Dornbirn / Austria
Joined Mar 2008
if the copter is drifting away more and more, check your I-Gain, if it's set too high then you will see this result, so try to set it to 0 first other than that, did you try auto trim? http://code.google.com/p/arducopter/wiki/AC2_AutoTrim |
Joined Mar 2012
Hey guys.
I have an older Crius MWC Board right now and i am thinking about getting a Crius AIO Pro because it has more Pins, better(?) Sensors and i would like to give GPS+MegaPirate a try. But there are a few Questions left: 1: Can i still run my Bluetooth Module with MutliWii AND MegaPirate? 2: Can i use this Sonic Sensor? Also MutliWii AND MegaPirate? 3: How many AUX Channels do i have with AIO Pro? 4: How accurate are the Crius AIO Sensores compared to my old Crious? 5: How good is a Crius AIO+GPS running MegaPirate compared with an AMP using the AMP Firmware? Thanks for your help ! Sandro |
The Netherlands, FR, Wymbritseradiel
Joined Oct 2005
2) yes 3) 4 ch5 ch6 ch7 ch8 4) better 5) can't tell..only use AIO |
Sverige, Örebro Län, Hallsberg
Joined Oct 2011
Rc Controll settings...
Hello guys,
I have been lurking this thread for a while and recently pulled the trigger on a AIOP board. I have it all set up on my computer and the radio at the moment. I'm using a Futaba 8FG Super wich in this case mean that all flight mode switches have 3 positions. I need some pointers on how to set this up. My questions: Acro mode is that the default mode, as in the mode that active if none of the options in controllsettings are active, correct? Do I need to be in Auto level mode to arm(with throttle + yaw input) I want to use this boart foa a AP plattform so the modes I'm most interested in are these: - Auto Level - Altitude Hold - Heading Lock - GPS Hold (once I get my gps, wich should arrive this week I hope) Does gps hold require any other modes? Does my settings seem ok? How did you guys set it up? |
As for your settings - I'm not sure what MWII calls it, but Step #1 Step #1 Step #1 (yes it bears repeating) is to do initial PID tuning in Stabilize Mode. You can't move on to any of the other flight modes until you get a stable platform in stabilize mode, because the other flight modes borrow or base parameters from this flight mode. PID tuning is not that difficult - what you're trying to do is find the max value it will take then back off a few ticks. The defaults are pretty good so long as you're in the suggested weight range of your rig (i.e. not too heavy - not too light). As for the other flight modes...Acro disables the 45 degree limits so you can do things like sport flying and flips and rolls. This will probably be the LAST mode you work on. For me my progression went like this. Stabilize PID tuning (in your case Stable/Level mode) GPS Hold/Position Hold PID tuning Guided (waypoints) RTL (Return Home) Altitude Hold I don't really use, but I can see how it would be useful for AP. I would say it's usefulness is limited unless you have sonar worked into your rig. To rely on the barometric pressure sensors for altitude alone probably won't cut it. Heading hold could be useful for you as well since it maintains its heading for things like panning shots. As for settings - I'll let the mwii guys chime in - if you do a search on the mwii thread you should see some posts for pid tunings that you can borrow just to get a sense for what kinds of changes and what ranges are possible. Not sure if that helps - but welcome to the party - oh and look up megapirate and mission planner and see how that suits your needs. Mocha |
| Thread Tools | |
| Discussion New updated Crius Multiwii SE flight controller | SGsoar | Multirotor Electronics | 72 | May 15, 2013 08:36 PM |
| Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 | pprioverde | Multirotor Talk | 29 | Nov 21, 2012 09:58 PM |
| Discussion Jim, any plans for more multi rotor flight controller? | chris24g | Xtreme Power Systems | 12 | Jun 25, 2012 08:11 PM |
| Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots | wingspinner | FPV/RPV - Equipment and Vehicles (FS/W) | 3 | May 28, 2012 12:55 AM |
| Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) | SJackson | Multirotor Talk | 27 | Apr 30, 2012 08:51 PM |
