Old Oct 17, 2012, 05:54 AM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
allright.. some while ago i was on the chat with rc timer, and they told me they were making their own 3DR radio's and should be released soon. they released them and state they are 100% compitable with 3DR/Xbee.. sounds interesting. but most interesting is the price.
$38.99 for a full set with free shipping...
link
only downside is that it's in the 900MHz band.. which is a cell band in most countries.
here's a quote:
The RCTimer Radio telemetry system base on 3DR Radio system and 100% compatible.
It's designed as an open source Xbee replacement radio set, offering a lower price, longer range (approx one mile) and superior performance to Xbee radios. It’s available in 915Mhz ; and in the following configurations: serial board (for the air) and USB (for the ground).
The system provides a full-duplex link using HopeRF's HM-TRP modules running custom, open source firmware. Interface to the module is via standard 5V-tolerant TTL serial / FTDI USB serial.
Firmware upgrades and configuration are fully supported in the APM Mission Planner. Configuration is also possible through the 3DR Radio configurator and AT commands.
Features
·Small size and light weight
·Available in 915MHz variants
·Receiver sensitivity to -121 dBm
·Transmit power up to 20dBm (100mW)
·Transparent serial link
·Air data rates up to 250kbps
·MAVLink protocol framing and status reporting
·Frequency hopping spread spectrum (FHSS)
·Adaptive time division multiplexing (TDM)
·Support for LBT and AFA
·Configurable duty cycle
·Built in error correcting code (can correct up to 25% data bit errors)
·Demonstrated range of several kilometers with a small omni antenna
·Can be used with a bi-directional amplifier for even more range
·Open source firmware
·AT commands for radio configuration
·RT commands for remote radio configuration
·Adaptive flow control when used with APM
·Based on the HopeRF HM-TRP radio module, featuring an SiLabs Si1000 RF microcontroller.
Datasheets of HM-TRP module: http://www.hoperf.com/upload/rf_app/HM-TRP.pdf
Documentation: http://code.google.com/p/ardupilot-mega/wiki/3DRadio
Radio Configurator(Air module need a USB-UART tool like FTDI to configure): http://vps.oborne.me/3drradioconfig.zip
Board schmatic:
Other
·Dimension: Air / Ground module(no include SMA connector) : 17mx35mm / 17mmx59mm
·Weight: Air / Ground module: 4.6g/16.8g(include cable and antenna) / 7.2g/17g(include antenna)
Package content
·Air Module( 915Mhz) x 1
·Ground Module(915Mhz) x 1
·UART 4Pin cable for Air module 300mm x1
·2.5dbi Antenna for two module x2
i think i will give it a try.
for 39 bucks i think i can't hurt right?
dutchcommando is offline Find More Posts by dutchcommando
Old Oct 17, 2012, 05:58 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
Originally Posted by critical_limit View Post
Hi All,
I´m very new to these Boards and I ordered a Crius AIO V1.1 last days.
Now I´m checking how to manage all these settings, flashing etc.
I´m not new to the R/C-Hobby, but first time using this kind of Boards.
Is there any step-by-step instruction to configure the Crius AIO with MegaPiratesNG Firmware?
I´ve read now days and days and learned a lot about it. But I can´t find any instruction for Beginners.
What I need to know is:
1) How to flash Crius AIO with MPNG correctly (which settings I have to do at the first time?)
2) Which Software do I need to make settings (with instructions an comments for Beginners)
3) How to setup my Futaba T12FG for flightmodes Alt-hold, Waypoints etc.
Sorry for asking, but I´m very new to these Boards. I have built several Copters with Naza and KK2.0-Boards, but not with this (at the first look) complicated System.
I´m asking, because I want to do FPV and want to be on the save side. So I decided to built a new Copter (with selfdesigned Frame created on a selfmade CNC-Plotter) and wnat to have Position-Hold, Alt-Hold, Autoland.
Ordered Crius AIO V1.1 and Multiwii MWC FC CN-06 GPS Receiver V2.0 and a Ultrasonic-Device.
Now I have to start learning to manage all these things.
Any recommendations for a Dummy? Any Beginners-Guides I have to read?
Thanx in advance
Dirk
http://code.google.com/p/megapirateng/
And ask Sir Alex. Hi is in this thread.
er9xuser is offline Find More Posts by er9xuser
Old Oct 17, 2012, 06:47 AM
Jumpy07 is offline
Find More Posts by Jumpy07
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Hi All,
Thanx in advance
Dirk
Dirk start with this http://www.rcgroups.com/forums/showa...mentid=5207041
Jumpy07 is offline Find More Posts by Jumpy07
Old Oct 17, 2012, 06:49 AM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
link
here's a quote:
Think these are the same but 433Mhz.. I have a set and they work great. $34.91
http://www.eforchina.com/view/120961...r-APM-APM2.htm
Old Oct 17, 2012, 06:55 AM
Joined Feb 2012
ey! cool! same price, better frequency! thanks.
