Canada, BC, Vancouver
Joined Feb 2013
Hi
here are the screenshots. I found out that the board had Multiwii already on it when I got it. I tried to run it with Multiwii GUI 2.1 and it works just fine on com port 4 and baud rate 115200. It seems the fact that Multiwii is already on the board prevents me to upload Megapirate to it ??? To get Megapirate on the board I tried all baud rates and I'm sure com port 4 is right, but nothing works. |
United States, TX, Richmond
Joined Aug 2010
http://www.rcgroups.com/forums/showt...9#post23947053 |
Slovakia
Joined Aug 2006
i assume that you have connected the buzzer into pin32. do you have 1kOhm resistor between the ground and buzzer ? I can see everywhere that it's recommended to put it there. why is it important to have the resistor there ? I have a buzzer from KK2.0 board. Can I use it ? maybe without the resistor ? |
Joined Feb 2013
MegaPirate NG
BTW, I read somewher that you should load the Multiwii first, and then load MegaPirate. Is this true? Or do you just go for the jugular!
I wanted to play around with just the Multiwii first to get the hang of everything... me being a virgin in Multiwii and all. What do you all suggest? Although it's my first time with Arduino, I am a software /firmware developer so this is not a problem. I've got all of the tools working, Mission Planner, Multiwii GUI, etc. etc, and they feel comfortable. Just not familiar with the Crius AIO PRO yet. |
Joined Dec 2012
MegaPirateNG + Spektrum DX7
Hi Guys.
First of all a thank you for all of the excellent information here that has made my build (almost) plug and play, with all of the information available (especially Mochaboy's excellent videos) I have had all the answers before I had the questions. ![]() Now for my first issue ![]() I am using: Crius AOIP v2 MegapirateNG 2.8 R3 Spektrum Dx7 + AR7000 On my first run through the config, I set the TX as TX_Set1 (as it looked like the obvious selection for my setup). But in Mission Planner the controls were all random, throttle controlled roll etc. so I swapped to TX_mwi and now everything is on the right stick. The issue is Yaw and Roll are reversed. For example to arm I need to go bottom left not bottom right. I have been through the options on my TX and can't find an option to reverse the inputs in airplane mode (it is there in heli mode) so hoped there was a config option. Thanks for your help. |
| Thread Tools | |
| Discussion New updated Crius Multiwii SE flight controller | SGsoar | Multirotor Electronics | 72 | May 15, 2013 08:36 PM |
| Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 | pprioverde | Multirotor Talk | 29 | Nov 21, 2012 09:58 PM |
| Discussion Jim, any plans for more multi rotor flight controller? | chris24g | Xtreme Power Systems | 12 | Jun 25, 2012 08:11 PM |
| Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots | wingspinner | FPV/RPV - Equipment and Vehicles (FS/W) | 3 | May 28, 2012 12:55 AM |
| Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) | SJackson | Multirotor Talk | 27 | Apr 30, 2012 08:51 PM |
