Old Jul 03, 2012, 04:31 AM
Flyrobot is offline
Find More Posts by Flyrobot
youtube.com/#/user/flyrobots
Indonesia
Joined Apr 2011
Do we need to change the sensor direction or just same as one of available listed on the MWI code?
Flyrobot is offline Find More Posts by Flyrobot
Old Jul 03, 2012, 05:28 AM
TS00 is offline
Find More Posts by TS00
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
No, just define it as a Crius SE and it works fine.
TS00 is offline Find More Posts by TS00
Old Jul 03, 2012, 06:53 AM
Quadframes is offline
Find More Posts by Quadframes
Quadframes's Avatar
Joined Jun 2011
mine just arrived to, comes pre installed with multiwii ver 2 I will try and upload megapirate later and report back or stay tuned here
Quadframes is offline Find More Posts by Quadframes
Old Jul 03, 2012, 07:59 AM
Quadframes's Avatar
Joined Jun 2011
double post !!
Old Jul 03, 2012, 08:35 AM
mealie is offline
Find More Posts by mealie
Joined Jun 2011
add this code to def.h in MultiWii 2.0 or later verson
#if defined(CRIUS_AIO_PRO_V1)
#define MPU6050
#define HMC5883
#define MS561101BA
#define ACC_ORIENTATION(X, Y, Z) {accADC[ROLL] = -X; accADC[PITCH] = -Y; accADC[YAW] = Z;}
#define GYRO_ORIENTATION(X, Y, Z) {gyroADC[ROLL] = Y; gyroADC[PITCH] = -X; gyroADC[YAW] = -Z;}
#define MAG_ORIENTATION(X, Y, Z) {magADC[ROLL] = X; magADC[PITCH] = Y; magADC[YAW] = -Z;}
#define MPU6050_EN_I2C_BYPASS // MAG connected to the AUX I2C bus of MPU6050
#undef INTERNAL_I2C_PULLUPS
#endif
then add this to "boards and sensor definitions" in config.h
#define CRIUS_AIO_PRO_V1 // Crius Multiwii AIO PRO v1.0
mealie is offline Find More Posts by mealie
Old Jul 03, 2012, 09:07 AM
titeuf007 is offline
Find More Posts by titeuf007
Joined Jun 2006
titeuf007 is offline Find More Posts by titeuf007
Old Jul 03, 2012, 09:54 AM
Flyrobot is offline
Indonesia
Joined Apr 2011
It could be just working but its not maximum capability since those board has difference sensor with difference resolution sensitivity.
This board using exactly the same as 0.4.3MS sensor, this sensor using the highest resolution on MWI world as i know.
Old Jul 03, 2012, 10:07 AM
Joined Jun 2006
you are right!
i think it s completely different
Old Jul 03, 2012, 10:08 AM
Quadframes's Avatar
Joined Jun 2011
#define MPU6050
#define HMC5883
#define MS561101BA
#endif
Thanks that worked
Old Jul 03, 2012, 10:41 AM
Flyrobot is offline
Indonesia
Joined Apr 2011
Anyone know where is to get this naviboard for this FC in ebay ?
http://rctimer.com/index.php?gOo=goo...6&productname=
Old Jul 03, 2012, 10:58 AM
fjaffre is offline
Find More Posts by fjaffre
Joined Dec 2011
Hello Quadframes ! Inside the box, there is no manual of connection or other ? Cordially.
fjaffre is offline Find More Posts by fjaffre
Old Jul 03, 2012, 12:11 PM
Quadframes's Avatar
Joined Jun 2011
Hi correct there is NO manual only the leads.
Old Jul 04, 2012, 03:13 AM
Quadframes's Avatar
Joined Jun 2011
Last night I uploaded MegaPirateNG 2.6 R3 uploaded and its working ;-)
Old Jul 04, 2012, 08:16 AM
mealie is offline
Joined Jun 2011
How can we change the 3-axis direction of sensor in MegaPirateNG ?
The heading sign of AIO PRO is the y-axis.
Thanks!
Old Jul 04, 2012, 09:49 AM
magik30 is offline
Find More Posts by magik30
France, Languedoc-Roussillon, Nimes
Joined Mar 2012
hello
woow I can buy that FC I await the result of your tests.
thank you
magik30 is offline Find More Posts by magik30
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