Old Oct 17, 2012, 09:22 AM
Guru06 is offline
Find More Posts by Guru06
United States, NC, Raleigh
Joined Mar 2012
I ordered my telemetry kit on Monday, it should be here early next week.
Guru06 is offline Find More Posts by Guru06
Old Oct 17, 2012, 09:30 AM
Joined Feb 2012
rctimer or eforchina?
Old Oct 17, 2012, 09:43 AM
Guru06 is offline
Joined Mar 2012
RCtimer
Old Oct 17, 2012, 10:55 AM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Mine took two weeks from eforchina to UK.. with tracking info
Old Oct 17, 2012, 12:10 PM
macinr is offline
Find More Posts by macinr
macinr's Avatar
USA, CA, Santa Barbara
Joined Feb 2003
Originally Posted by jtpile View Post
Hi Guru 06,
To make my life easier with these molex connectors that comes with our AIO Pro I simply soldered the proper wires I needed to a pinout that were cut to size (4-6 pin). After soldering the Molex wires to the pinout I covered the soldered connection with heatshrink; it can't get any easier than that. This "method" keeps one from ruining or permanently altering their molex connectors; really nice if one wants to change things around plus these pinouts simply plug in and hold snug just by pushing them together. If anyone needs these pinouts I can get them at a local electronics surplus store very cheap. Please see photos uploaded here.
- cheers
What is that rubbery looking orange stuff on your connectors?
macinr is offline Find More Posts by macinr
Old Oct 17, 2012, 01:27 PM
Guntars is offline
Find More Posts by Guntars
Latvia
Joined Oct 2006
One question.... Is it possible to define low pass filter for gyro smoothing (120-50 hs) in megapirate's code (like in mw)?
Guntars is offline Find More Posts by Guntars
Old Oct 17, 2012, 03:17 PM
RaySuave is offline
Find More Posts by RaySuave
United States, MI, Dearborn Heights
Joined Dec 2009
I'm running MPNG firmware with CRIUS AIOP and Extend Board for a quad. Was wondering if anyone knew what would cause a quad's motors to speed up by themselves and go berserk if the transmitter is turned off while the quad is still armed?
I have had two accidents where I turned the TX off before disarming. The second time, it attacked me, I ducked out of the way and then it attacked my little Eflite MQX quadcopter ripping off one of its little propellers. I'm used to turning the transmitter off at anytime since I flew planes before quads.
RaySuave is offline Find More Posts by RaySuave
Old Oct 17, 2012, 03:35 PM
RHTizzy is offline
Find More Posts by RHTizzy
RHTizzy's Avatar
The Netherlands, NH, Bussum
Joined Feb 2012
Originally Posted by Jumpy07 View Post
Sorry no ............PWM RSSI is output by the FrSky RX into the MinimOSD, you dont need RSSI.. its a nice to have..
Fail safe?
RHTizzy is offline Find More Posts by RHTizzy
Old Oct 17, 2012, 04:14 PM
janekx is offline
Find More Posts by janekx
janekx's Avatar
Czech Republic, South Moravian Region, Brno
Joined Aug 2012
Look there http://9xforums.com/forum/viewtopic.php?p=22390#p22390
janekx is offline Find More Posts by janekx
Old Oct 18, 2012, 12:08 AM
Guru06 is offline
Joined Mar 2012
Anyone have tips on setting up MegaPirate flight modes with a modded 9x? I'm hoping to get all of them going by using switches not the knobs.
Flight mode for MegaPirate
Acro
Alt Hold
Simple
Loiter (uses GPS)
Guided (uses GPS)
Position (uses GPS)
Circle (uses GPS)
RTL (uses GPS)
Auto(uses GPS)
Follow Me(uses GPS)
Mini-HowTo Arduino and HobbyKing Multi-Rotor Control Board V3.0 or KKmulticontroller v5.5 pprioverde Multirotor Talk 31 Apr 14, 2016 01:58 AM
Discussion New updated Crius Multiwii SE flight controller SGsoar Multirotor Electronics 72 May 15, 2013 08:36 PM
Discussion Jim, any plans for more multi rotor flight controller? chris24g Xtreme Power Systems 12 Jun 25, 2012 08:11 PM
Sold One New, one used ArduPilot 2560 APM1.0 Flight Controlls/autopilots wingspinner FPV Equipment (FS/W) 3 May 28, 2012 12:55 AM
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
