Old Jul 27, 2012, 05:50 AM
Sir Alex is offline
Find More Posts by Sir Alex
Aleksey Kharlanov
Беларусь, Минская область, Минск
Joined Sep 2011
Originally Posted by Jeppie View Post
@ Careyer;
For MPNG turn it 90 deg clockwise (not 45 deg).
MPNG 2.6 R6 works fine without rotation.
Sir Alex is offline Find More Posts by Sir Alex
Old Jul 27, 2012, 05:51 AM
flyboygaac is offline
Find More Posts by flyboygaac
flyboygaac's Avatar
Portugal, Lisbon, Sintra
Joined Jul 2011
Originally Posted by MrFawlty View Post
Thx alot Mis_B for the info. awesome!
Do i need a transistor or something between pin 33 and the leds?
thx again
I'm moving from Crius SE to Crius AIO Pro, and still trying to find were to connect things. Can you help me check if this ir correct?:
- Buzzer connects to pin 32 (with 1kohm resistor) (identified has CamPitch on this board) (needs external driver. right?)
- Led (Lipo status): connects to pin 32 (with 1kohm resistor) (identified has CamPitch on this board)
- Lipo voltage sense: connects to pin A3 from A0~A5 plug
- Led Flasher: with this quoted procedure (port C4) connects to pin 33 (with 1kohm resistor or transistor if more then 1 led) (identified has CamRoll on this board)
- Led landing lights: By default uses port C0 witch is digital pin 37... where is that? what to use?
I thought that Pin 32 and 33 were inputs from radio Rx to assign 2 channels to control cam pitch and roll, that will override stabilization movements. Is this correct?
If it is I want to use this feature. In this case what pins should I use for led flash and led lipo/buzzer?
Pin 34 and 35 that are in the middle of the board are usable?
flyboygaac is offline Find More Posts by flyboygaac
Old Jul 27, 2012, 06:32 AM
MrFawlty is offline
Find More Posts by MrFawlty
Joined Mar 2011
Thx again , great info.
Really like this fc.
gps hold works great. will try rth today.
/Magnus
Originally Posted by mis_b View Post
Yes, if you use 12V led strips's or other 12V led's.
Get some NPN transistor (0.5A of collector current or better) add 1kohm resistor series in base, connect second terminal of resistor to pin 33 of AIO, connect emiter to GND and collector to - point of LED's. + LED's to +battery.
MrFawlty is offline Find More Posts by MrFawlty
Old Jul 27, 2012, 07:52 AM
stif is offline
Find More Posts by stif
Joined Nov 2011
hello guys
message to people with Ublox GPS problem and plan to change it.
How about this one : http://www.drotek.fr/shop/en/90-pa6c-gps-llc.html ?
Does it work with MegapirateNG?
stif is offline Find More Posts by stif
Old Jul 27, 2012, 09:55 AM
nebstress is offline
Find More Posts by nebstress
Advanced Monkey
nebstress's Avatar
United Kingdom, England
Joined Nov 2011
Originally Posted by flipflop View Post
So, does this mean my new Multiwii MWC FC CN-06 GPS Receiver, unopened GPS is useless? Which GPS did you end up going with, I'm planning on using MW software, but don't have the knowledge/skills to add an eeprom to my current GPS.
No, 'Multiwii MWC FC CN-06 GPS Receiver' is very good & works well with both MegaPirate & MultiWii.
I got 10 satellites in doors yesterday:
Look, there's my house:
The only issue with the 'Multiwii MWC FC CN-06 GPS Receiver' is that the settings reset if its left unpowered for 24-48 hours, so you simply have to set them again, can be little frustrating.
nebstress is offline Find More Posts by nebstress
Old Jul 27, 2012, 10:05 AM
Kipkool is offline
Find More Posts by Kipkool
Old Flying Bastard
Kipkool's Avatar
France, IdF, Paris
Joined Jun 2011
Originally Posted by stif View Post
hello guys
I us this one it's perfect. Works with 10hz without problem. But default config is 1hz 9600bds.
I've changed the default firmware with a 10hz 115200 one to avoid reconfiguring it when the bat is down.
Kipkool is offline Find More Posts by Kipkool
Old Jul 27, 2012, 11:11 AM
Borneoben is offline
Find More Posts by Borneoben
United States, TX, Houston
Joined Jan 2005
So the on-board battery doesn't keep the settings?
That's strange. So what does the on-board battery do?
So you have to power on the board every 24-48 hours and it keeps all the new settings?
Borneoben is offline Find More Posts by Borneoben
Old Jul 27, 2012, 11:28 AM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
The on board battery keeps the settings for 24-48 hours.
The battery is for 'Hot starts' so you don't have to wait every time for a cold start.
Old Jul 27, 2012, 11:34 AM
scribble007 is online now
Find More Posts by scribble007
United States, CA, Yosemite Lakes
Wasnt that the reason for the EEPROM mod?
To give it a place to store settings in a non-volatile place? like a tiny flash card?
scribble007 is online now Find More Posts by scribble007
Old Jul 27, 2012, 01:07 PM
ziojos is offline
Find More Posts by ziojos
Joined May 2010
Do You need to power on-off-on to have serial data ?
ziojos is offline Find More Posts by ziojos
Old Jul 27, 2012, 01:33 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
I have to do that in u-center but not with MWC.
Old Jul 27, 2012, 02:00 PM
lucianozan is offline
Find More Posts by lucianozan
lucianozan's Avatar
Italy
Joined Feb 2009
No, 'Multiwii MWC FC CN-06 GPS Receiver' is very good & works well with both MegaPirate & MultiWii....,,
I agree. I'm using this GPS with MultiWii and it works great...but reconfiguring every time you use it is really frustrating! In order to have it working I need always to switch it on/off two times.
Luciano
lucianozan is offline Find More Posts by lucianozan
Old Jul 27, 2012, 03:00 PM
Joined Jan 2005
So what are the alternative GPS Units that don't have this issue and still work with both MWC and MPNG?
Old Jul 27, 2012, 03:07 PM
Advanced Monkey
nebstress's Avatar
Joined Nov 2011
If a GPS module will work with MWC then it will work with MPNG (only the Bauds are different)!
Not to state the obvious but have you thought about "Extend Board for AIO PRO FC"
Old Jul 27, 2012, 04:08 PM
Kipkool is offline
Old Flying Bastard
Kipkool's Avatar
France, IdF, Paris
Joined Jun 2011
This one is crap, it's old and can do 5hz max no 10hz.
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
