Old Aug 22, 2012, 09:07 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
GPS fix for MultiWii
Originally Posted by ibooo View Post
please i have Extend Board for AIO PRO FC
What is the default baud speed ? we need to change any setting to use with current 2.1 MWI
The default Baud on mine is 9600bps.
You can either reconfigure the default settings in the GPS to the correct ones using u-center or;
This is the code you can add to MWC 2.1 (& file to replace) that will automatically configure the GPS with all the correct settings on boot up as long as the GPS module is on default settings.
Just replace the GPS.ino file & add the following lines to config.h gps part:
Code:
                //#define NMEA
                #define UBLOX
           // #define MTK
           #define GPS_LEAD_FILTER
        //#define GPS_FILTERING
        //#define NAV_SLEW_RATE                   30
Plus add the initialisation to the multiwii.ino setup:
Code:
#if defined(GPS_SERIAL)
          #if defined(UBLOX)
           UBLOX_init();
           delay(200);
          #endif
        #if defined(MTK)
           MTK_init();
           delay(200);
        #endif
                SerialOpen(GPS_SERIAL,GPS_BAUD);
You must change the Baud to 57600:
Code:
#define GPS_SERIAL 2 // should be 2 for flyduino v2. It's the serial port number on arduino MEGA
    #define GPS_BAUD   57600
(Works on Extend Board & CRIUS CN-06)
Thanks to EOSBandi.
nebstress is offline Find More Posts by nebstress
Old Aug 22, 2012, 09:35 AM
ibooo is offline
Find More Posts by ibooo
Joined Dec 2007
ok thank
i test 9600 work
now i will revise my code
ibooo is offline Find More Posts by ibooo
lucamaxco is offline
Find More Posts by lucamaxco
Joined Apr 2009
I thought that Extend Board for AIO PRO FC do not need the above modifications since it has the Gps backup battery that works while the other RcTimer Gps, U-blox Neo 6M fails to hold configuration.
So IMHO with Extend Board for AIO PRO FC (U-blox LEA-6H GPS) you need only to change baud rate and configuration via U-blox sofware as have been explained in the AIO guide http://www.rcgroups.com/forums/showa...mentid=5020340
lucamaxco is offline Find More Posts by lucamaxco
Old Aug 22, 2012, 09:46 AM
ibooo is offline
Joined Dec 2007
compile error
Old Aug 22, 2012, 09:51 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
The backup battery does work on the "Neo 6M" GPS, the backup battery's will only hold settings for a limited period of time on any GPS module.
The problem with the "Neo 6M" is that it can't be flashed with new firmware.
If you want to change the default settings permanently on the LEA-6H GPS (Extend Board) then you need to flash it with a firmware that has the settings you need.
Old Aug 22, 2012, 09:54 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
compile error
You must be doing something wrong, make sure to follow the instructions properly.
[EDIT]
It looks like you have pasted the code for the 'multiwii.ino' tab straight into the top of the sketch.
It needs to be pasted in the "Serial GPS only variables" section, here is a copy of mine, the code you need to add is in blue.
Code:
  calibratingG = 400;
  #if defined(POWERMETER)
    for(uint8_t i=0;i<=PMOTOR_SUM;i++)
      pMeter[i]=0;
  #endif
  #if defined(ARMEDTIMEWARNING)
    ArmedTimeWarningMicroSeconds = (ARMEDTIMEWARNING *1000000);
  #endif
  #if defined(UBLOX)
   UBLOX_init();
   delay(200);
  #endif
#if defined(MTK)
   MTK_init();
   delay(200);
#endif
Old Aug 22, 2012, 11:08 AM
careyer is offline
Find More Posts by careyer
member of TheBlindHawks
careyer's Avatar
Joined Feb 2011
Hi there,
just wondering if there will be a correct Quad8X Motor-Mapping for MPNG sometimes soon? I would like to also start playing around with my AIO Pro board but until now the all finished camera-copter just sits on the floor and dust starts to cover it.
This is due to the faulty motor-mapping for the afore mentioned frame setup. I could switch back from MPNG to MultiWii 2.1 but once you've seen the possibities of MPNG you never want to go back.
Please make it happen! THANK YOU
careyer is offline Find More Posts by careyer
Old Aug 22, 2012, 12:16 PM
DanielCV is offline
Find More Posts by DanielCV
Joined Feb 2010
Hello,
would this Bluetooth adapter work with AIOP and MegapirateNG ?
http://www.ebay.de/itm/MWC-Multiwii-...item3f199c1479
DanielCV is offline Find More Posts by DanielCV
Old Aug 22, 2012, 12:32 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Originally Posted by DanielCV View Post
Hello,
Yes it will work but it is a lot cheaper plus free delivery HERE
Old Aug 22, 2012, 12:55 PM
DanielCV is offline
Joined Feb 2010
Thanks for the hint, any experiencie how fast RCTime deliver ?
Also, as I am using the CN-06 GPS, do you recommend the AIOP Extend board instead ?
Old Aug 22, 2012, 01:08 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Delivery time will depend on where you live & the shipping method used.
If you are already using the CN-06 GPS without any issues then why would you want to get the Extend Board as well?
Old Aug 22, 2012, 01:13 PM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
perhaps to have a better gps and possibilities to have xbee module
titeuf007 is offline Find More Posts by titeuf007
Old Aug 22, 2012, 01:15 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Well there you are you answered your own question
Old Aug 22, 2012, 01:22 PM
DanielCV is offline
Joined Feb 2010
question was not answered by me...
But ok. thanks for your hints. Anyway it is not clear to me why that GPS is better ?
Waiting to do first test with CN-06 and then I will see.
I ordered always from HK and it took 3 weeks to me (living in africa). So RCTimer should be the same ?
Old Aug 22, 2012, 01:50 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Waitin gto do first test with CN-06 and then I will see. I ordered always from HK and it took 3 weeks to me (living in africa). So RCTimer should be the same ?
Oop's, I'm a bit more dopy today than usual
Sorry I thought you said that you had the CN-06 GPS working well with your CRIUS AIOP so couldn't understand why you'd want to get the Extend Board.
xBee's is one reason to get the Extend Board but if you want wireless telemetry there are better, cheaper alternatives to the xBee's & the Extend Board isn't necessary to use/attach them.
I have both the CN-06 & the Extend Board, the LEA-6H is a better GPS module than the NEO-M6 but I don't think there is a big difference in overall performance.
[EDIT]
RCTimer is in ShenZhen so the shipping time should be about the same, yes.
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 30 May 14, 2014 10:52 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 09:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 09:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 01:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 09:51 PM
