Old Dec 29, 2012, 01:35 PM
marvin081 is offline
Find More Posts by marvin081
marvin081's Avatar
United States, TX, Laredo
Joined Dec 2011
Hello i downloaded mpng 2.8 r2 and in arduino after i make the changes in apm_config it gives me the following error:
ArduCopter.pde:-1: error: 'UBRR2H' was not declared in this scope
ArduCopter.pde:-1: error: 'UBRR2L' was not declared in this scope
ArduCopter.pde:-1: error: 'UCSR2A' was not declared in this scope
ArduCopter.pde:-1: error: 'UCSR2B' was not declared in this scope
ArduCopter.pde:-1: error: 'U2X2' was not declared in this scope
ArduCopter.pde:-1: error: 'RXEN2' was not declared in this scope
ArduCopter.pde:-1: error: 'TXEN2' was not declared in this scope
ArduCopter.pde:-1: error: 'RXCIE2' was not declared in this scope
ArduCopter.pde:-1: error: 'UDRIE2' was not declared in this scope
ArduCopter.cpp: In function 'void USART2_RX_vect()':
ArduCopter.pde:-1: error: 'UDR2' was not declared in this scope
ArduCopter.cpp: In function 'void USART2_UDRE_vect()':
ArduCopter.cpp: At global scope:
ArduCopter.pde:-1: error: 'UBRR3H' was not declared in this scope
ArduCopter.pde:-1: error: 'UBRR3L' was not declared in this scope
ArduCopter.pde:-1: error: 'UCSR3A' was not declared in this scope
ArduCopter.pde:-1: error: 'UCSR3B' was not declared in this scope
ArduCopter.pde:-1: error: 'U2X3' was not declared in this scope
ArduCopter.pde:-1: error: 'RXEN3' was not declared in this scope
ArduCopter.pde:-1: error: 'TXEN3' was not declared in this scope
ArduCopter.pde:-1: error: 'RXCIE3' was not declared in this scope
ArduCopter.pde:-1: error: 'UDRIE3' was not declared in this scope
ArduCopter.cpp: In function 'void USART3_RX_vect()':
ArduCopter.pde:-1: error: 'UDR3' was not declared in this scope
ArduCopter.cpp: In function 'void USART3_UDRE_vect()':
I followed the instruction on the readme file, replaced the libraries folder and all.
I am using Crius AIOP V1.1
any help would be really appreciated.
marvin081 is offline Find More Posts by marvin081
Old Dec 29, 2012, 02:02 PM
rcjose is offline
Find More Posts by rcjose
United States, TX, Richmond
Joined Aug 2010
Just got the same error yesterday. In Arduino, under tools check that the board selected is the Arduino Mega 2560 or Mega ADk.
I am using this very well written manual from Jumpy07:
rcjose is offline Find More Posts by rcjose
Old Dec 29, 2012, 02:17 PM
marvin081's Avatar
Joined Dec 2011
Thanks that worked i forgot to change back the board type after programming a minimosd.
thanks again
Old Dec 30, 2012, 01:59 AM
fishinrflyin is offline
Find More Posts by fishinrflyin
RussMc
Olympia WA
Joined Nov 2004
Hi Guys,
I have gotten a long ways with the great manuals and wealth of info on this thread but am stuck with something that has to be really simple.
I am trying to set up the flight modes, got the transmitter programmed for 6 modes, confirmed the PWM settings are right using the Mission Planner/Configuration/Radio Calibration - but can’t figure how to redirect the Tx output for selecting flight mode from channel 8 to channel 5.
I’m using :
Turnigy 9x original firmware v2.0 – FrSky DHT-U ¬
FrSky D8R-2+ Rx
Crius AIOP V 1.0
MPNG 2.7 R4
Mission Planner 1.2.27
Rx out - AIOP in
1 - A9
2 - A10
3 - A8
4 - A11
5 - A13
6 - A15
7 - A14
8 - A12
Transmitter programming was done using 2 switches (a 3 position and a 2 position). I tuned the mixes to get the PWM settings as recommended here (http://diydrones.com/profiles/blogs/...-for-turnigy-1 ).
Mission planner shows proper PWMs for the 6 flight modes on Channel 8. How do I redirect that so I can get flight modes? I tried switching 8 (Rx out) to A13 (AIOP in) but that doesn’t work. Is there a programming item for the Tx in APM_Config.h or something that I am missing?
fishinrflyin is offline Find More Posts by fishinrflyin
Old Dec 30, 2012, 05:20 AM
Jumpy07 is offline
Find More Posts by Jumpy07
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Originally Posted by renatoa View Post
Maybe is time to give Sir Alex and whole MPNG team a warm THANK YOU,
You can make a small donation to the MPNG team to help them continue their great work, they put a lot of time and effort into development and they allways need new versions of hardware etc to test.. making a donation helps to support their good work.
