Old Feb 06, 2013, 01:37 AM
United States, CT
Joined Oct 2012
I am having a problem, I just got a Crius AIOP v1.1 but when I plug it into the USB it will not detect it.
The lights blink yellow and red at first then just red after a few seconds. And a constant green and red light stay on while the red light blinks. How do I make my windows 7 desktop which has no problem detecting MultiWii, open pilot, or Naza flight controllers detect the Crius AIOP v1.1?
Please let me know where I can find usb drivers for Crius AIOP v1.1
TimeTrave1er is offline Find More Posts by TimeTrave1er
Old Feb 06, 2013, 03:35 AM
Joined Feb 2013
High refresh with MegaPirate too!
Did a fast load of MP last night, and same thing! Motor refresh of near 500 Hz
I don't see how out can be a board problem, refresh should be controlled by processor timer.
But the setup doesn't require all that much to screw up so constantly.
I wonder if perhaps most of you have fast refresh rates, but have ESCs that respond. Has anyone else put a scope on the servo outputs.?
Any of you gurus that can direct me to the code ares that controls the output train? In other words, "HELP"
Crius AIO PRO clone (HK).
Arduino 1.0.3
Megapirate 2.8 r3
SkyHawk_DP is offline Find More Posts by SkyHawk_DP
Old Feb 06, 2013, 04:45 AM
Poland, Mazowieckie, Warsaw
Joined Jan 2009
Originally Posted by renatoa View Post
Yes, I am aware about that file, but they state based on the board engraving, which is wrong, imo.
I checked MP code 2.7R4, and pins 32/33 are nowhere assigned to any task.
For 2.9.1, version I am using now, it seems 32 could/should be used for piezo buzzer ???
But not sure as for this sentence
// MPNG: Piezo uses AN5 pin in ArduCopter, we uses AN5 for CLI switch
What is a CLI switch ???
Paku is offline Find More Posts by Paku
Old Feb 06, 2013, 06:09 AM
Romania, Dolj, Craiova
Joined Sep 2007
CLI (Command Language Interpretor) is terminal mode, in genuine APM is a slide switch allowing you to enter in terminal mode.
In MPNG this switch is electronic, and the activation is via the "hit Enter three times" sequence.
But, are you sure AN5 is pin 32 ?
renatoa is online now Find More Posts by renatoa
Latest blog entry: JRSky - birth of a dream radio
Old Feb 06, 2013, 06:16 AM
United States, CT
Joined Oct 2012
Ughhhhh why can't my computer detect the Crius but can detect my other flight controllers?!! Please somebody tell me where drivers are or if there even are any
Old Feb 06, 2013, 06:40 AM
United States, CT
Joined Oct 2012
I plug the USB into the Crius first to avoid short. Then I plug USB into computer. The Red (A) light and Orange (B) light blink alternately rapidly for about 5 seconds then stops and only Red blinks alone on and off once per second. My comp recognizes something is plugged in but can't locate the drivers to use it. I need to know where drivers are that will let my comp usb detect a Crius.
Old Feb 06, 2013, 06:44 AM
Leeds, UK
Joined Dec 2003
I don't have mine here to test, but have you tried looking at the Google code sites? Maybe mission planner too.
Even Arduino, it works via that so their drivers might work. I can't remember how I got mine working
sidneylopsides is offline Find More Posts by sidneylopsides
Old Feb 06, 2013, 07:37 AM
Joined Jan 2009
32 in code is just a numeric constant, what means it is a chip's io port address in decimal /I think, as I know AVRs/
AN5 is a code constant and defaults to 59 for APM, for mpNG you can change it to 32 to have buzzer on pin labelled 32 on board.
Look into pdf mentioned above, chapter "Buzzer".
Old Feb 06, 2013, 08:18 AM
Joined Jul 2011
I'm sorry to ask. This is not with intention to make pressure or anything, i just would like to humbly ask if there's an ETA no the launch of MPNG ver 2.9.1?
abriosi is offline Find More Posts by abriosi
Old Feb 06, 2013, 08:23 AM
United States, TX, Richmond
Joined Aug 2010
Install mission planner and arduino. The drivers for the crius are found in the arduino folders.
rcjose is offline Find More Posts by rcjose
Old Feb 06, 2013, 08:36 AM
Joined Jan 2009
You have the MegaPirateNG 2.9 R5 (ArduCopter 2.9.1) in the SVN repository for few days now.
Old Feb 06, 2013, 08:37 AM
Joined Jul 2011
Yes i know, but is it completly stable?
Old Feb 06, 2013, 08:44 AM
Radd Graduate '06
Mochaboy's Avatar
United States, MA, Sudbury
Joined Aug 2006
Trunk = beta code => use at your own risk.
If you want stable - stick to the official releases in the downloads area.
For what it's worth 2.9.1 fixed that timing issue that was causing uncommanded failsafes which nailed by my last count about 4 flyers. So long as you're not using throttle failsafes it's not an issue, but if you are - you need to be running 2.9.1
Mochaboy is online now Find More Posts by Mochaboy
Old Feb 06, 2013, 08:58 AM
Joined Feb 2013
Code for refresh rate
@Paku or someone, can you direct me to the code in MP (for CriusAIO Pro) that manages refresh rate of the servos? I'll take it from there, seems like nobody has seen my problems.
I'm using MP 2.8 r3
Old Feb 06, 2013, 09:10 AM
barok's Avatar
Joined Apr 2006
don't see this MegaPirateNG 2.9 R5 on the download list..
http://code.google.com/p/megapirateng/downloads/list
barok is offline Find More Posts by barok
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 29 Nov 21, 2012 09:58 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV/RPV - Equipment and Vehicles (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
