Quadframes View Post
when you have used then you wont want to use un-flashed again
Well okay then, will definitely be going down that road sometime in the foreseeable future
First to get it airborne tho (with as little tampering as possible until I know what I'm doing) so I can get that noob status lifted
RHTizzy is offline Find More Posts by RHTizzy
Old Aug 23, 2012, 03:12 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
I'm sorry, I heard that some USB receptacle of this FC damaged in few used.
Because the number of pads on PCB is not enough.
Now I fix the USB receptacle with glue, make sure it strong enough.
I will fix this problem completely in next edition, maybe in August.
first post.. bottom
jy0933 is offline Find More Posts by jy0933
Old Aug 23, 2012, 03:27 PM
mamut is offline
mamut's Avatar
Romania,Est Europe
Joined May 2004
Originally Posted by bluelightning View Post
https://vimeo.com/47992845
Here a video of an autonomous mission flight with a Maxi Swift flying wing piloted by the firmware ArduPlaneNG v2.x R5 with an All In One Pro (AIOP) full IMU board. In this test flight the STABILIZE and AUTO mode and the RTL mode has been tested. The video has been shorted due the total duration of the flight and only one closed loop turn has been showed here. The video has been taken with an EVO HD Cam sports video camera. The flight plan has been defined with 6 waypoints (2km turn) and runs in closed loop around the airfield.
The wind was blowing at 11km/h gusting 17 km/h.
Hi
I am using your configuration/ArduPlaneNG2xR5 except the GPS -is LEA6 on the extention board.
I am getting HDOP 9999 and no satellite, so no fix, can you help me?
Old Aug 23, 2012, 08:51 PM
Joined Feb 2012
first post.. bottom
Interesting. Well August is almost over, I was about to buy one of these boards to run Arducopter, but Ill wait and see now.
Old Aug 24, 2012, 01:39 AM
bluelightning is offline
Find More Posts by bluelightning
VTOL UAV designer
bluelightning's Avatar
France
Joined Aug 2005
Originally Posted by mamut View Post
Hi
Hello Mamut,
I haven't yet tested the extension board, but I think that it will work too. I recommend you to test this method for the startup of the AIOP + GPS:
1) connect the power to the AIOP,
2) when the led B is fix while led A and C are off (after that the initialisation is complete),
3) disconnect the power to the AIOP and then reconnect the power.
I think that you will be able to see the yellow (ready) and green (GPS lock) leds on.
I have noticed that the Crius NEO-6 GPS need to be prepowered first so as to get the lock... May be this is due to the lithium battery which is not able to keep the startup info for long time...
I hope this will help you
bluelightning is offline Find More Posts by bluelightning
Old Aug 24, 2012, 03:44 AM
Akcopter is offline
Find More Posts by Akcopter
Akcopter's Avatar
Joined Apr 2012
hey.. there is no slot for a sd card on the crius board which logs all the flight data on an APM 2...any bright ideas asto how can i add an external Sd reader be'coz ...I like this feature and would love to use the blackbox functionality on my UAV quad..anyway I can always analyse the data sent to the GCS via telemetry but..still is there a way to interface a micro sd reader.........
Akcopter is offline Find More Posts by Akcopter
Old Aug 24, 2012, 05:46 AM
mamut is offline
mamut's Avatar
Romania,Est Europe
Joined May 2004
Hi Bluelightning
Thank you for your support.
It works now- 9 satellites hdop 232 I will put it in a plane next week for evaluation.
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
