Old Jan 25, 2013, 07:01 PM
Mochaboy is offline
Find More Posts by Mochaboy
Radd Graduate '06
Mochaboy's Avatar
United States, MA
Joined Aug 2006
Here's part 2...
In this video - I cover wiring options for both master and slave mode along with the necessary Mission Planner configs for Master mode.
Somehow it all miraculously worked!
MinimOSD Setup, Wiring and Final Power Up Test! (22 min 31 sec)
Mochaboy is offline Find More Posts by Mochaboy
Old Jan 26, 2013, 04:33 PM
TheDonski is offline
Find More Posts by TheDonski
Oakridge, Oregon
Joined Jul 2004
Another great video! Thanks Mochaboy.
TheDonski is offline Find More Posts by TheDonski
Old Jan 26, 2013, 04:46 PM
Oakridge, Oregon
Joined Jul 2004
Had my first successful auto flight with my quad that went to all of my waypoints!
Also RTL worked about 6 times in a row and alt hold too.
On the third battery it seems it could find the waypoints, but could not hold the throttle and altitude. It started to bounce off the ground. Not sure why. There was a fresh battery for that mission.
The newer MP 2.8 has the throttle settings changed, but I did not change them in my mission planner (Could not enable the box Throttle Accel). Maybe it was going into Failsafe and that is why it bounced.
Then after that I tried to RTL and it went in a different direction. Checked the GPS lock with my FatSharks and OSD and was locked with 8 sats. I will have to try again later when it stops raining to see if it continues this issue.
I feel that I am getting the PIDs locked in better, but I still get a wobble with extreme throws in pitch/roll input, also rapid descending (Heard wobble on descending is normal). Is the wobble on extreme pitch/roll usually the last thing to be eliminated when fine tuning PIDs?
Thanks again for the help to get to this point!
Old Jan 26, 2013, 06:34 PM
shakzool is offline
Find More Posts by shakzool
Joined Jun 2009
any one have any idea why my board won't load when powered by ubec. I have removed jumper and powered by extend power pins on the aiop v2 I get blue light on tow tiny orange leds flash but board won't load unless I connect usb. Its sometimes very randomly will load but 90% of the time it needs usb.
shakzool is offline Find More Posts by shakzool
Old Jan 26, 2013, 07:23 PM
Mochaboy is offline
Radd Graduate '06
Mochaboy's Avatar
United States, MA
Joined Aug 2006
Put your multimeter on the bec and post back with what you get.
Old Jan 26, 2013, 07:26 PM
Mochaboy is offline
Radd Graduate '06
Mochaboy's Avatar
United States, MA
Joined Aug 2006
Can you post your current PIDs?
You're way ahead of me flight mode wise I'm still playing around with tunes. I'll be picking YOUR brain soon
Old Jan 26, 2013, 07:34 PM
Oakridge, Oregon
Joined Jul 2004
I had to tune down most of my rates to get a mostly stable quad.
rate_p= 0.0875
rate_i= 1.0000
rate_d=0.0045
stab_p=3.5
Still thinking I need to lower rate_p more since there is still some wobble with high pitch/roll values.
These values are about half of what I came up with the rig test for rate_p and rate_d. The quad getting better and more stable (less wobbles) than at higher values.
I will keep playing around with it and then post any changes.
Old Jan 26, 2013, 08:10 PM
jabram is offline
Find More Posts by jabram
Joined Jul 2012
Originally Posted by Mochaboy View Post
As for getting a fix - the board needs a clear unobstructed view of the sky, so it can't be located inside a protective case, or below a flight plate, or anything else.
Plastic protective case or heatshrink around GPS module does not affect GPS receiver, metal or carbon fiber will.
jabram is offline Find More Posts by jabram
Old Jan 26, 2013, 09:10 PM
shakzool is offline
Joined Jun 2009
I'm sure it was 5.2. And to be sure I even put a 2s lipo on it and still it wouldn't load. I don't know if its a dodgy board or there is some conponent malfunction but occasionally it will load
Old Jan 26, 2013, 09:46 PM
Thidsa is online now
Find More Posts by Thidsa
Norway, Nordland, Leknes
Joined Jun 2012
Does anyone know a way to extend or add new status leds with a cable on the AIO v2 board?
Any of the free pad that could be used? Board will be hidden and i would like to see the status leds
Bjoern
Thidsa is online now Find More Posts by Thidsa
Old Jan 27, 2013, 02:23 AM
Joined Jun 2012
Old Jan 27, 2013, 03:29 AM
antoniekruger is offline
Find More Posts by antoniekruger
Joined Jul 2012
Help - AIO USB Port damaged
Hi Guys, Please help.
I managed to pull the mini usb port off the board - and yes, the pads came along. Not one of my best moments. Now the question is, how can I program the board through another port. Can I use the FTDI or one of the serial ports. I managed to get comms with the board using port 3(talks to mission planner), but seem unable to put the board in programming mode to download the software. Is the board salvageable?
Thanks for any help.
Antonie
A pic of my handywork mmmmm
Description:
antoniekruger is offline Find More Posts by antoniekruger
Old Jan 27, 2013, 03:34 AM
Skewp is offline
Find More Posts by Skewp
In progress...
Skewp's Avatar
Estonia, Tartu County, Tartu
Joined Jul 2012
I'm using Crius V1.1 and MegaPirate software. I'm currently flying an flat octocopter. Does MegaPirate also support X8 mode and if yes, where could I find the motor layout scheme?
Skewp is offline Find More Posts by Skewp
Old Jan 27, 2013, 03:39 AM
Joined Jul 2012
Hi Skewp
The readme file that comes with the MP download has all the supported layouts.
File attached.
Cheers,
Antonie
README
Old Jan 27, 2013, 03:52 AM
Sir Alex is offline
Find More Posts by Sir Alex
Aleksey Kharlanov
Беларусь, Минская область, Минск
Joined Sep 2011
http://code.google.com/p/megapirateng/wiki/confighw
UPD: Sorry, images not have X8 config, so read README.txt
UPD2: Ok, now all images updated. Added Quad, Tri and X8 configurations
Sir Alex is offline Find More Posts by Sir Alex
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
