Old Jul 06, 2012, 03:21 PM
mealie is offline
Find More Posts by mealie
Joined Jun 2011
Yes. You can connect any standard NMEA GPS receiver to AIO PRO board.
You don't need the I2C-GPS NAV board.
I2C-GPS NAV board used for FC witth 328P MCU, because it has only one UART port for debug.
mealie is offline Find More Posts by mealie
Old Jul 06, 2012, 03:38 PM
palm369 is offline
Find More Posts by palm369
palm369's Avatar
Germany, HH, Hamburg
Joined Jun 2012
cool, then i ordered something useless yesterday -.-
palm369 is offline Find More Posts by palm369
Old Jul 06, 2012, 04:11 PM
Quadframes is offline
Find More Posts by Quadframes
Quadframes's Avatar
Joined Jun 2011
Hi here is something I put together hope it helps if anything needs changing let me know?
Quadframes is offline Find More Posts by Quadframes
Old Jul 06, 2012, 04:47 PM
Kipkool is offline
Find More Posts by Kipkool
Old Flying Bastard
Kipkool's Avatar
France, IdF, Paris
Joined Jun 2011
Waiting for this board tooo, it's in a plane between Taiwan & Paris now.
Thanks for your doc Quadframes.
Just wondering, but are you sure about the Tx1/Rx1 dedicated to ppm sum ? This seems to me a waste of serial port as receiver pins can do the job ( keep ppm sum on pin 1 ).
I think it's more for Spektrum/Sbus rx.
I never used APM, only Multiwii, so I refer about mwc here.
Writing "i2c for gps" on the i2c connector is quiet confusing for new users. This mega2560 has enough power/memory/serial output to handle the serial gps, using i2c gps on it is non sense & waste.
Perhaps you should write instead "external i2c sensors" , or something like that.
Can't wait to receive it, I really want to give a look on megapirate code..
Kipkool is offline Find More Posts by Kipkool
Old Jul 06, 2012, 04:53 PM
Quadframes's Avatar
Joined Jun 2011
Hi no problem, it is just bits and pieces that I have put together that I have found out also info from here.... as I have said any changes i can make but we need to get the correct info, if it helps to get a manual started then great .
Old Jul 06, 2012, 06:14 PM
Quadframes's Avatar
Joined Jun 2011
Hi just added a few more things to the manual hope that this help
Old Jul 06, 2012, 07:14 PM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
thanks quadframe it s very nice
titeuf007 is offline Find More Posts by titeuf007
Old Jul 07, 2012, 04:40 AM
Milamber is offline
Find More Posts by Milamber
Joined Apr 2010
Thanks very much for the Manual Quadframes. I will be able to start playing now.
Milamber is offline Find More Posts by Milamber
Old Jul 07, 2012, 04:51 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
Thank you Quadframes, Great manual
nebstress is offline Find More Posts by nebstress
Old Jul 07, 2012, 04:58 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Originally Posted by seile View Post
Hey Nebstress
I just ordered one of these too.. How is it compare to the bunny
Thx
Hi Seile, I have only been playing with the firmwares & GUI's (MultiWii+MegaPirate) so far, will be adding it to a Quad in a few days hopefully & will be getting a GPS unit next week to add to it.
Still not 100% sure which to go with MultiWii or MegaPirate, I will probably start with MegaPirate & see how it performs/flys but I am keen to see how MultiWii will compare to the Bunny.
Old Jul 08, 2012, 10:12 AM
bluelightning is offline
Find More Posts by bluelightning
VTOL UAV designer
bluelightning's Avatar
France
Joined Aug 2005
AIO Pro works fine with the GPS MT3329
Hello,
The AIO Pro v1.0 works fine for me, the GPS MT3329 it is fully locked with the MegaPirateNG_2.6_R5...
GPS is connected to RX2, TX2 and to +5V, GND from the I2C port
I have also tested the GPS EM406 and it works also well too...
The working setup is:
#define PIRATES_SENSOR_BOARD PIRATES_FREEIMU_4 // For All In One Pro 1.0
#define CONFIG_BARO AP_BARO_MS5611_I2C // For All In One Pro 1.0
#define GPS_PROTOCOL GPS_PROTOCOL_AUTO // for GPS MT3329 or EM406
See the photo attached.
bluelightning is offline Find More Posts by bluelightning
Old Jul 08, 2012, 12:45 PM
Trauma50 is offline
Find More Posts by Trauma50
Joined Sep 2011
Crius AIO Pro Setup
Nub questions
1. Does the board need to have the receiver and ecs's hooked up to communicate with Ardunio/GUI?
2. Can I power it with just a receiver battery pack and not a ECS for programing firmware?
3. I read that the USB can provide power?
I just got my feet wet flying a KK board, this board is so new it seems theres not much info out there regarding it? Should I just keep reading about the AIO SE board??
Thanks much, JD
Trauma50 is offline Find More Posts by Trauma50
Old Jul 08, 2012, 01:10 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
Originally Posted by Trauma50 View Post
Nub questions
Thanks much, JD
1. NO
2. & 3. USB provides power for uploading Firmware.
Only if you are going to get the SE board, otherwise start reading up about one or both MultiWii & MegaPirate.
Old Jul 08, 2012, 03:23 PM
Quadframes's Avatar
Joined Jun 2011
Originally Posted by bluelightning View Post
Hello,
Hi if you power the board from external power source via the extended power in marked on the back of the board then you will be able to take the 5v from the S1-S3 plug and then you dont have to have wires running from the I2c plug
Remember to remove the yellow jumper if you are powering the board this way
Old Jul 09, 2012, 12:32 AM
VTOL UAV designer
France
Joined Aug 2005
Thanks for your advice. I have used the 5V from the I2C plug because, If I power the AIOP with the USB (during the dev phase) there is no voltage ouput from the S1-S3 plug, so the GPS is not powered by this way.
Attached the successful test with the GPS EM406
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