You can do this via Paypal at the link below like I did...
http://code.google.com/p/megapirateng/
Jumpy07 is offline Find More Posts by Jumpy07
Old Dec 30, 2012, 07:24 AM
wanghailan9 is offline
Find More Posts by wanghailan9
Australia, NT, Burt Plain
Joined Dec 2012
Very nice spec.
wanghailan9 is offline Find More Posts by wanghailan9
Old Dec 30, 2012, 07:45 AM
Fester 1 is offline
Find More Posts by Fester 1
ProFester
Fester 1's Avatar
United States, NY, Wallkill
Joined Feb 2008
Originally Posted by fishinrflyin View Post
Hi Guys,
I’m using :
FrSky D8R-2+ Rx
Crius AIOP V 1.0
MPNG 2.7 R4
Rx out - AIOP in
1 - A9
2 - A10
3 - A8
4 - A11
5 - A13
6 - A15
7 - A14
8 - A12
Manually switch the wires on the FC board . Switch the wires #5 & #8 . The gear channel is 5 on spektrum. I dont what it is on a Turnigy 9x ,Leave your radio programed as the post you used to set it up .
Fester 1 is offline Find More Posts by Fester 1
jimbobsi is offline
Find More Posts by jimbobsi
Joined Nov 2012
Totally agree. I already made it
jimbobsi is offline Find More Posts by jimbobsi
Old Dec 30, 2012, 07:48 AM
RHTizzy is offline
Find More Posts by RHTizzy
RHTizzy's Avatar
The Netherlands, NH, Bussum
Joined Feb 2012
Great idea! Done! Thanks Alex for all your hard work and dedication!
And of course best wishes to all for the new year!
RHTizzy is offline Find More Posts by RHTizzy
Old Dec 30, 2012, 07:49 AM
jimbobsi is offline
Joined Nov 2012
I need a simple camera trigger via RC Channel X and a digital PIN e.g. 34
I can´t get the build in camera trigger (Mission Planner CH7) working.
Does anybody know how to do this?
Old Dec 30, 2012, 08:09 AM
Sir Alex is offline
Find More Posts by Sir Alex
Aleksey Kharlanov
Беларусь, Минская область, Минск
Joined Sep 2011
Look at ap_relay module, looks like it connected to different pin...
Sir Alex is offline Find More Posts by Sir Alex
Old Dec 30, 2012, 11:29 AM
jimbobsi is offline
Joined Nov 2012
I looked it up in AP_Relay.cpp and AP_Relay.h
Seems to me there are no pins defined
I also tested Relay in Terminal Mode in mission planner an measured all Pins on the Board. Nothing seems to switch
Old Dec 30, 2012, 04:49 PM
Raycichocki is offline
Find More Posts by Raycichocki
Joined Dec 2012
MPNG and Copter GCS
I'd like to use Copter - GCS as a way to tweak my Crius AIOP from an android phone, away from my computer. Will it work over plain old Bluetooth with MPNG ?
is there any other app that I can use with an ipad, iphone or android ?
Ray
Raycichocki is offline Find More Posts by Raycichocki
Old Dec 30, 2012, 05:55 PM
Mochaboy is offline
Find More Posts by Mochaboy
Radd Graduate '06
Mochaboy's Avatar
United States, MA
Joined Aug 2006
Some fun with MPNG r247 - still haven't loaded the tested release.
Tuning Flight #10 and Flight test Compilation (4 min 14 sec)
It's taken a long time to get to this point - and that's all a function of the pilot not the platform.
I did want to take this one opportunity to share a public service announcement and remind everyone to do your preflight checks. I came this >< close to a fly away because for all the wonders of RTL - it's not worth a damn if you don't have a GPS signal - of course - I didn't notice this until I was in a bit of a pickle.
I've since rectified the situation and spent a few minutes tapping together a preflight checklist to ensure something silly like this doesn't happen again.
Mochaboy is offline Find More Posts by Mochaboy
Old Dec 30, 2012, 06:32 PM
crash8384 is offline
Find More Posts by crash8384
crash8384's Avatar
United States, OK, Erick
Joined Aug 2011
hi all, took a break from arduino and programing etc for a few months. I have the aio fc and the crius cn-06 ublox gps modual.
I want to use mpng and mission planner, I have scanned over this thread but after the long few month break after I received the fc and gps there is soooo much more info and post I don't have the time to read every one.
so my ? is.............................
where to start ? I have the latest arduino and mpng files downloaded. ( I think) any one have a pic of the gps to fc connections ?
I have also downloaded the pdf docs. for code changes.
ive attempted months ago to get older off brand gps to work and gave up and bought ublox. sence tyhemn I ha vent messed with it. wondering if someone can get me started with correct known software that will work. im fimmillar with arduino but not mpng or ardupilot. this is my first. thanks in advance.
crash8384 is offline Find More Posts by crash8384
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
