Old Nov 13, 2012, 03:43 AM
NEAGRON is online now
Find More Posts by NEAGRON
United Kingdom, Scotland, Aberdeen
Joined Mar 2010
Thank you Sir Alex for the update,yours Marty.
NEAGRON is online now Find More Posts by NEAGRON
Old Nov 13, 2012, 04:10 AM
Goofy68 is offline
Find More Posts by Goofy68
Sweden
Joined Sep 2010
Originally Posted by Sir Alex View Post
I'm very busy now and this week, so MPNG will be released next week...
Is there a place where I can read whats changed in the new version?
Goofy68 is offline Find More Posts by Goofy68
Old Nov 13, 2012, 04:17 AM
Sir Alex is offline
Find More Posts by Sir Alex
Aleksey Kharlanov
Беларусь, Минская область, Минск
Joined Sep 2011
Of course, you can read at DIYDrones site: http://diydrones.ning.com/forum/cate...istForCategory
Sir Alex is offline Find More Posts by Sir Alex
Old Nov 13, 2012, 05:19 AM
Goofy68 is offline
Sweden
Joined Sep 2010
Thankyou
Old Nov 13, 2012, 07:42 AM
npre is online now
Find More Posts by npre
Joined Jan 2011
Hooray! Thank you!
npre is online now Find More Posts by npre
Old Nov 13, 2012, 12:59 PM
jeff114 is offline
Find More Posts by jeff114
Joined Oct 2012
Hello,
I would like to use a remote controlled switch like this one :
http://www.hobbyking.com/hobbyking/s...d_Switch_.html
to on / off some night lights?
Where could it be connected and what code do I need to change in megapirateng?
Best regards,
jeff
jeff114 is offline Find More Posts by jeff114
Old Nov 13, 2012, 01:54 PM
crash8384 is online now
Find More Posts by crash8384
crash8384's Avatar
United States, OK, Erick
Joined Aug 2011
Originally Posted by scribble007 View Post
Never heard of it.
Whats the difference?
yes if you have bell or pancake motors you will need to flash your escs to wiiesc thru the new kk flash tool from lazyzero. i think its called 0.7 beta . i have it and seen the wiiesc flash on there.
its a known issue that simonk and flat motors dont like each other but the wiiesc flash will fix that.
crash8384 is online now Find More Posts by crash8384
Old Nov 13, 2012, 03:07 PM
1-2-hak is offline
Find More Posts by 1-2-hak
1-2-hak's Avatar
Joined Nov 2012
Thats great news as I was having trouble trying to port it myself.
Sir Alex - would you mind updating the porting method on the wiki so we can get some more insight for the next version.
1-2-hak is offline Find More Posts by 1-2-hak
Old Nov 13, 2012, 03:13 PM
antoine is offline
Find More Posts by antoine
France, Īle-de-France, Savigny-sur-Orge
Joined Nov 2005
All,
With the Extend Board for AIO PRO FC which GPS baud should I use?
Do I need to setup the GPS as for a standalone GPS?
Also I bought the 3DR radio from RCTIMER, do I need to separate the XBEE from it? Is there any XBEE that will work with the extend board with the 3DR from RCTIMER?
Antoine
antoine is offline Find More Posts by antoine
Old Nov 13, 2012, 03:15 PM
scribble007 is offline
Find More Posts by scribble007
United States, CA, Yosemite Lakes
I have the bell RC timer 2830 1000kv motors. And like I said. 3 of the 4 work fine after flashing. So Im thinking I might have screwed something up.
Should I order another motor and esc and try flashing again. Or just order a new preflashed esc?
scribble007 is offline Find More Posts by scribble007
Old Nov 13, 2012, 03:26 PM
npre is online now
Joined Jan 2011
new simonk firmware works fine with pancake motors. it just took him a long time to fix the problem.
Old Nov 13, 2012, 06:45 PM
ThePara is offline
Find More Posts by ThePara
Multicopter Nut
ThePara's Avatar
Romania, Bucharest
Joined Dec 2011
I use RcTimer 5010 360 Kv pancakes since April on SimonK-ized 20A ESCs without any issues. And lately I setup a hexa on AX-4008Qs and it's running smooth as well.
ThePara is offline Find More Posts by ThePara
Old Nov 13, 2012, 06:47 PM
A Monell is offline
Find More Posts by A Monell
Gloucester Ma
Joined Dec 2002
pre flashed escs
do the pre flashed escs have a bootloader such that they can be re-flashed/updated through the receiver wire?
A Monell is offline Find More Posts by A Monell
Old Nov 13, 2012, 07:00 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Yes. Using lazyzero flashing tool.
Edit: sorry, they have to have had the bootloader loaded when they were flashed. I haven't seen store with preflashed ESCs with bootloader enabled
Edit2: forgot. Abusemark sells them with bootloader.
TheFernMan is offline Find More Posts by TheFernMan
Old Nov 13, 2012, 08:14 PM
rikkepos is offline
Find More Posts by rikkepos
Joined Oct 2012
failed to leave programming mode
rikkepos is offline Find More Posts by rikkepos
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
