Old Jul 26, 2012, 04:40 PM
brettwal is offline
Find More Posts by brettwal
Anti-Gravity
United States, LA, Opelousas
Joined Mar 2012
Originally Posted by Jochen222 View Post
Hi,
I use a transistor NPN (for example) BC547 with base resistor to pin 32 - that works an MultiWii.
So, unlike the SE, this board will not work w/o a driver?
brettwal is offline Find More Posts by brettwal
Old Jul 26, 2012, 04:50 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
where can i buy those 4 pin white connector with wires?
thanks
jy0933 is offline Find More Posts by jy0933
Old Jul 26, 2012, 07:13 PM
flipflop is offline
Find More Posts by flipflop
So, does this mean my new Multiwii MWC FC CN-06 GPS Receiver, unopened GPS is useless? Which GPS did you end up going with, I'm planning on using MW software, but don't have the knowledge/skills to add an eeprom to my current GPS.
Originally Posted by nebstress View Post
When you have made all the changes & sent them you need to save them, go to "Receiver" then down to "Action" & click on "Save Config".
The settings will reset within 8 - 24 hours of no power if you are using "Multiwii MWC FC CN-06 GPS Receiver", this is very frustrating so I have given up using this GPS module with the CRIUS AIOP.
flipflop is offline Find More Posts by flipflop
Old Jul 26, 2012, 08:07 PM
ibooo is offline
Find More Posts by ibooo
Joined Dec 2007
RTH test and crash
Test CRIUS AIO return home and Crach (0 min 13 sec)
ibooo is offline Find More Posts by ibooo
Old Jul 26, 2012, 08:17 PM
ezsport is offline
Find More Posts by ezsport
United States, FL, Crestview
Joined Jul 2012
I need help. I have the Crius AIO Pro and the GPS. The board works fine with both wii gui and wingui. The GPS is configured per FPV central with the ucenter. GPS works good with ucenter and is configured 115200/ 100ms/10, etc. and shows good data. Plugged in to the AIO the power light comes on, but no data or sats on either GUI. Wiring checked and re-soldered. What next?
ezsport is offline Find More Posts by ezsport
Old Jul 26, 2012, 08:30 PM
scribble007 is offline
Find More Posts by scribble007
United States, CA, Yosemite Lakes
What GPS module you using?
Seems like people who are using that 06 model are having issues without doing the Eeprom mod or what ever it is
scribble007 is offline Find More Posts by scribble007
Old Jul 26, 2012, 09:00 PM
mis_b is offline
Find More Posts by mis_b
Poland
Joined May 2009
Originally Posted by MrFawlty View Post
Thx alot Mis_B for the info. awesome!
Do i need a transistor or something between pin 33 and the leds?
thx again
Yes, if you use 12V led strips's or other 12V led's.
Get some NPN transistor (0.5A of collector current or better) add 1kohm resistor series in base, connect second terminal of resistor to pin 33 of AIO, connect emiter to GND and collector to - point of LED's. + LED's to +battery.
mis_b is offline Find More Posts by mis_b
Old Jul 26, 2012, 09:29 PM
ezsport is offline
Joined Jul 2012
I guess the 06. I got it recently from RC Timer (controller board too). yes, with magnifier the board for the GPS has "CN06"
Old Jul 26, 2012, 09:47 PM
ibooo is offline
Joined Dec 2007
YOU SAME MY PROBLEM
I USE THIS CONFIG
#define GPS_SERIAL 3
#define GPS_BAUD 115200
AND USE TX3,RX3
Old Jul 26, 2012, 10:03 PM
ezsport is offline
Joined Jul 2012
Thanks ibooo for the response. I read somewhere that TX/RX 3 are for something else, but if it works I can only think we are moving away from something defined somewhere about serial 2.
Old Jul 26, 2012, 10:24 PM
Anyone else still waiting on this FC or other parts to come in before they can fly?
Because the anticipation is KILLING ME
am I alone? lol
Old Jul 27, 2012, 12:08 AM
careyer is offline
Find More Posts by careyer
member of TheBlindHawks
careyer's Avatar
Joined Feb 2011
Orientation of Crius AIO Pro1 in MPNN
Hi,
thanks a lot to Sir Alex!
Now the board has with MPNG the same orientation as in MWC !!! Im happy!
Does that mean that from now on one must not mount the FC rotated by 45degrees (compared to MWC) on the frame when using MPNG?
Currently designing a new frame and i wonder if i need to drill holes for normal mount AND 45degree offset mount.
Thanks for your answer!
Thomas Berndt
careyer is offline Find More Posts by careyer
Old Jul 27, 2012, 12:31 AM
carl1864 is offline
Find More Posts by carl1864
Joined Jan 2010
Kicking around the idea of giving MegaPirate a try, but have a couple questions.
1. What's the learning curve like on MegaPirate? I consider the Multiwii learning curve pretty steep, but I'm quite familiar with it now, not sure if I want to start learning all over again.
2. How difficult is it to switch back and forth on this board? Relatively simple like just flashing the firmware, and changing the board orientation (since I heard the orientations were different). Or do you have to totally change all the motor outputs around, reconfigure your tx, recalibrate esc's, and a bunch of other stuff?
carl1864 is offline Find More Posts by carl1864
Old Jul 27, 2012, 02:01 AM
Borneoben is offline
Find More Posts by Borneoben
United States, TX, Houston
Joined Jan 2005
am I alone? lol
You are not alone!
Mine is due to arrive very soon!
Borneoben is offline Find More Posts by Borneoben
Old Jul 27, 2012, 05:40 AM
Jeppie is offline
Find More Posts by Jeppie
Jeppie's Avatar
The Netherlands, NH, Amsterdam
Joined Jun 2002
@ Careyer;
For MPNG turn it 90 deg clockwise (not 45 deg).
Jeppie is offline Find More Posts by Jeppie
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
