Old Mar 15, 2013, 02:02 PM
Mochaboy is offline
Find More Posts by Mochaboy
Radd Graduate '06
Mochaboy's Avatar
United States, MA
Joined Aug 2006
Multiwii or KK. The Acro features for MPNG haven't been implemented fully yet (true acro as you know it).
I want to echo the RTL ability of this platform. I chose this specifically for that feature and it's saved me on more occasions than I care to admit. The problems I've run into have been almost all mechanical, but I've finally sorted a number of those issues.
I want to share one particular failure that I hope you guys can avoid.
Everyone keeps mentioning what wonderful motors the NTM series are. I drank the koolaid, and I bought 8. I won't be buying these again, but I'm not throwing these out and they're still mostly salvageable.
I ran into one particular issue with my tricopter. When an arm dips, the motor speeds to stabilize the rig back to level. That creates a torque effect on the motor. It was fine for the few hours of operation, but both motors suddenly developed an uncontrollable vibration above 50% throttle any time I rolled left or right. If you look at my videos on Youtube, you'll see one of those flights caused a crash. You'll see it about 3:40
Tricoptex FPV crash (4 min 33 sec)
I bought a new set of bearings from GravesRC (I would have bought them from AvidRC but they were out of the 3x8x4's when I ordered), held the tricopter in my hand and dipped the motors left and right under full throttle. Smooth as butter now.
I have no idea how long this will last, but if you're running NTMs, it's not a question of if these bearings will fail - but when. The effect isn't as pronounced on my quad maybe because of the extra rigidity of the frame, but I'm not waiting for them to fail - I'm going to swap out all the bearings as soon as possible.
I want to add that in addition to swapping out the bearings, I've balanced each motor bell using the quadrant & iVibration app method, propeller, and prop hub, and this rig whispers in the air now. I'll grab some footage tomorrow so you can see the difference.
I may also swap the Skywalker out of the HT FPV and change them up for SimonK Blues but I'm less concerned about that rig. Just trying to get some flying in for a change.
Mochaboy is offline Find More Posts by Mochaboy
Old Mar 15, 2013, 04:40 PM
leithalweapon is offline
Find More Posts by leithalweapon
Joined Dec 2010
http://www.youtube.com/watch?v=UEmDKb9lVZE
The NTM 28's do have crappy bearings, but the NTM 35's I have seem to be lasting a lot longer. At about $2 per motor for new bearings the 28's are still pretty good though. Just like many other Chinese products. You keep the good parts and replace the bad parts with quality American made parts.
leithalweapon is offline Find More Posts by leithalweapon
Old Mar 15, 2013, 06:14 PM
bulesz is offline
Find More Posts by bulesz
bulesz's Avatar
Hungary EU
Joined May 2007
Just ordered the HK NEO-6M GPS module..
http://www.hobbyking.com/hobbyking/s...dProduct=31135
I think I will put on the multiwii 2.2 and all will be fine....
bulesz is offline Find More Posts by bulesz
Old Mar 16, 2013, 01:32 AM
lakis21 is offline
Find More Posts by lakis21
lakis21's Avatar
Greece, Makedonia Thraki, Nikiti
Joined Dec 2006
Anyone has success with multiwii 2.2 and CRIUS AIO with GPS on position Hold ? Do you know something about that?
lakis21 is offline Find More Posts by lakis21
Old Mar 16, 2013, 01:46 AM
lakis21 is offline
lakis21's Avatar
Joined Dec 2006
Hello I am trying the last 2 days to make a piezo buzzer for arming - disarming like kk2.0 on MegapirateNG 2.9 R6. But I could make it. I Have copter led enabled and they are working fine, but a buzzer will be also good.
Code:
// New in 2.0.43, but unused in MegairateNG
// MPNG: Piezo uses AN5 pin in ArduCopter, we uses AN5 for CLI switch
As I understand from that line , the Piezo doesn't work on MegapirateNG any more, am I right?
Old Mar 16, 2013, 04:58 AM
jan michael is offline
Find More Posts by jan michael
www.solarenergyglow.com
jan michael's Avatar
Joined Feb 2013
Code:
@lakis you can check at KK2.0 thread KK2
jan michael is offline Find More Posts by jan michael
Old Mar 16, 2013, 05:09 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Code:
Normally a buzzer just emit some sound when get 5v power
All you need is to connect the buzzer on one side (check which is +vcc on your buzzer else you may destroy something) then control high and low via one of the free pin ... you will have to initialize this pin as an output
It is very easy if you know what are you doing
e_lm_70 is offline Find More Posts by e_lm_70
Old Mar 16, 2013, 10:22 AM
lakis21 is offline
lakis21's Avatar
Joined Dec 2006
Hello I know how its works, I ve done on my apm2.5 and arducopter, but I can't on MegapirateNG and Crius.... By the way external leds for arming - disarming, gps lock they are working fine like arducopter.... But I didn't manage to have buzzer...
Does anybody knows if the MegapirateNG 2.9 R7 supports Buzzer on CRIUS ?
Old Mar 17, 2013, 03:17 AM
Joined Feb 2013
Im asking for Help maybe anybody can help me on my setup. regarding on STOCK FS-TH9X configuration for my quad.
Specs.
F450 frame with Crius AIO
1000kv 2212 motor with 20Amps quattro
10X4.5 props
2200 25C zippy
Old Mar 17, 2013, 03:26 AM
Paku is offline
Find More Posts by Paku
Poland, Mazowieckie, Warsaw
Joined Jan 2009
Yes it does , but you have to change the LED_MODES to enable Buzzer and define YOUR piezzo pin (any free pin).
I have sent you examples one day ...
Edit:
Again:
http://code.google.com/p/megapiraten...pter/defines.h
lines 411,412
Paku is offline Find More Posts by Paku
Old Mar 17, 2013, 07:29 AM
Joined Feb 2013
Need help i try to arm my Crius aio multiwii but doesn't work i follow the throttle down right but nothing happened. i also check the ESC buy plugging the signal in into thr RX throttle channel and all off them working fine. when i plug the all and plug the battery only initial sound where heard. what could be the problem on mu multiwii? should i flash it with Megapirate NG?
Old Mar 17, 2013, 07:41 AM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
you can assign a switch to arm on multiwii..
dazza44 is offline Find More Posts by dazza44
Old Mar 17, 2013, 07:46 AM
Joined Feb 2013
any guideline how to. sorry but im noob and i dont know.
Old Mar 17, 2013, 08:09 AM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
open multiwii gu,i in flight modes youll see aux1 aux2 aux3 aux4 look down the list you will see arm.
you can assign one of your switches for it..
Old Mar 17, 2013, 08:34 AM
Joined Feb 2013
@dazza now i got it thank you so much now my next problem is motor calibration
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
